| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 |
Drives: 2013 BRZ Premium Black
In my opinion, the twins clutch is one of the best I've driven on. My friends 2012 STI feels squishy and my old 6 puck sentra se-r was a nightmare lol
#30 |
Drives: 2015 Dark Gray Metallic BRZ
My last car (till 2 weeks ago) was a 1998 neon RT. Bought it new. It had a cable operated clutch and I loved it. Drove it for 280k miles and its still going strong. My new 2015 dark gray metallic clutch has me feeling like I just started learning clutch again. I swear I have almost stalled it off the line a bunch of times. I think the lack of torque down low has more to do with that than the clutch, but it really is vague. I haven't tried removing the spring yet as I only have like 400 miles on the car. I figure I will give it a chance, then ditch it. My neon's clutch was easily this light, but had perfect feel.
Anyway, My .02 |
#31 |
Drives: 14' BRZ
I've been driving nothing but manuals for 12 years now. Started on an 01 Escort Zx2. The clutch feel and shifter felt very similar to this car, except the clutch had more feel in the Zx2. Moved on to an 03 Jetta 1.8t Manual. Decent shifter, kind of dull all the way around, longer clutch, but much smoother and better feel than the twins. 11 Jetta 2.5SE after that, Great shifter and clutch, again shifter is longer throw, but very smooth, solid shifts, the clutch felt like a compound bow. It was odd to get used to at first, but I wound up loving it shortly there after, you knew where the friction point was and when it was coming up based on the clutch pushed harder, but when you just wanted the clutch in at a light it was very easy at the bottom. A lot of feel all the way around to be honest. Very easy car to learn to drive manual in, taught a slew of friends by just giving them the keys and explaining the jist of it all. Now I have the 14 BRZ. Clutch is much shorter with a steady pressure through out, engagement is completely dull, feels the same on friction as it does not making contact. Shifter is great, although very notchy at points, I'm assuming I'm still running Subaru recommended fluid in there, a switch to a different fluid like many have suggested will clear that up. At the end of the day I got used to the clutch quickly in the car, if it's anything, it's extremely consistent.
#32 |
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Cables will always feel more vague compared with direct mechanical linkage. As for which is normal - both - though more cars probably use cables these days.
#33 | |
#34 | |
Drives: Toyota Highlander; Subaru BRZ (SWP)
I can be barely touching the gas pedal (to point where I dont even feel it though my shoe yet) and its enough to get the car moving. If you're willing to visit the torrance area, I may let you test out how it feels. |
#35 | |
The real culprit is the long engagement arc. Most of us unconsciously blip the throttle and let the clutch engage during spool-down. This thing is awful for that because by the time you think/feel the clutchshould be engaged, you're only halfway there. I cussed at it for a month or so, either stalling it or smoking the clutch. Here's how to change the gearing to shorten that engagement arc. It transforms the whole experience. BTW, @Koa, @Decay107 let me drive his after he installed the Perrin engine mounts. Oh, man! Rubber banding eliminated! Only drove around a parking lot in first gear trying to induce it but it was gone! Am I dreaming?
#36 |
Drives: 2013 brz limited
haha im driving 桑塔纳 to learn manual , too
#37 | |
As for the engine mounts- No sir! It's amazing, innit? I have been out of my FRS for... going on 2 months as of the 21st. Really ticked off that its' taking this long to repair my rear-end accident. Fuck Everett and their uninsured drivers plowing into you, pushing your baby onto the sidewalk and fucking up the whole undercarriage. I'm really salty about it, and admittedly it's why I've been gone. Just looking at this forum makes me miss my baby so much.. :' I'm going to make a thread about my journey and specifically what Racer-X Fabrication has done to help me along this process.. It's pretty amazing what they did and I don't wanna spoil it before releasing the whole story
#38 | |
#39 |
I haven't tried to figure out what he did yet. I'm still trying to get the chance to drive someone else's manual BRZ so I can compare. I plan to find some way to stop the bogging once summer hits.
#40 | |
Drives: Splash Mountain
#41 |
Totally personal preference. It's good to learn how to shift without the clutch so one doesn't need to rely on it. The trick is in stopping. Coast to a stop and shut off the engine. When you're ready to go, stick it in first and start the engine. Still need to push the clutch pedal for the starter interlock but the car will start and go just fine.
#42 |
I'm pretty sure for newer cars like ours, you don't have to worry about catastrophic clutch failure out of no where. maybe for cars that are 10+ years old, but IMO it's an unfounded worry unless you constantly abuse the crap out of the car. even if the clutch does go bad, there will be signs like the TOB squeaking or the pedal feeling different. and if the clutch does blow up, well, adjusting your pedal wouldn't help with that haha
EDIT: I read a few posts wrong, but still, newer cars like ours shouldn't have any problems with the clutch master cylinder that would warrant any worries.
| Driving stick: A short(ish) guide | boogle | BRZ First-Gen (2012+) — General Topics | 24 | 11-20-2014 12:31 AM |
| To those who learnt auto driving before stick | sci3 | Scion FR-S / Toyota 86 GT86 General Forum | 64 | 08-16-2014 10:30 PM |
| Commuters driving stick | rawrmatty | Scion FR-S / Toyota 86 GT86 General Forum | 142 | 02-24-2014 03:00 PM |
| Stick shift school in Houston? | nitewolfgtr | Southwest | 6 | 09-07-2013 01:32 PM |
| AutoGuide.com: Parents Push Teens To Drive Stick to Avoid Distracted Driving | poormans_LFA | Other Vehicles & General Automotive Discussions | 15 | 01-25-2012 10:02 AM |
