Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 05-11-2015, 10:58 AM   #15
nelsmar
Originally Posted by sav View Post
Interesting, thanks - will try using the same filter to log and see what's what. Might be a good idea to use a clean filter anyway for logging. Another problem here is that pretty much everybody are running different drop in filters which also throws a spanner into the works.
I don't think we've got ethanol in our fuel yet.
http://ethanolproducer.com/articles/...arting-in-2015
It looks like by October you should start seeing it. You'll typically see a little more LTFT at idle with the stock MAF calibration. 6-9% LTFT. If you tune the maf to 0% remember your shifting your engine load and thus shifting the ignition advance. As the fuel in my area averages E7 fairly consistently I actually use a basemap with a flex fuel map hard coded to 7% ethanol as my starting point.
My flickr - Canibeat
Local magazine scout
The Following 3 Users Say Thank You to nelsmar For This Useful Post:
GeeTee86 (05-12-2015), JouMaSeHoes (05-12-2015), sav (05-11-2015)
Old 05-13-2015, 05:38 AM   #16
steve99
Drives: FT86
PI/DI ratios idle stability and knock
@sav
you might try a couple of these tweaks to pi/di ratios
alter all three tables
cold/warm/hot the same
zero out the PI up to 0.2 load this is idle for manual, makes it idle smoother and you can drop your idle back to 700 or even 650 rpm.
doing that also stopped the idle dips when air conditioner kicks in as well.
On an auto zero out to 0.3 load as it idle at more load due torque converter
you might also try altering the rpm axis where is 5200 to 6000 so it runs full DI up to 6000 or even try 6500 as DI generally more knock resistant
seethe linked info below from moto mike about max pulse widths ect.
on E85 we are actually holding full DI to 7000 rpm.
I have also altered the values in the 2400 and 2800 rows to max of 25%
you might be able to put back a bit more ignition advance doing that.
more info here
http://www.ft86club.com/forums/showp...2&postcount=17
The Following 2 Users Say Thank You to steve99 For This Useful Post:
GeeTee86 (05-19-2015), sav (05-13-2015)
Old 05-13-2015, 06:07 AM   #17
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Thanks Steve, will give it a try and report back.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 05-19-2015, 07:42 AM   #18
Scarl3t
Scarl3t's Avatar
Drives: Hachi-Roku
Hi Guys,
are you guys doing the same map work as @Damon was doing with Phoenix ?
if so can i get in on this action????
Scarl3t is offline   Reply With Quote
Old 05-19-2015, 07:52 AM   #19
sav
sav's Avatar
Hi
Not sure what they're doing exactly but we've been working with @steve99 and we don't charge money for our maps.
Busy testing the direct injection tweaks with the 95 EL maps, will be ready soon, or we can load the "v1" map if you want.
We also don't have a "one size fits all" approach either so it involves loading the map then you need to do some miles to let the fuel trims settle, then we need to do some 3rd gear pulls for custom MAF scaling and then log some more later to confirm that all is running 100%.
What mods, filter, etc have you got?
95RON SAV Tuned
The Following User Says Thank You to sav For This Useful Post:
Vic_RSA (05-19-2015)
Old 05-19-2015, 08:33 AM   #20
Scarl3t
Scarl3t's Avatar
Drives: Hachi-Roku
Hi SAV,
all stock... eish
Old 05-19-2015, 08:42 AM   #21
sav
sav's Avatar
Cool, that makes it easier.
95RON SAV Tuned
Old 05-19-2015, 09:19 AM   #22
Scarl3t
Scarl3t's Avatar
Drives: Hachi-Roku
Hi
They mos did the launch control and flat foot shifting, as well as minimal torque dip
Old 05-19-2015, 09:21 AM   #23
Scarl3t
Scarl3t's Avatar
Drives: Hachi-Roku
Nice, i'm based in Centurion.
Old 05-19-2015, 09:23 AM   #24
sav
sav's Avatar
Yep, we've got launch control and flat foot shifting as well. As for the torque dip - check their graphs.
The graph in the first post is with Borla UEL headers.
95RON SAV Tuned
Old 05-19-2015, 09:23 AM   #25
sav
sav's Avatar
Great, me too. Will let you know as soon as I've finished testing.
95RON SAV Tuned
Scarl3t (05-19-2015)
Old 05-19-2015, 09:44 AM   #26
Scarl3t
Scarl3t's Avatar
Drives: Hachi-Roku
Hats of to you guys!!!!
The Following 2 Users Say Thank You to Scarl3t For This Useful Post:
GeeTee86 (05-19-2015), sav (05-19-2015)
Old 05-24-2015, 02:23 PM   #27
MacJunkie
MacJunkie's Avatar
Drives: Toyota 86 STD
WOW, can't believe I missed this well done guys and were do I sign up👍
MacJunkie is offline   Reply With Quote
Old 05-24-2015, 04:19 PM   #28
sav
sav's Avatar
Thanks, where are you based?
95RON SAV Tuned
Torque Pro App poorsche Engine, Exhaust, Transmission 4 12-12-2014 06:01 AM
The Torque Dip. Ozzman Engine, Exhaust, Transmission 25 09-06-2013 03:32 PM
500 hp & 550 lb/ft torque ? yes please LS13 Scion FR-S / Toyota 86 GT86 General Forum 3 06-17-2013 01:48 PM
What torque dip? pdreams Engine, Exhaust, Transmission 44 11-12-2012 07:56 PM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 01:22 AM
