Old 02-28-2015, 01:21 PM   #1
Sugi
Sugi's Avatar
Drives: 2015 FR-S - Halo
Question Engine noise (not crickets) and almost dies out when stopping
Hey guys,
So a few weeks back my car was making a weird noise in the engine bay. Didn’t think anything of it at first because I remember reading about the “cricket noise” issue with the fuel pumps, so I went on continuing to drive my car. I started to get concerned when I could hear the “cricket noise” and also hear the other noise. The noise sounded like a clicking sound coming from the motor. It started to get worse and my car almost idled out and dies when I come to a stop. I took it to Tracy, CA Toyota and had the service dept. take a look at it. Of course it would not perform the issues while at the dealership and they claimed that what I was describing was normal and blamed the cause on the fuel pump. Because I own a 2015 with the latest and greatest, the service tech stated that there was no need to do anything. I left the dealership and it still continued to perform what I described above.
I was convinced that there was more to this so I took it back to the dealer. I opened my hood and started to explain the issue again. Right in the middle of my explanation, the car performed the noise and almost died out. It was late in the day so the service dept. asked that I bring it back so they could spend a day on it. I took it in last Tuesday. The issue happened on Tuesday they stated and wanted to run further tests. Tuesday became Wednesday, Wednesday to Thursday and Thursday to Friday. The service rep calls me stating that they noticed I had an aftermarket HID kit on the car and blamed the issue on that. I flipped!!! She was stating that if they prove that the vehicles behavior was due to the HID kit that I would be charged for EVERYTHING. Keep in mind that I purchased the car in Nov. and it only has 3000 miles. I don’t want to get into the details of all the crap she was feeding me, but they disconnected the HID and the car was still performing the issues. Now they believe it has something to do with the vacuum system and I still don’t have my car.
Any ideas on what this could be???
Sugi is offline   Reply With Quote
Old 02-28-2015, 01:37 PM   #2
Koa
wow.... seriously?
fuck that dealership
Old 02-28-2015, 01:45 PM   #3
Sugi
Sugi's Avatar
Originally Posted by Koa View Post
wow.... seriously?
Yea, tell me about it. I about had a heart attack at work. That's the second dealer I've had issues with. After this, I'm also going to cancel my extended warranty that I purchased.
Old 02-28-2015, 02:29 PM   #4
Poodles
Drives: 2015 Series.Blue
Keep in mind some cheap HID kits can cause serious issues, so I could agree with them there. Now the smart thing would have been to disconnect and confirm that before saying anything...
Old 02-28-2015, 04:17 PM   #5
Koa
What can cheap kits damage? JW
Old 02-28-2015, 05:33 PM   #6
Sugi
Sugi's Avatar
^Second? From my understanding, HID kits use only marginally the power necessary to charge compared to OEM and than use about half of what the OEM bulbs use to stay ignited. So if anything, they are better for the car. Correct me if I’m wrong.
http://www.caradvice.com.au/278125/h...v-led-v-laser/
Old 02-28-2015, 07:37 PM   #7
BRZnut
Drives: BRZ DGM Limited
typical...there have been several post of Toyota/Subaru dealers finding any reason they can not to do warrantee work. Ridiculous! Keep us updated on what they find! Good luck!
Old 02-28-2015, 08:47 PM   #8
Poodles
I'll answer you both at the same time. Because of the way the ballast works, it can create a lot of EMF interference that can mess with all kinds of things. It can also cause feedback though the electrical system.
This is why it's important to use a reputable vendor and not Ebay or DDM (the masters of cheap HID crap)
Old 02-28-2015, 10:23 PM   #9
Sugi
Sugi's Avatar
Ok so I just picked up my car. The issue was a vacuum line that was not on all the way. I got home and was hearing the "crickets" pretty bad, but I guess as long as my car is better.
Also, does anyone else experience thier idle dropping slightly when turning your headlights off manually at night? With or without HID.
Old 03-04-2015, 08:34 PM   #10
Sugi
Sugi's Avatar
The problem is back so what they did is not correct. It was not a vacuum line so I have to take the vehicle back to the dealership once again. Anyone else have any ideas?
Old 03-04-2015, 08:50 PM   #11
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Turning off shouldn't drop the idle. Turning it on might as it puts more load on the car but it's not a significant load.
N1rve
Old 03-04-2015, 09:41 PM   #12
Sugi
Sugi's Avatar
During the day when they are off, I'm experiencing the car almost dying out.
Old 03-05-2015, 12:40 AM   #13
N1rve
N1rve's Avatar
What RPM do you currently idle at?
N1rve
Old 03-05-2015, 01:02 AM   #14
Sugi
Sugi's Avatar
Around 700
Car Dies at 170 Miles Check Engine Limp etc CASE CLOSED learnerspermit Issues | Warranty | Recalls / TSB 38 11-06-2013 02:51 PM
Noise when idle (not Crickets) hanabie Issues | Warranty | Recalls / TSB 8 10-18-2013 08:58 PM
Engine noise besides crickets bruizerrob Engine, Exhaust, Transmission 3 10-15-2013 10:29 AM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 06:39 PM
Just changed oil...crickets got but new pulley noise sa1126 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 09-30-2012 05:45 PM
