Old 09-10-2013, 02:09 AM   #1
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Noise when idle (not Crickets)
Sorry I hate to search. I don't think that is crickets. The noise only activates when the engine runs below 1k rpm during idle.
It sounds like rattling. As soon as I press gas pedal, it stops. It comes back again when the engine hits below 1k rpm.
Thanks
hanabie is offline   Reply With Quote
Old 09-11-2013, 01:26 PM   #2
hanabie
hanabie's Avatar
Is this normal? It seems I get no answer. It is pretty rough at idling. Thanks. I have no other car to compare with
Old 09-11-2013, 01:36 PM   #3
TheseColorsDontRun
Keep calm and drive on
TheseColorsDontRun's Avatar
Drives: 2013 WRB BRZ Limited 6M
Maybe take it in to the dealership?
TheseColorsDontRun is offline   Reply With Quote
Old 09-11-2013, 02:07 PM   #4
strat61caster
strat61caster's Avatar
The car is noisy and can be described in many ways, mechanical clicking/ticking is a common phrase used which could be similar to 'rattling' unless you post a video it sounds normal to most people around here based solely on your description.
ineedyourdiddly
Old 09-11-2013, 02:17 PM   #5
Hope10Series
#150 FR-S
Hope10Series's Avatar
Drives: FR-S 10 Series #150
Is it a humming noise like a fuel/air pump but from the back and goes away ASAP ramp goes above 1k and only there under idle? Mine just started day before yesterday... Car only has 800km
Hope10Series is offline   Reply With Quote
Old 09-16-2013, 01:43 PM   #6
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
If it's a "diesel" sound or sounds like marbles in the engine at low RPM it is probably the HPFP. It is a noisy little thing
I figure as long as you smile while driving the car, you're doing it right.
SillySaxon is offline   Reply With Quote
Old 10-09-2013, 06:25 PM   #7
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I have this sound as well along with crickets. Two separate noises
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 10-09-2013, 11:29 PM   #8
Tromatic
Oddly enough, you would not even have to search to find an answer.
Tromatic is offline   Reply With Quote
Old 10-18-2013, 08:58 PM   #9
SubieNubie
SubieNubie's Avatar
I've just started hearing a noise that maybe similar to this. It seems like a lower tone but louder version of the crickets and is more audible inside the car. It's not as prevalent out side of the car. Are you having the same issue?
Daily Driven 2013 6MT Subaru BRZ Premium in WRB
SubieNubie is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Engine idle chirping (cricket) noise poll. Hanzo BRZ First-Gen (2012+) — General Topics 229 02-16-2016 01:21 PM
Reported idle-drop and crickets - got turned away empower-auto Issues | Warranty | Recalls / TSB 11 10-21-2012 11:36 AM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 06:39 PM
Just changed oil...crickets got but new pulley noise sa1126 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 09-30-2012 05:45 PM
