#15 |
Drives: WRB Limited BRZ
Did you change your spark plugs? When you got your Supercharger installed?
#16 |
Drives: toyota mr2/ Toyota GT86
#17 |
Drives: Ultramarine Blue Scion FRS
ZXE27HBR8 is our oem spark plug. Denso. heat range 9. You can go colder but you may not need to. Its pretty damn cold for 200 hp car. The plugs can handle a boosted frs.
#19 |
Ridge Racerrrrrrrrr
a LS7
| The Following User Says Thank You to SkAsphalt For This Useful Post: | Dream20b (01-27-2015) |
#20 |
Drives: Subaru BRZ 2015
I am still at the planning stage, really tempted but afraid of the consequence. Especially I don't have the best of luck personally when it comes to mechanics. Personally I am always the one that has random problems that are 90% not my fault.
#21 |
#22 |
http://www.ft86club.com/forums/showthread.php?t=73684 You NEED these two: 21311AA170 - OIL COOLER, COMPLETE 21317AA070 - CONNECTOR, OIL COOLER How you want to route is up to you. The thread/video I pasted above routes to the throttle body coolant res lines (turbo guys typically tap into this to cool their snails). The connections are not 1:1, and some say the disparity between the oil cooler and TB diameters will affect performance. However, as evidenced by the video and others who went this route, the performance is close to or exactly like the alternative option, which would be to tap into the block.. lots more parts and headaches. |
| The Following User Says Thank You to Koa For This Useful Post: | BlueLeader (01-27-2015) |
#23 | |
http://www.redline360.com/hks-spark-...rz-50003-M45HL I'm about to head to work but you can probably look into this on your free time. |
#24 | |
#25 |
Drives: 2014 WRB BRZ
While I might be talking out of my ass, Subaru probably intended for this car to be mildly boosted as an upgraded model from the get go, which would explain some of their design choices. Plus, all of their other models are turbo equipped, so I wouldn't be surprised if they did it out of habit.
#26 | |
#27 | ||
Drives: 13 BRZ Limited WRB
I would change it if you're going FI and tracking. Have you seen the stock radiator? Its about as thin as a AA battery. I Changed it, and I highly recommend it along with the Oil cooler - again IF you are going to track.
Stock clutch = Dimmer light switch Race clutch = On/Off light switch Otherwise it's just holding power.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
#28 |
I guess maybe they could still be interested 4 months later... at least it's in 2015.
| The Following User Says Thank You to fika84 For This Useful Post: | kch (05-20-2015) |
| Turbo Reliability VS Supercharger reliability | KGB | Forced Induction | 130 | 09-08-2015 09:55 AM |
| Leds could potentially blow ECU or BSI on 86? | dssence | Cosmetic Modification (Interior/Exterior/Lighting) | 29 | 03-22-2014 12:37 AM |
| Potentially headlight stupid question | BentAnat | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 08-21-2013 02:32 AM |
| Potentially Ordering a 2014 BRZ. Quick Question. | Lobe | BRZ First-Gen (2012+) — General Topics | 36 | 06-14-2013 04:19 PM |
| GTS Man White Order Potentially up for grabs | mikedsilva | AUSTRALIA | 3 | 08-31-2012 06:32 AM |
