#57 | |
| The Following User Says Thank You to CSG David For This Useful Post: | dave- (05-06-2015) |
#58 |
Small update. Winmax W7 is no longer available for order in the United States. Thank you for your understanding!
#59 |
Drives: WRB JR BRZED
How many track days can one except from the W6's?
#60 |
#61 |
#62 |
This is when I replaced my W5's. Is that about Right or did I go too far or not far enough?
#63 | |
You can run pads to the backing, but you run the risk of the backing plate touching your rotors and scoring them. Also, as pads wear thinner, there's less heat sink mass, and they get hotter, and end up wearing faster. You could always throw these in your track bag, and just keep em as backups. |
#64 | |
#65 | |
![]() The risk is not "wearing out" the fluid, but rather heating it up enough that it degrades, and possibly boils. |
#66 |
Drives: Subaru BRZ
I'm using hp+ now but looking for a step up. How would the w4 compare to dtc30? Thanks
| DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 05:17 PM |
| Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! | Mike@CZP | Brakes, Suspension, Chassis | 348 | 06-01-2018 12:29 PM |
| CounterSpace Garage - Winmax USA Brake Pads Group Buy - EXTENDED!! | CounterSpace Garage | Groupbuys | 21 | 01-28-2015 06:48 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
