Old 05-04-2015, 01:33 AM   #1
ButteR
Drives: 2015 Scion FR-S
Stuck - Koni Shocks & TRD Spring install issue
Disclaimer - I've never installed my own coilovers and or springs/struts/shocks etc. First attempt here! Help would be greatly appreciated as this is my daily driver and I work 8:30 - 6 pm monday thru fridays and currently have no car (tomorrows gonna be "one of those mondays")
I attempted to install my koni shocks and TRD springs and I hit a dead end. I haven't touched the rears yet.
I began with the fronts - successfully removed the front struts & springs and then I started putting in the koni's & TRD. As you can see in the pics below, once I hooked everything up, I was about to put on the wheels and I realized that the struts are still moving freely...If I put the wheel on, the weight of the wheel just pulls entire strut down...clearly I've missed something lol.
Here's the video I used as a guide for installing in addition to the instructions that came with the shocks and springs (the koni shock instructions are pretty useless for newbies like me).
[ame="https://www.youtube.com/watch?v=4C-ZUGi4R-Q&app=desktop"]Installation Video I used[/ame]
How come the strut doesn't go through the hole above it into the engine bay? I used a jack to lift the strut up, which compressed the springs and sent the top of the strut into the engine bay...i figured that was a step in the right direction, but, how do I get the spring to stay compressed???
ButteR is offline   Reply With Quote
Old 05-04-2015, 01:40 AM   #2
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Um...did you take the nut and washer off the piston shaft before you tried pushing it through? Once you have the piston shaft threading through the mount the washer and nut would secure it on the top side...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 05-04-2015, 02:12 AM   #3
ka-t_240
Post a picture of the top of your Koni's. There is likely a nut holding the black piece on, you will need to compress the springs and remove that nut. You will then need to fully assemble the tophat/mount, spring and strut together using a nut/washer that threads onto the top of the koni strut.
ka-t_240 is offline   Reply With Quote
Old 05-04-2015, 07:52 AM   #4
scirocco78
Drives: Scion FRS
You missed from 4:00-4:10 minutes of your video.
scirocco78 is offline   Reply With Quote
Old 05-04-2015, 07:25 PM   #5
duke_FRS
duke_FRS's Avatar
Drives: 2015 FRS Hot Lava 2014 CT200H
1. Unbolt the sway bar from the strut
2. Take the top hat off the car
3. Bolt it on the strut
4. Mount the strut back to the top.
5. Bolt the sway bar back to the strut.
Open Flash Tablet Stage 1 93 | Borla Cat-Back | VOSSEN VFS1 | Eibach Sportline
duke_FRS is offline   Reply With Quote
Old 05-04-2015, 08:19 PM   #6
vroom4
Ugh, I'm sorry but you need someone to look everythig over before you drive your car. No way I'd feel safe driving in that after this question
vroom4 is offline   Reply With Quote
The Following User Says Thank You to vroom4 For This Useful Post:
chaoskaze (05-04-2015)
Old 05-04-2015, 10:17 PM   #7
gtslow
Drives: 2015 Halo FR-S
Your strut housings should be full reassembled before you put them back on the car.
gtslow is offline   Reply With Quote
Old 05-04-2015, 10:31 PM   #8
TRD-X
TRD-X's Avatar
Drives: Da-Big Banana
Installed right OP.
Old 05-04-2015, 11:26 PM   #9
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
OP..........find a friend that KNOW wut he is doing.
Old 05-05-2015, 01:09 AM   #10
ButteR
Yeah I got the front end figured out. I'm waiting on assistance with someone who has experience before I attempt to touch the rears. Thanks for the help guys, much appreciated.
The Following User Says Thank You to ButteR For This Useful Post:
MJones_RB (05-07-2015)
MTEC shifter spring install issue jamesm Engine, Exhaust, Transmission 36 12-06-2015 10:36 AM
Koni shocks damping setup Brzerker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-07-2015 12:48 PM
Koni Rear Ride Height Too High; Install Issue rene0023 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-06-2014 06:01 PM
Koni Install Issue WolfSongX Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 07-22-2013 10:17 PM
Need help fast - suspension issue during spring install finch1750 Scion FR-S / Toyota 86 GT86 General Forum 5 07-08-2013 04:30 PM
