Old 05-20-2015, 03:11 PM   #29
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Originally Posted by fika84 View Post
I guess maybe they could still be interested 4 months later... at least it's in 2015.
lol you can always add reliable mods down the road!
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 05-20-2015, 03:40 PM   #30
CSG Mike
CSG Mike's Avatar
Originally Posted by Gopherboy6956 View Post
I would change it if you're going FI and tracking. Have you seen the stock radiator? Its about as thin as a AA battery. I Changed it, and I highly recommend it along with the Oil cooler - again IF you are going to track.
On my vortech kit on stock pulley, tuned to 275/hp 199/tq the stock clutch started slipping at 10k miles. The stage 1 exedy clutch only holds 203tq and the wheels, while the stage two holds 224. So, might as well do Stage 2 if you're going to do it.
Holds more power. Negatives are that the engagement is less smooth because you have less friction surfaces. I'd compare it to this in terms of engagement:
Stock clutch = Dimmer light switch
Race clutch = On/Off light switch
Otherwise it's just holding power.
Have you actually seen your stock radiator overheat?
Our preferred method is to add fans.
Old 05-20-2015, 03:47 PM   #31
Gopherboy6956
I looked at it once, and it was like "Bro dude, i'm so hot" so i was like, ON IT.
No - I added it there for more of a precaution than a requirement.
Old 05-20-2015, 05:43 PM   #32
sw20kosh
Drives: 2013 Black FR-S
Nope. We have been tracking and competing on stock radiator for almost 2 years while FI @ 300+ whp turbo. It may look thin but what you don't realize is a thin radiator has less restriction to airflow through it than a thick radiator. This car has issues with airflow through the frontal opening due to a sealed engine bay and a giant crash beam in the way of incoming airflow.
You cannot just make assumptions on how a part looks. You have to actually test it to see how it performs. In this case, a dinky small radiator actually performs beyond expectations based on its appearance.
The Following User Says Thank You to sw20kosh For This Useful Post:
Chad86 (05-22-2015)
Old 05-20-2015, 06:05 PM   #33
Gopherboy6956
Well then.
Turbo Reliability VS Supercharger reliability KGB Forced Induction 130 09-08-2015 09:55 AM
Leds could potentially blow ECU or BSI on 86? dssence Cosmetic Modification (Interior/Exterior/Lighting) 29 03-22-2014 12:37 AM
Potentially headlight stupid question BentAnat Cosmetic Modification (Interior/Exterior/Lighting) 7 08-21-2013 02:32 AM
Potentially Ordering a 2014 BRZ. Quick Question. Lobe BRZ First-Gen (2012+) — General Topics 36 06-14-2013 04:19 PM
GTS Man White Order Potentially up for grabs mikedsilva AUSTRALIA 3 08-31-2012 06:32 AM
