Old 05-02-2015, 09:20 AM   #1
Adrian002
Adrian002's Avatar
Drives: 2014 Ultramarine Scion FRS AT
What supporting Mods do you REALLY need?
Alright I've done all kinds of reading about FI supporting mods on this forum but I feel like I don't have a real route to go with here.
I have an A/T FRS, looking to do a Vortech system set up and i'm aiming for a reliable daily driver with some pop since this car is really missing it.
I've read up on everything from oil coolers, catch cans, tranny coolers...but what do you REALLY need in order to commute to and from work, maybe some high revs on the weekends yknow nothing crazy guys.
There are a lot of cool and smart FRS owners on this forum that have seen it all when it comes to this car, so i'm looking for your opinion.
Adrian002 is offline   Reply With Quote
The Following User Says Thank You to Adrian002 For This Useful Post:
erbaker67 (05-03-2015)
Old 05-02-2015, 09:53 AM   #2
Cal3000
Drives: Panda FR-S
All you need is a bolt on kit and a good tune to be very basic.
Go for an oil cooler/larger radiator if you decide to track the car. A catch can or AOS may not be necessary since you wont be in constant boost. You may want to change your fuel pump as it would be running higher duty cycle but it isn't critical. Just dont drive around hard with a close to empty tank because you may starve the pump.
250whp range is usually a bolt and go.
If you want more power or want to run E85, you will have to get larger injectors or find a tuner that can tune for the use of both PI/DI at the same time.
Vortech kits don't make a lot of torque, so a new clutch isn't necessary.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following User Says Thank You to Cal3000 For This Useful Post:
Boofneenee (05-03-2015)
Old 05-02-2015, 09:54 AM   #3
FirestormFRS
I would suggest only an oil cooler based on your location. The AT really only needs a cooler if you hammer it for extended periods of time.
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
Old 05-02-2015, 09:57 AM   #4
Adrian002
Adrian002's Avatar
Thanks very much for your input, I appreciate it.
Old 05-02-2015, 10:00 AM   #5
Adrian002
Adrian002's Avatar
Yeah, an oil cooler seems to be a good idea. I'll be driving it in SoCal. I wouldn't have dreamed of shipping my car to this infernal base....cars take a beating out here from scorching sun and only DIY maintenance. There's a guy with an earlier gen supra here and the turbo gives a nasty audible pop when he parks it. I can't imagine how much caked up oil is in it...only boosted car I've seen on this base to date
Old 05-02-2015, 10:06 AM   #6
jflogerzi
jflogerzi's Avatar
Yup for a base vortech kit just a solid tune and a oil cooler. The smaller mocal with the 13 row radiator like sold on the Perrin kit should be perfect. If you are getting v3 becareful if you head to the track
2013 Series 10 FRS #553
Old 05-02-2015, 12:17 PM   #7
Zan
Drives: 2015 WRB BRZ
Is there an issue with trying to track the v3?
Zan is offline   Reply With Quote
Old 05-02-2015, 02:07 PM   #8
jflogerzi
jflogerzi's Avatar
Yes. Under heavy load they dont hold up well. I believe there is a heavy duty oil cooled v2 you want if your are going run at the track
Old 05-02-2015, 02:47 PM   #9
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
For what it is worth~
When I went FI I asked LJ/Fullblown what should I do first for cooling. Their oil cooler or their radiator?
They replied with radiator. It is the better value per dollar for a lower cost ($300ish for a radiator vs $500 for an oil cooler.) And better supporting mod for the daily driver.
Keep in mind this was which to do first.
The Following User Says Thank You to Kiske For This Useful Post:
jflogerzi (05-02-2015)
Old 05-02-2015, 03:14 PM   #10
jflogerzi
jflogerzi's Avatar
Its been proven that the stock rad is fine. And he is going sc and not a turbo so the oil cooler is a much better choice. In so cal on a na car oil temps can climb
Old 05-02-2015, 03:42 PM   #11
R3NIK
R3NIK's Avatar
Drives: 2013 FR-S/C
Zero clue why they'd recommend that. Stock water cooling is excellent. Oil cooling is definitely a priority in any warm climate or FI setup.
R3NIK is offline   Reply With Quote
Old 05-02-2015, 06:58 PM   #12
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Are you at GTMO or in Cali???
Your profile thing says you're in GTMO? but you say you're at a base in Cali.
if you were at GTMO were you just on base or part of the JTF??
JAden
Jaden is offline   Reply With Quote
Old 05-03-2015, 01:29 AM   #13
DAEMANO
Time Traveller
Oil cooler and catch can are a must. Then catless header. If you change pulley, then consider wheel/tire upgeade, a stg 2 clutch, brake pads, fluid, and lines.
The Following User Says Thank You to DAEMANO For This Useful Post:
Deadpool_25 (05-04-2015)
Old 05-03-2015, 02:51 AM   #14
sw20kosh
Drives: 2013 Black FR-S
Lol limit of stock radiator hasn't been found even on track. That was bad advice.
The Following User Says Thank You to sw20kosh For This Useful Post:
DAEMANO (05-03-2015)
Supporting mods for higher rev limit? radroach Engine, Exhaust, Transmission 6 12-01-2014 10:53 PM
FI, supporting mods and transmission question BRZPDX Forced Induction 9 12-11-2013 01:22 PM
turbo kit supporting mods lbroskee Forced Induction 13 03-30-2013 08:56 PM
Supporting Mods For F/I Applications Tansey86 Forced Induction 59 02-26-2013 01:42 AM
Supporting Mods Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 02-21-2012 05:33 PM
