Old 05-01-2012, 03:04 PM   #1
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Increasing torque with out forced induction
Hello all. After reading the last part of the EVO review (BRZ vs. Impreza), it got me thinking. I seems that low end torque is the key to the "fun" and the lack of it was what they all had an issue with. My question to all the mechanically inclined folks out there, other than forced induction (turbo/supercharging, which has been much talked about around here), are there any other ways of increasing an engine's torque? From my basic knowledge, a reflash (ie Cobb, etc.) may have some gains, but I'm not sure how much for a non-fi engine. I know engine mods like boring-out and a more aggressive cam can give a little bit but I'm not quite sure how all this applies to a smaller 4-cyl, let alone a boxer engine.
Old 05-01-2012, 03:19 PM   #2
3MI Racing
Pro Subie Engine Nerd
3MI Racing's Avatar
Drives: empty spot for an FR-S/BRZ
Put simply increasing air flow in and exhaust out, reducing mechanical losses and improving combustion efficiency.
Intake, exhaust, stronger igntion system and lightened flywheel are a few easy methods. Beyond that I'll start getting on nerdy on the engineering work I'll be carrying out within the engine.
3MI Racing is offline   Reply With Quote
The Following 3 Users Say Thank You to 3MI Racing For This Useful Post:
BigFatFlip (05-01-2012), BLACK->BULLET (06-02-2015), civicdrivr (05-03-2012)
Old 05-01-2012, 03:23 PM   #3
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
Increasing displacement...
A tune would most likely would bump the TQ in places where it's lower (like the dip between 3500-4500). But to gain gobs of peak TQ would mean what 3MI said, making the most of what's there. Intaking more air, adding more fuel, and letting out that air in an efficient manner. Basically the engine is a pump, with tradeoffs.
Sacrificing gas mileage for more power, for example.
86'd is offline   Reply With Quote
The Following 3 Users Say Thank You to 86'd For This Useful Post:
BigFatFlip (05-01-2012), bimmerboy (05-01-2012), civicdrivr (05-03-2012)
Old 05-01-2012, 03:28 PM   #4
bimmerboy
Drives: 2009 135i
+1
bimmerboy is offline   Reply With Quote
Old 05-01-2012, 03:52 PM   #5
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
If only they made it a 2.2 stock.
blu_ is offline   Reply With Quote
Old 05-01-2012, 03:56 PM   #6
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
What about I/E Manifold Porting/Polish? Did previous Subaru engines gain from this?
Starscream15 is offline   Reply With Quote
Old 05-01-2012, 04:29 PM   #7
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
I think anything to do with the intake will gain torque but for example on my 350z when i did the dc headers i actually lost torque down low but gained hp. So you might want to wait on getting headers till someone does a dyno test. Boxer engines are know for their low end torque so i think the engine should be very responsive.
Light flywheels are know to decrease inertia meaning more torque will be needed to break traction or get off the line quick. Everything else you said makes sense.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following User Says Thank You to track_warrior For This Useful Post:
Old 05-01-2012, 07:25 PM   #8
W204
Drives: 08 C350, 02 Subaru WRX
Nice to see a fellow w204 owner here
If the 2.5RS is any indication of boxer NA engine tuning, it is going to be tough. There are very few EJ251's(zzyzx for example) running at 300whp NA and it had such a wide array of parts such as racing cams, ported and polished heads, throttle body, and intake manifold, racing pistons, lightened crankshafts, lightened rods, etc.
I'm guessing the FA20 will probably top off somewhere between 240-250whp with general mods such I/H/E/T and that's just well wishing. That's exactly fine with me as that's perfectly where I would want my 86 to be in.
W204 is offline   Reply With Quote
Old 05-01-2012, 08:23 PM   #9
BigFatFlip
BigFatFlip's Avatar
Thank you all for the input. To me, NA seems to be more fitting for this car, not that I wouldn't consider a turbo in the future (for Subaru sake) so all these tuning suggestion are great.
It seems like 240-250 hp/200 lb-ft is the magic number for a lot of the posts I've seen around here, which sounds around what I would like it, but who knows, maybe once I get my hands on one for a test drive, maybe all the other reviews maybe right about the engine being "just right"...
Old 05-01-2012, 08:37 PM   #10
Calum
That Guy
Drives: 2013 asphalt FRS MT
I think anything to do with the intake will gain torque but for example on my 350z when i did the dc headers i actually lost torque down low but gained torque up top. So you might want to wait on getting headers till someone does a dyno test. Boxer engines are know for their low end torque so i think the engine should be very responsive.
Light flywheels are known to require less power to accelerate thus allowing more power to be used to accelerate the rest of the drivetrain/car.
There fixed it for ya.
The Following 2 Users Say Thank You to Calum For This Useful Post:
3MI Racing (05-02-2012), mrtodd (05-04-2012)
Old 05-01-2012, 08:53 PM   #11
the_3d_man
Drives: 2007 Legacy GT
I seriously doubt we'll be seeing 240-250whp without FI, unless you go with an E85 tune or replace internals to significantly bump up the redline. I'd be impressed if we got much over 200whp reliably.
the_3d_man is offline   Reply With Quote
Old 05-01-2012, 09:06 PM   #12
matt30
Drives: 2004 Subaru WRX
Not really. It's not really a common mod because most people are tinkering with the forced induction (since all performance Subarus are turbos). The power gain per dollar was more reasonable.
I'm not saying it won't work (it should), it just wasn't very common.
matt30 is offline   Reply With Quote
Old 05-01-2012, 09:28 PM   #13
SkullWorks
Drives: SSM LT MT BRZ
more timing down low will add torque but will require race gas or E85,
more compression will help (~7% per pt of Compression) but 12.5 : 1 is already pushing the pumpgas envelope.
a light flywheel will reduce engine inertia and make you drive like a clutch monkey, it is a tradeoff of the first order, anyone who tells you otherwise either hasn't driven one or is arguing for the sake of the argument,
Most gains to lowend torque cost HP up top, I think the key to this car is going to be sorting out the torque dip of doom, otherwise the engine makes an incredibly flat torque curve for a 2.0L 4Cyl. upsetting that would be a mistake unless you are adding gobs of HP (a gob is equal to or greater than a metric fuckton)
SkullWorks is offline   Reply With Quote
The Following 2 Users Say Thank You to SkullWorks For This Useful Post:
NESW20 (05-01-2012), yourboyvic (11-16-2018)
Old 05-02-2012, 10:21 PM   #14
3MI Racing
3MI Racing's Avatar
eh, yes and no. The only way the lightened flywheel gives interial force to the tires is when you dump throttle or are disengaging the clutch (like launching the car). It does allow the engine to accelerate more rapidly as it requires less energy (power) to accelerate it's (the flywheel's) mass. So as I stated, it will give you power the same way reducing friction will. I never said a lighter flywheel would aid in force to launch a car or break traction.
So you were close but a bit off. I keep my customers with straight line cars on heavy flywheels for this exact reason. My track/auto-x/time attack all get light flywheels.
Do dealers re-torque lugs during PDI? Sport-Tech Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 05-08-2012 10:54 PM
Induction Poll - NA, Supercharger, or Turbo cloud9 Engine, Exhaust, Transmission 45 02-21-2012 12:41 PM
Will you make your BRZ/FR-S Forced Induction? koyv90 Scion FR-S / Toyota 86 GT86 General Forum 12 12-04-2011 09:31 PM
Sound induction tube Yay, or ay? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 22 12-04-2011 09:30 PM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 12:22 AM
