Old 04-02-2015, 11:35 PM   #29
KNS
Drives: BMW and Porsche at the moment
Ask if you can trade with one of the other "normal" cars on the lot. They're all the same after all.
KNS is offline   Reply With Quote
Old 05-04-2015, 11:26 AM   #30
Sugi
Sugi's Avatar
Drives: 2015 FR-S - Halo
Originally Posted by Jpzeb
Do you have any further updates? I am currently in mediation because my dealer won't fix it. I also have a rear view mirror distortion that is very distracting and a shudder when I take off at cold start. Mine is the automatic version. Any help would be appreciated. I go see the mediator today.
Thanks,
Jeremy
As of right now, No. Toyota has deemed the issue to be normal and will NOT do ANYTHING to attempt to solve the issue. I had the dealer advise me that it was NOT normal, the dealer had a field tech advise them that it was NOT normal, but Toyota will not listen. As of right now, I'm just dealing with the motor idle issue. I plan to flash my ECU when I mod my vehicle more to see if that resolves the issue. I too have an automatic and am not sure if anyone with a manual is experiencing this issue?
Sugi is offline   Reply With Quote
Old 05-04-2015, 11:35 AM   #31
ramiram1984
Drives: 2016 STi DGM
Originally Posted by Poodles View Post
I'll answer you both at the same time. Because of the way the ballast works, it can create a lot of EMF interference that can mess with all kinds of things. It can also cause feedback though the electrical system.
This is why it's important to use a reputable vendor and not Ebay or DDM (the masters of cheap HID crap)
That's why I don't even mess with hid aftermarket lights etc etc of any kind
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 05-04-2015, 01:00 PM   #32
Sugi
Sugi's Avatar
Toyota had my vehicle for a week and removed the HID system ruling out that the issue is being caused by something different. The HID system is not the issue.
Car Dies at 170 Miles Check Engine Limp etc CASE CLOSED learnerspermit Issues | Warranty | Recalls / TSB 38 11-06-2013 02:51 PM
Noise when idle (not Crickets) hanabie Issues | Warranty | Recalls / TSB 8 10-18-2013 08:58 PM
Engine noise besides crickets bruizerrob Engine, Exhaust, Transmission 3 10-15-2013 10:29 AM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 06:39 PM
Just changed oil...crickets got but new pulley noise sa1126 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 09-30-2012 05:45 PM
