Old 05-06-2015, 02:04 PM   #57
CSG David
CSG David's Avatar
Originally Posted by dave- View Post
Thread revival...
Have run DS2500's for years and been very happy with them but there is one particular track I goto which has started pushing their limits with R compound tyres. In this case, there is a long straight where 120mph becomes about 55mph so after 5 laps the front pads are smoking. Every other track I do doesn't have as much of a variance so the pads have never been an issue even with the tyres.
I like that they're suitable for daily duties, minimal dust, don't abuse rotors and good pedal feel but still manage consistent performance on the track (except this one place lol). Is there a Winmax pad (or anything else for that matter) worth trying which matches those characteristics but can take a bit more heat abuse? Can drop the daily duties but want to keep the other stuff as swapping pads before a track day isn't a big issue. Though always thought switching compounds on the same rotors was a no no?
Current BBK uses FRP3077 front and FRP219 rear though I'd prefer not to replace the rears as they're only half used.
@CSG David
I will send you a PM regarding this inquiry. DS2500 is a hybrid compound and we wouldn't normally consider this a good track pad for heavy use, however you are using a FRP3077 pad shape so it's a big pad.
The Following User Says Thank You to CSG David For This Useful Post:
dave- (05-06-2015)
Old 05-06-2015, 05:31 PM   #58
CSG David
CSG David's Avatar
Small update. Winmax W7 is no longer available for order in the United States. Thank you for your understanding!
Old 05-12-2015, 08:16 PM   #59
enivid
enivid's Avatar
Drives: WRB JR BRZED
How many track days can one except from the W6's?
enivid is offline   Reply With Quote
Old 05-12-2015, 08:26 PM   #60
swarb
seriously hard to gauge as we don't know how long, how hard, how fast, how good, how bad, how much, how often, etc, etc...
I'm going to shoot in the dark and say 3-5 days.
Old 05-12-2015, 08:56 PM   #61
CSG Mike
CSG Mike's Avatar
That totally depends on you, but if you're getting 4 days or less out of a set of W6, you should seriously consider a BBK for cost reduction purposes.
Old 05-12-2015, 08:58 PM   #62
enivid
enivid's Avatar
This is when I replaced my W5's. Is that about Right or did I go too far or not far enough?
Old 05-12-2015, 09:05 PM   #63
CSG Mike
CSG Mike's Avatar
This is when I replaced my W5's. Is that about Right or did I go too far or not far enough? Attachment 109419
You still have a solid 3mm of pad on the two middle pads. Keep using em!
You can run pads to the backing, but you run the risk of the backing plate touching your rotors and scoring them. Also, as pads wear thinner, there's less heat sink mass, and they get hotter, and end up wearing faster.
You could always throw these in your track bag, and just keep em as backups.
Old 05-12-2015, 09:24 PM   #64
enivid
enivid's Avatar
Ok, I thought you were supposed to swap them out when the pad thickness equaled the thickness of the backing plate. Do I risk wearing out my brake fluid faster when they run that low?
Old 05-12-2015, 10:35 PM   #65
CSG Mike
CSG Mike's Avatar
Yes, but brake fluid is cheaper than race pads....
The risk is not "wearing out" the fluid, but rather heating it up enough that it degrades, and possibly boils.
Old 07-04-2016, 09:59 AM   #66
n0thing
Drives: Subaru BRZ
I'm using hp+ now but looking for a step up. How would the w4 compare to dtc30? Thanks
n0thing is offline   Reply With Quote
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
CounterSpace Garage - Winmax USA Brake Pads Group Buy - EXTENDED!! CounterSpace Garage Groupbuys 21 01-28-2015 06:48 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
