Old 05-05-2015, 09:44 PM   #15
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
So I tested it out today... dam it warns me way too early like 1.5 intersection away too early.
The only option is either when approaching or when speeding. I'm going to change it to when speeding and test it again tmr.
krayzie is offline   Reply With Quote
Old 05-06-2015, 01:49 AM   #16
MalcolmHimself
MalcolmHimself's Avatar
Drives: 2015 BRZ
As in 1.5 intersections before the intersection with the camera? That doesn't seem too bad.
MalcolmHimself is offline   Reply With Quote
Old 05-06-2015, 07:36 AM   #17
krayzie
Drive From Home
krayzie's Avatar
Yea it'll go "speed camera up ahead" and then starts to beep slowly like a radar detector. I would like it more if it only warns when just approaching the correct intersection, and not starting to warn when approaching the set of lights before it.
I wonder if there is a distance setting for this.
Old 05-06-2015, 08:13 AM   #18
Agent 86
Drives: 2017 Cayman S
This explains a lot. We have a 2013 Outback, and 2014 BRZ. I have explored the Navigation menus of both and thought I set up alerts for traffic cameras etc., but it never provided any alerts.
Database. Duh, makes sense.
BTW, can I use the file for both cars or do I need to purchase one for each car?
Also, if I remember correctly, you can adjust the distance to notification within the Navigation menu.
… and loving it! Maxwell Smart
Gone but not forgotten
2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT
Agent 86 is offline   Reply With Quote
Old 05-06-2015, 11:09 AM   #19
MalcolmHimself
Drives: 2015 BRZ
Hmm, I might do this after school, work, and play today.
You do need the nav screen up for the alerts, right?
Old 05-07-2015, 07:47 AM   #20
krayzie
Drive From Home
krayzie's Avatar
You can use the same database file for both units as it's basically just a text file with a bunch of coordinates.
I tried adjusting the distance for general warnings down to 50m but it made no difference.
I hope it doesn't freak my mechanic out when he test drives my car tomorrow lol!
Old 05-14-2015, 10:21 AM   #21
Aviato
Aviato's Avatar
Drives: 2015 BRZ, 2001 Toyota 4runner-Sold
Would this void the warranty if Subaru found out? Or is that not really possible?
Aviato is offline   Reply With Quote
Old 05-14-2015, 12:24 PM   #22
extrashaky
Drives: 2014 BRZ Limited
It can't void the warranty. Subaru could refuse to warranty the head unit if they could show that your installation of the database caused something to fail. That's extremely unlikely, especially considering that the head unit is made for this functionality. Even if I somehow bricked the HU while installing this (also unlikely), I would still expect them to honor the warranty on it because the HU is made to accept such a database.
Old 05-14-2015, 12:37 PM   #23
Not to mention of the unit is truly bricked, they aren't going to know what caused said bricking....
In the end though the database is updateable through a function/feature of the device. If that feature fails, then the device should be covered I would think.
Old 05-15-2015, 10:01 PM   #24
Eski
Eski's Avatar
Drives: '15 Brz Series Blue
so i did everything right, and i looked around my gps at some areas in my town where i know speed cameras are and i cant seem to find anything on my map. i even pulled out my sd card and put it back in my pc to verify everything worked correctly and i turned on all the warnings. anyone had any issues like this?
edit: i havnt actually road tested yet, still at work but will see what happens when i pass them on the way home. if it fixes i will post but please let me know if anyone has had any issues with this
"Listen, smile, agree and then do whatever the fuck you were going to do anyway." -Robert Downey Jr.
Eski is offline   Reply With Quote
Old 05-15-2015, 10:15 PM   #25
ryoma
ryoma's Avatar
http://www.scdb.info/en/karte/
look up your city and see if it's on the map. if it's not on the map, then they haven't updated it. I'm pretty sure you can manually add it in if you have the coordinates via the .txt file.
Old 05-15-2015, 10:27 PM   #26
Eski
Eski's Avatar
wow lol my city is on there but there are no camera's on the map so i guess they havnt updated it yet?
a little disappointed now, granted its only 12$ but i wanted the features to work around my own town and surrounding areas.
Old 05-15-2015, 10:51 PM   #27
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Have you turned on the alerts for the speed cameras?
Old 05-15-2015, 11:09 PM   #28
ryoma
ryoma's Avatar
check the database file you downloaded and see if you can insert the coordinates of the speed cameras for your city, if you know them (or go to google maps and see if you can get coordinates that way).
oem headunit, red light camera, scdb.info, speed camera, speedcam database
Besides Torque, what apps do you guys have on your Android headunits? Ruckus Electronics | Audio | NAV | Infotainment 7 09-30-2015 01:33 AM
DIY: gaming setups on OEM headunits lbroskee DIY (Do-It-Yourself) Guides 46 12-10-2014 12:11 AM
aftermarket rear view mirror camera uninstall/install shop 1slowfrs Southern California 2 10-28-2014 03:33 PM
stock brz jdm rear view camera SuperDave Electronics | Audio | NAV | Infotainment 0 04-03-2014 10:53 AM
Any headunits the same dimesions as stock? Hanakuso Electronics | Audio | NAV | Infotainment 25 07-20-2013 10:03 AM
