Old 04-24-2015, 10:59 PM   #225
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Also, tune might not have trims set correctly yet. Mine always felt a touch sluggish there to me after a fresh flash/ECU reset, but a MAF scale and some tweaking and it feels fantastic all the time
Old 04-24-2015, 11:08 PM   #226
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
Should I have to mess with the MAF scale at all though? I thought that only was needed with aftermarket intakes. I can definitely feel some good changes with the new map. I could see how the vvti sound could mess with me and give a placebo effect though. I actually kind of liked that sound!
cdq85 is offline   Reply With Quote
Old 04-25-2015, 01:00 AM   #227
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
My maf scaling was close with the factory intake, but every car is going to react slightly differently.
Old 04-25-2015, 01:13 AM   #228
Vroomin86
Drives: 2015 Fire
Guys so I have an OFT. Car currently sits at 1360 miles, been on stage 1 93 octane since about 600 miles. That's all I've done so far. On to my question:
I bought a vigilant MotorSports CAI. I want to install it sometime this weekend. I have never used the tablet to read diagnostics yet.
1. Once installed should I plug the OFT in and check for any numbers to be proper? Like MAF or A/F ratios etc to make sure the car is still driving at optimal performance ?Sorry I am a bit of a noob, what I mean is anything I should look for that should at a certain % : ratio? if that makes any sense lol
Vroomin86 is offline   Reply With Quote
Old 04-25-2015, 01:13 AM   #229
Vroomin86
Drives: 2015 Fire
Double post...
Old 04-25-2015, 05:26 PM   #230
steve99
Drives: FT86
Have a look at your ltft long term fuel trims it will vary with rpm ie flow rates but should be less than about 6% maybe a bit more at idle. Have a look with your stock intake then compare when you install new intake. If ltft goes to over 10% then your going to need to scale maf .. Also look at commanded afr verses afr and see if thier are large differences when yor full throttle see links below especially maf scaling for mor info and basic bolt on mods guide
Old 04-26-2015, 09:14 AM   #231
Fricke
Drives: Toyota GT86
With the G or I series rom ie europe australia south africa the oft guys only offer one map the map they use is the usa 91 map.
in general the usa 93 fuel is superior to our 98 ron fuel.
if your getting no knock over 5000 rpm then you could try copying the base timing B map from the usa equlivant tune. The only difference between 91\93 maps is base timing B table ie timing over 5000 rpm is reduced about 1.5 degrees in the 91 maps and hence our maps
Hm i always got the impression that Swedens/ Germany 98 and 98+/99 ron was Superior to US 93, haw heard diskussions whit folks that imported supras and V8 musel cars, that almost ewery time delivers more hp on the dyno whit tweeking, Tham they did in the US?
Fricke is offline   Reply With Quote
Old 04-26-2015, 09:18 AM   #232
Fricke
Drives: Toyota GT86
Originally Posted by chaoskaze View Post
Would like a review on ACE 4-2-1 header! Thanks haha.
Ofcourse i can do that, djust ned to break in the new Clutch and tune the car at PBZ first
Can post som dyno charts too 👍🏻
Old 04-27-2015, 10:04 PM   #233
steve99
Drives: FT86
Originally Posted by Fricke View Post
Djust got my OFT this week and flashd a euro stage 2 EL map in too the car
Runing an ACE 4-2-1 header and 2,5" exhast whit vibrant 200cel catt and cosworth panel filter.
My question is, what typ of Fuel ar the euro stage 2 mapps for?
Looked att the US mapps and those hade 91 or 93 oktane to schoose from.
Her in Sweden i run 98ron or 98+ron, but as i understand that is equal to yor 93?
Fot G or I series roms the oft tunes are basicly the 91 usa fuel maps which is about as good as 98 ron.
they dont offer the different octane tunes for petrol on g or i roms.
you do get e85 maps though and thats available in sweeden
if you get no knock on the maps affered then you could copy across the 93 base timing b tables from an equlivant usa 93 tune.
Old 04-28-2015, 02:44 AM   #234
coeurdencre
coeurdencre's Avatar
Drives: 2014 x ZC6 x 37J
Sorry if I'm a newbie but how can I know if I have knock ?
We can check only with a data log ?
I use the euro G serie stage 1 91 map with Shell vpower 100 octane.
Thanks !
coeurdencre is offline   Reply With Quote
Old 04-28-2015, 02:52 AM   #235
steve99
Drives: FT86
Thanks !
Yes you can use oft to log tune
log
IAM
FLKC
FBKC (knock correction)
dont confuse above with KC Learned it is not knock
alternativly set up oft with tuning alerts to sound alarm if
http://www.ft86club.com/forums/showp...5&postcount=10
iam less than 1
fbkc less than -0.7
fbkc knock correction less than -0.7
then ofr will beep and flash on knock events see links below for details ie knock correction post and oft tips
http://www.ft86club.com/forums/showthread.php?t=61820
Old 04-28-2015, 12:53 PM   #236
johneastvold
Drives: 2014 scion FRS
i just got the oft, i was going to turbo my car and decided against it. but i went ahead and flashed my ECU with this. Did all the nececary procedures. is it okay that i uploaded the stage 2 tune witha stock car? ran it for an hour this morning and at first it was slow to responce but i read that was normal but after awhile it leveled out and now driving amazingly. i run pure non ethanol 93 right now but stock everything else.
johneastvold is offline   Reply With Quote
Old 04-28-2015, 01:04 PM   #237
cnk
Drives: '13 DGM BRZ Limited
Stage 2 is for headers and full exhaust or e85. If you're stock, stick to stage 1.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 04-28-2015, 01:06 PM   #238
steve99
Drives: FT86
From the first post in this thread, no don't run stage 2 tune on stock car (on petrol) its only for cars with catless header uel or EL.
Rough guide OTS Map Requirements:
Stage 1- For vehicles equipped with original header. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel or fuel as specified by tune.
Stage 2- For vehicles equipped with aftermarket cat-less headers. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel or fuel as specified by tune
91 (USA) octane or better required for 91 octane tunes
93 (USA) octane or better required for 93 octane tunes
Its ok to use a higher octane than specified by the tune but not a good idea to use a lower octane fuel than specified by the tune.
E85 required for tunes labeled E85 (ie fuel with 60 to 90% ethanol content)
Exception for Stock cars running E85 use Stage 2 E85 EL header tune http://www.ft86club.com/forums/showthread.php?t=67310
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
