Old 09-28-2014, 07:24 PM   #1
Euro7R
Drives: 2013 Subaru BRZ
Oil Filter Stuck
Oil filter is stuck. I've always hand tightened my oil filter on all my previous oil changes and never had oil filter stuck and can't get it off. I've spent 2 hours trying to get it off with bare hands and then elastic bands around the filter to get more grip.
I've tried turning it when the car is warm and cold and still won't budge. It's somehow stuck so tight, which is weird because it doesn't feel like hand tight anymore. I'm not sure if it's because it's a Toyota brand oem filter as the Toyota dealership where I get my oil change parts switched from Subaru to Toyota oil filters.
Any recommendation to remove this stuck filter? I think I might have to resort to using oil filter wrench, hoping it won't leave a mess.
Euro7R is offline   Reply With Quote
Old 09-28-2014, 07:29 PM   #2
ayau
Drives: Some rust bucket
Stab a long screw driver through the filter and turn. It might get a bit messy though.
The Following 2 Users Say Thank You to ayau For This Useful Post:
Euro7R (09-28-2014), Sportsguy83 (05-17-2015)
Old 09-28-2014, 07:37 PM   #3
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
There are many good oil filter wrenches out there of varying styles, most of which are non-destructive (i.e. strap, cap, band, etc.) but for God's sake, do not use the 'ol screwdriver method. Once you damage the filter, you're stuck until you can get it off. Worst case, leave the old filter in tact, replace the oil anyway and take it to a good shop.
BirdTRD is offline   Reply With Quote
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
Euro7R (09-28-2014), JohnJuan (09-29-2014)
Old 09-28-2014, 07:47 PM   #4
stugray
Drives: 2013 GBS BRZ Limited
I have found that grabbing them with sandpaper in your palm will often work if grip is the problem.
I also have about three different oil filter wrenches that wont fit my other cars, but this one is practically waving in the wind.
The Following User Says Thank You to stugray For This Useful Post:
Euro7R (09-28-2014)
Old 09-28-2014, 07:51 PM   #5
cnk
Drives: '13 DGM BRZ Limited
I use the oil filter caps, but also have a oil filter strap tool and one of the 3 pronged tools that pinch closed as you turn it. Have never failed to remove a filter with any of those 3.
Sent from my SAMSUNG-SM-N900A using Tapatalk
The Following User Says Thank You to cnk For This Useful Post:
Euro7R (09-28-2014)
Old 09-28-2014, 07:51 PM   #6
Euro7R
I'm planning to go to auto store and get a oil filter wrench that doesn't use the teeth kind to try it out. My friend lent me his oil filter wrench, but it's the one with the edgy teeth, so when I clamp on the filter, it'll destroy it and potentially leaving a mess.
The Following User Says Thank You to Euro7R For This Useful Post:
Old 09-28-2014, 09:08 PM   #7
stugray
Old 09-28-2014, 10:52 PM   #8
mike the snake
I use my leather belt. Wrap it around the filter so the buckle cinches it tighter in the direction you want to go, then you can wrap the belt further, or connect something to the belt and remove your filter.
Old 09-28-2014, 11:15 PM   #9
flippy (05-21-2015), Jrryjms07 (10-07-2014)
Old 09-28-2014, 11:19 PM   #10
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
This type of oil filter remover has never failed me. Squeeze/grip it hard enough so that the filter dents in a bit:
The Following 2 Users Say Thank You to NLSP For This Useful Post:
brandonblt2 (05-17-2015), TONYpepperon1 (10-03-2014)
Old 09-28-2014, 11:38 PM   #11
ZZT86
ZZT86's Avatar
Drives: BR86
3 pronged claw oil filter wrench is what you need - comes off in a second with a snap on 1/2 socket wrench !
ZZT86 is offline   Reply With Quote
Old 05-17-2015, 05:01 AM   #12
BaBaFlyingSheep
Drives: 2015 BRZ Ltd 6MT
I had the same problem today. Didn't have a lot of homemade solutions.
I ended up taking out the intake box to get more clearance and leverage and was able to twist it off by hand.
BaBaFlyingSheep is offline   Reply With Quote
Old 05-17-2015, 05:22 AM   #13
juliog
juliog's Avatar
Drives: 86
If none of the tools above work, try this one:
juliog is offline   Reply With Quote
The Following User Says Thank You to juliog For This Useful Post:
weedtank (05-21-2015)
Old 05-17-2015, 05:44 AM   #14
HATED1
HATED1's Avatar
Drives: 86
this may sound weird, but turn it in the direction to tighten it, then try to loosen it. It has worked for me in the past.
HATED1 is offline   Reply With Quote
key keeps getting stuck Covo_86 Issues | Warranty | Recalls / TSB 14 04-21-2014 09:55 AM
O2 Sensor stuck... ThisGuy919 Engine, Exhaust, Transmission 13 10-18-2013 05:58 AM
I'm Stuck In A Dilemma ALbadboy BRZ First-Gen (2012+) — General Topics 30 02-25-2013 08:02 PM
stuck in buffalo NY FT86R Scion FR-S / Toyota 86 GT86 General Forum 5 07-16-2012 10:29 PM
