#15 | |
It looks like by October you should start seeing it. You'll typically see a little more LTFT at idle with the stock MAF calibration. 6-9% LTFT. If you tune the maf to 0% remember your shifting your engine load and thus shifting the ignition advance. As the fuel in my area averages E7 fairly consistently I actually use a basemap with a flex fuel map hard coded to 7% ethanol as my starting point.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| The Following 3 Users Say Thank You to nelsmar For This Useful Post: |
#16 |
Drives: FT86
PI/DI ratios idle stability and knock
@sav
you might try a couple of these tweaks to pi/di ratios alter all three tables cold/warm/hot the same zero out the PI up to 0.2 load this is idle for manual, makes it idle smoother and you can drop your idle back to 700 or even 650 rpm. doing that also stopped the idle dips when air conditioner kicks in as well. On an auto zero out to 0.3 load as it idle at more load due torque converter you might also try altering the rpm axis where is 5200 to 6000 so it runs full DI up to 6000 or even try 6500 as DI generally more knock resistant seethe linked info below from moto mike about max pulse widths ect. on E85 we are actually holding full DI to 7000 rpm. I have also altered the values in the 2400 and 2800 rows to max of 25% you might be able to put back a bit more ignition advance doing that. more info here http://www.ft86club.com/forums/showp...2&postcount=17 |
#17 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
Thanks Steve, will give it a try and report back.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#19 |
Hi
Not sure what they're doing exactly but we've been working with @steve99 and we don't charge money for our maps. Busy testing the direct injection tweaks with the 95 EL maps, will be ready soon, or we can load the "v1" map if you want. We also don't have a "one size fits all" approach either so it involves loading the map then you need to do some miles to let the fuel trims settle, then we need to do some 3rd gear pulls for custom MAF scaling and then log some more later to confirm that all is running 100%. What mods, filter, etc have you got?
95RON SAV Tuned |
| The Following User Says Thank You to sav For This Useful Post: | Vic_RSA (05-19-2015) |
#20 |
Drives: Hachi-Roku
Hi SAV,
all stock... eish |
#21 |
Cool, that makes it easier.
95RON SAV Tuned |
#22 | |
Drives: Hachi-Roku
#23 |
Drives: Hachi-Roku
#24 | |
Yep, we've got launch control and flat foot shifting as well. As for the torque dip - check their graphs. ![]() The graph in the first post is with Borla UEL headers.
95RON SAV Tuned |
#25 |
Great, me too. Will let you know as soon as I've finished testing.
95RON SAV Tuned |
| The Following User Says Thank You to sav For This Useful Post: | Scarl3t (05-19-2015) |
#26 |
Drives: Hachi-Roku
#27 |
Drives: Toyota 86 STD
WOW, can't believe I missed this well done guys and were do I sign up👍
#28 | |
Thanks, where are you based?
95RON SAV Tuned |
| Torque Pro App | poorsche | Engine, Exhaust, Transmission | 4 | 12-12-2014 05:01 AM |
| The Torque Dip. | Ozzman | Engine, Exhaust, Transmission | 25 | 09-06-2013 02:32 PM |
| 500 hp & 550 lb/ft torque ? yes please | LS13 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-17-2013 12:48 PM |
| What torque dip? | pdreams | Engine, Exhaust, Transmission | 44 | 11-12-2012 06:56 PM |
| Torque App | ZetaVI | Other Vehicles & General Automotive Discussions | 4 | 12-02-2011 12:22 AM |
