#15 |
Sadly its a slippery slope with these cars
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | DAEMANO (05-03-2015) |
#16 |
Good tune, oil cooler, catch cans, and you'll be good to go.
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#17 | |
Drives: 2015 FRS RS1, 93 Supra
#18 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
Ive read from a lot of posters that an oil cooler could be bad for the car especially on colder days. That oil needs to get up to temp to be viscous enough. I warrant when you go FI you will need to think about the proper oil to use. I know people are going to poo poo on my oil cooler comment but I felt compelled to bring it up. Perhaps someone could chime in. I do believe that if you track the car an oil cooler is important. But I think that under normal DD circumstances an oil cooler may cause more complications than its worth.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#19 |
Drives: 2013 White FRS
I thought he said he was stationed in gitmo. And leaving his car in Cali. No reason he wouldn't have his frs in Irwin and pretty sure there are a few fi cars there in the area
SBD turbo. Delicious tuning flex fuel. Kate oil cooling kit. Spencer crash beam. Perrin 3" Exhaust. Motiv pipes. Wilwood Front Big Brakes. Greddy Cold Air Intake. Stance Coilover kit. Spyder v2 tails. Sparcos driver seat. Race Creations duck bill cf trunk. 91/e85 tuned by Eric @ elite performance. All other installs by Neal @ the racers line.
Coming soon: track time |
#20 | |
Custom User Title
Drives: Asphalt FR-S MT
| The Following User Says Thank You to boredom.is.me For This Useful Post: | DAEMANO (05-03-2015) |
#21 | |
Road-hole
Drives: 2013 Whiteout FR-S
I wasn't questioning the veracity of it...
I was there as part of the JTF with military intelligence and it's relatively rare, which is why I was asking... Jaden |
#22 | |
Drives: 2013 FR-S/C
There's no downsides to installing an oil cooler, especially with the thermostatic option. You also add almost a quart of oil capacity to your engine. And to the earlier comment, no you do not need a tune adjustment for an oil cooler. Beyond having to fix/seal the fittings on my Mishimoto, I'm very happy with its ability to keep my oil a good 20-30 degrees cooler
| The Following User Says Thank You to R3NIK For This Useful Post: | DAEMANO (05-04-2015) |
#23 |
Drives: Panda FR-S
I take what I said back. Needs an oil cooler for hot days. I installed Tomei UEL headers recently. In 100 degree weather, with 6 hard pulls on the highway, the coolant starts to boil. I never had this problem with stock header since it had the heat shield. I've ran hard in 100 degree weather with the stock headers many times without overheating. Maybe I should wrap the UEL headers.
So from my experience, if you are running with the stock headers on a non oil fed FI unit, there is enough shielding and cooling going on that you wont need any extra cooling system, but you are reaching the limit. I monitored this. When I would do hard pulls, I would see 246 F temps, which was the highest. Then I would drive normal and the temps would start to level out at 228-230 F within a minute. This was in 100 F weather. I drove like this for 50k miles. If your headers dump a lot of heat, they should be wrapped and get an oil cooler.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
#24 | |
Drives: 2013 Black FR-S
#25 |
Drives: 2014 Ultramarine Scion FRS AT
Nice input everybody.
Really excited to slap on the Vortech when I get off this rock. Probably will be going to Evasive Motorsports for the install.
#26 |
Junior
Drives: a car
If you take anyones advice, it better be CSG Mike's.
| The Following User Says Thank You to cdrazic93 For This Useful Post: | Adrian002 (06-19-2015) |
#27 |
Road-hole
I'd wait to see the numbers...
#28 |
Small penis big dreams
Drives: '13 Scion FR-S
Having the Vortech, you can bolt her up and go.
To get the most out of it you'll need injectors, fuel pump, and a CBE. If you want to step it up a notch you'll want the v2 with HD barrings and the 3.125 or 2.87 pulley. To get the most out of that you'll want a header back exhaust and E85. The vortech does not do ~much~ better with smaller pulleys on 93. However you will pick up much better throttle response.
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE 277hp 93 octane 370hp on E-85 |
| Supporting mods for higher rev limit? | radroach | Engine, Exhaust, Transmission | 6 | 12-01-2014 10:53 PM |
| FI, supporting mods and transmission question | BRZPDX | Forced Induction | 9 | 12-11-2013 01:22 PM |
| turbo kit supporting mods | lbroskee | Forced Induction | 13 | 03-30-2013 08:56 PM |
| Supporting Mods For F/I Applications | Tansey86 | Forced Induction | 59 | 02-26-2013 01:42 AM |
| Supporting Mods | Double4Free | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 02-21-2012 05:33 PM |
