Old 04-29-2015, 12:42 PM   #57
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
From everything I have read, there is no stock limiter. The car is drag limited to 136 MPH at stock power. With my areo mods, stock ECU and bolt ons I have in theory, once or twice, may or may not have, on occasion, off public highways, in the middle of the desert, hypothetically, gone 137mph and the car was still pulling.
Header, catback, & K&N.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 04-29-2015, 03:45 PM   #58
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Originally Posted by OkieSnuffBox View Post
Why it's not hurting the engine and you can still get 30mpg on the highway?
Because it is effing annoying and you could theoretically get better mileage if it didn't have to rev so high......
Old 04-29-2015, 06:59 PM   #59
CoupedUpSubie
Drives: 2013 BRZ Limited
Any gains in mileage seen at cruising speeds will be mostly offset by increased effort of taking off. Those that have gone with lower gears say they only lost 1-2 mpg at most IIRC. The bigger benefit of lower RPMs at cruising speed would be less exhaust noise while cruising.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 04-29-2015, 08:07 PM   #60
churchx
churchx's Avatar
Drives: 2014 GT86
Selling point of these cars is handling. NOT top speed, NOT cruise comfort or good sound insulation. Increasing something that is not their strength & purpose at expense of severely hurting THE purpose/strength of them makes me think that wrong car was bought. Even for twins MSRP there are faster ones, there are more comfortable/quieter ones. It's hard to find better handling ones at this price range (except Miata of course, but i doubt it's top speed or comfort being very high on list too).
Old 04-29-2015, 09:33 PM   #61
zooki
Drives: waiting on a 2021...
The beauty of these cars is they're cheap enough that they can be modded however somebody want to mod them. AutoX? Yep. Drag racer? Yep. Bonneville flats salt liner? Sure, why not. Rocket Bunny cambered out parking lot crawler, yes sir. It kills me that some people think you can only build these cars a certain way, and only use parts that cost a certain amount.... Come on, I'm a hot rodder. Improvise, adapt, haul asss! 😃
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 04-30-2015, 02:30 AM   #62
brn12345
brn12345's Avatar
The way these cars are tuned from the factory make it very hard to achieve high top speed. Although there is no outright top speed limiter, the ecu starts to close the throttle as higher speeds are achieved. The following link is to testing I did last year on this very issue. You will notice in the data logs how the throttle physically closes.
http://www.ft86club.com/forums/showthread.php?t=58835
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 04-30-2015, 09:12 AM   #63
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by Hyper4mance2k View Post
From everything I have read, there is no stock limiter..
After my comment above I pulled out RomRaider and looked at a stock ROM.
Amaya was 100% correct:
Originally Posted by Amaya View Post
The stock speed limiter is a soft limiter set at 137 and 140. The fuel cut speed limiter is set well over 200mph.
The soft limiter is set at 137 & 140.
Old 04-30-2015, 11:00 AM   #64
Summerwolf
Panda Trueno
Summerwolf's Avatar
If the Overdrive gear was steeper there would be no extra effort in taking off.
Old 04-30-2015, 11:05 AM   #65
OkieSnuffBox
Drives: '23 BRZ Limited
And the lower revs would require more throttle input to maintain the same speed.
It's really not that big of a difference either way.
Turn your stereo up, or put a nice exhaust on the car.
Old 04-30-2015, 11:08 AM   #66
Summerwolf
Panda Trueno
Summerwolf's Avatar
Because in sixth maintaining cruise at 70-75 requires a ton of throttle input right?
You're right, it really isn't that big of a deal, I was saying in an ideal situation.
I haven't even seen rear gears available besides higher ratios, and no trans gearing changes. It seems to me a lower ratio rear with as many turbo vehicles are out there would be almost common.
Old 04-30-2015, 01:00 PM   #67
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
So what is a soft limiter, spark cut? Normally that's what soft limiters are referred to as.
Old 04-30-2015, 05:46 PM   #68
churchx
churchx's Avatar
Drives: 2014 GT86
Imho spark cut would result to too quirky 'cut' at that speed. And why would one use it, if throttle is drive by wire, and ECU simply may set it to position it needs to not go over limit? Think of it as high-speed cruise control, lol
Old 04-30-2015, 06:04 PM   #69
steve99
Drives: FT86
it looks like their is three "limiters"
Throttle "limiter" set to close throttle plate partially in at 140mph ie close throttle till 137 mph then allows throttle to open futher again
Fuel cut limiting at over 200mph , unlikely to ever hit that one stock
RPM limiter stock at 7400 unlikely to hit that in top gear on stock car.
all can be adjusted via tune tables.
Old 04-30-2015, 10:02 PM   #70
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
That was my point. Soft limiters are spark cut. So it sound's like we're ECU limited to 140 with the stock tune.
Coilover options capable of slightly increasing ride height. Mechazawa Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-31-2014 01:23 PM
Decreasing Wheel diameter while increasing the width BlackMagicSir Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-01-2013 09:58 AM
Damn 86 increasing in price in Taiwan next year... tnkw Scion FR-S / Toyota 86 GT86 General Forum 11 10-16-2012 04:59 PM
Increasing torque with out forced induction BigFatFlip Engine, Exhaust, Transmission 54 05-17-2012 08:03 PM
