Old 05-08-2015, 04:26 PM   #29
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
OP windowed his block. No need to worry about his cams any longer.
Old 05-09-2015, 01:24 AM   #30
Dipstik-sportech
Dipstik-sportech's Avatar
Ahahahhaha hahahhahaa Crawford strikes again!!!!!
Old 05-09-2015, 04:42 AM   #31
2ndgenhachi
Drives: 2013 fr-s, sr20 180sx
DAMN! didn't he also window the stock block!? looks like it's time to call FBM! Idk what options op has but hopefully some sort of compensation will be given.
2ndgenhachi is offline   Reply With Quote
Old 05-09-2015, 12:18 PM   #32
sw20kosh
Drives: 2013 Black FR-S
Why did OP go with Crawford? NO one on this forum recommends Crawford...
Old 05-09-2015, 02:00 PM   #33
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
My Crawford block didn't blow up. That was a stock block with a bad tune.
texasbound972 is offline   Reply With Quote
Old 05-09-2015, 04:05 PM   #34
Astroboy
Astroboy's Avatar
Drives: None
Honestly, Who tuned it
Astroboy is offline   Reply With Quote
Old 05-09-2015, 04:20 PM   #35
2much
I wanna go fast
Drives: 2013 FR-S 6MT
<3 @texasbound972 this sucks dude, all jokes aside about the builder, tuning, etc. it sucks to drop money like that and it doesnt work. Hope you get this figured out soon!
2much is offline   Reply With Quote
Old 05-09-2015, 04:29 PM   #36
texasbound972
USMC
Delicious tuned it. Same tuner still with no issues besides the low oil pressure below 1100 rpm. So my idle is set at 1100 rpm so the oil pressure is high enough for the cams to work properly.
Old 05-09-2015, 04:30 PM   #37
texasbound972
USMC
Here is the latest dyno from 4 March. Remember this is on a mustang dyno, so for a dyno jet or similar dyno numbers multiply these numbers by 17%
Old 05-09-2015, 05:07 PM   #38
Dipstik-sportech
I assume you're on e85
Old 05-09-2015, 09:09 PM   #39
texasbound972
USMC
Yes
Old 05-09-2015, 10:02 PM   #40
steve99
Drives: FT86
What was sequence of events
Cam issues , low oil pressure
followed by oil in coolant
then window in block
From what i remember cams not working correctly can be due to fault in cam actuator that bleeds off oil pressure hence cams dont work correctly and rest of engine get low oil pressure generally causing failure, their may not be any cel codes registered somtimes their is sometimes not. But eny cam issues best get it sorted asap
http://www.ft86club.com/forums/showp...postcount=2970
should look like this
http://www.ft86club.com/forums/showp...postcount=2973
Old 05-10-2015, 09:05 AM   #41
wparsons
wparsons's Avatar
17% is a huge correction factor, that's about the same as the drivetrain losses.
As for the dyno, did you miss my questions above?
What's the boost target before/after the new block? What's the new C/R?
What oil are you running on the new block?
To get the same hp with significantly lower C/R, you're going to need a lot more boost, and it'll spool later in the RPM range.
flickr
Old 05-10-2015, 01:18 PM   #42
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Im surprised no one else guessed AVCS failure first. Way to go steve.
Cams Fabron757 Forced Induction 10 01-13-2015 06:30 PM
HKS cams JesseTheFlash Engine, Exhaust, Transmission 4 01-09-2015 07:42 PM
Wtb oem cams midnight23 Want-To-Buy Requests 0 03-19-2014 12:07 PM
Cams? Sonolin Engine, Exhaust, Transmission 10 05-21-2013 10:49 PM
Cams Surok Engine, Exhaust, Transmission 10 01-01-2013 08:30 PM
