Old 01-22-2015, 08:32 PM   #1
Drakelee117
Drives: Subaru BRZ 2015
All the parts that could potentially increase the reliability of a superchared BRZ?
I've been tempting to go FI since the day I got the BRZ last year, and reliability is the biggest reason that's holding me back. I know there is a lot of discussion about what's the safest tune and there is no definite answer to that question: some people are doing fine with 400 whp while others have engine failure at 200 whp and stuff like that.
Personally I think I will be shooting for 280-300 whp on 93 Octane and stay CARB legal with all the mods. So here is the questions, what are the aftermarket parts that could at least minimize the chance of an engine failure? Radiator, oil cooler, CAI, upgraded fluids, oil catch can, maybe even a racing clutch? Anything I missed?
Drakelee117 is offline   Reply With Quote
Old 01-22-2015, 08:38 PM   #2
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Originally Posted by Drakelee117 View Post
racing clutch?
Some 9:1 pistons and a good tuner.
Really all the failures have been blamed on the tune as far as I know. That's the #1 thing.
Whatabouteggs is offline   Reply With Quote
The Following User Says Thank You to Whatabouteggs For This Useful Post:
Chad86 (02-14-2015)
Old 01-22-2015, 09:02 PM   #3
kbogarto
Drives: 2013 BRZ limited WRB
I second the tune as most important for reliability. You can get a tune with a lot of failsafes built in. Catch can and oil cooler probably not bad ideas.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
The Following User Says Thank You to kbogarto For This Useful Post:
Chad86 (02-14-2015)
Old 01-22-2015, 09:03 PM   #4
kbogarto
Is E85 considered more reliable since it is more knock resistant???
Old 01-22-2015, 09:58 PM   #5
chaoscentral
Drives: 2013 Scion FR-S Series 10
1 heat range colder spark plugs would be a recommendation. Those were basically a requirement when I supercharged my 2006 Mustang GT as they help prevent detonation on pump gas.
chaoscentral is offline   Reply With Quote
Old 01-22-2015, 10:34 PM   #6
Drakelee117
I thought E85 is not CARB legal? I am no expert but I feel like people usually use e85 with a more aggressive tuning so it might be rougher for the engine?
Old 01-22-2015, 10:37 PM   #7
Drakelee117
So what exactly is the difference between tunes? If I just get the supercharger kit with all the maps developed by Perrin or something like that included would there be problems?
Old 01-23-2015, 12:53 AM   #8
sw20kosh
Drives: 2013 Black FR-S
People use E85 to operate an engine without much worry of knock. You can make more power at the same boost level than with gasoline due to the increased octane and the E85 cools down the combustion chamber and charge air going into it.
People CAN use E85 to significantly raise the boost level and make bucket loads of power but it is not the only reason.
Running on E85 is considered safer as long as your tuner is competent.
The Following User Says Thank You to sw20kosh For This Useful Post:
kbogarto (01-24-2015)
Old 01-23-2015, 12:54 AM   #9
sw20kosh
Stock radiator doesn't need changing.
Old 01-23-2015, 09:00 AM   #10
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
E85 us readily available at many stations all over California.
-Jack Burton
Old 01-26-2015, 12:07 AM   #11
BlueLeader
Drives: Ultramarine Blue Scion FRS
Racing clutch? Unless you're driving like you're racing on a daily basis, I think a stage 1 will suffice if you have a modest tune or 2 clutch if more aggresive. This way a hardier clutch won't wear so fast compared to stock. I suggest staying away from puck clutches unless you want to hate driving stick.
BlueLeader is offline   Reply With Quote
Old 01-26-2015, 09:36 AM   #12
Drakelee117
I haven't done much research about racing clutches, what do they do exactly? I know they tend to bite the transmission harder, but what does it mean to driver? RPM drops faster? Easier to stall the car?
Old 01-26-2015, 10:50 PM   #13
BlueLeader
Read this from hotrod mag: http://www.hotrod.com/how-to/transmi...clutch-basics/
basically if you're gonna FI your car, you probably will want an upgraded street clutch. A racing clutch will be made of material overkill for your specs unless you're running dragster power. Also, some clutches are pucked, meaning they are not continuous, and is basically an on and off switch. In addition, they usually will pair it with a stiffer pressure plate so you'll need to hit 24 hr fitness and do some calf raises just to press your clutch. I had an evo and made the mistake of putting a 6-puck clutch on it with a heavier pressure plate. made the commute to LA want me to run the car into a ditch and just walk. So yes, most likely harder to drive and easier to stall. So if you want to keep your car reliable, you need not go overboard.
Old 01-26-2015, 10:53 PM   #14
stylsh
Drives: MY15 GTS
Choose the clutch that is suited to the amount of torque your car will probably make. There is no point in buying a stupidly stiff, multiplated or puck clutch of you are going to run a turbo with a stock engine. Unless you have plans on making big power with a built engine later on.
stylsh is offline   Reply With Quote
Turbo Reliability VS Supercharger reliability KGB Forced Induction 130 09-08-2015 09:55 AM
Leds could potentially blow ECU or BSI on 86? dssence Cosmetic Modification (Interior/Exterior/Lighting) 29 03-22-2014 12:37 AM
Potentially headlight stupid question BentAnat Cosmetic Modification (Interior/Exterior/Lighting) 7 08-21-2013 02:32 AM
Potentially Ordering a 2014 BRZ. Quick Question. Lobe BRZ First-Gen (2012+) — General Topics 36 06-14-2013 04:19 PM
GTS Man White Order Potentially up for grabs mikedsilva AUSTRALIA 3 08-31-2012 06:32 AM
