#393 | ||
Drives: Asphalt Scion FR-S
#394 |
Drives: PEARL WHITE GT86 TRD
#395 |
I used to have the Perrin rear shifter bushing with the TRD short shifter and it didn't feel right. Changing the shifter bushing for the TRD bushing and bracket feels a lot better as it relocates the rear carrier mounting point.
#396 |
I had the bracket (Item 2) installed today. There is very little difference between the TRD bracket and OEM bracket. The TRD bracket assembly seems to hold the shift tower assembly slightly higher.
I didn't notice any change in the length of the gear throws after installing the part. Regards |
#397 |
Drives: 2013 Red FRS
Just installed this. Got it for 156+tax. Not best deal probably.
Install took me about 3-4 hours. I did it all by putting my car on 2x4s and using jacks. Would be much easier with proper lift. I also really recommend having an assortment of ratchet extensions, i had to improvise a bit and it was difficult. My was really happy with the test drive. Throws are definitely shorter and they seem to pop into gear much more firmly. |
#398 |
I had a gear lever rattle, after installing this the rattle is gone
#399 |
I wanna go fast
Drives: 2013 FR-S 6MT
Just had this installed on Friday. I am not sure how I feel about it yet.
The throws are pretty dang short indeed, nice job of engineering. I can't help but feel like the msrp could be a little lower as they achieved their goal with the use about about $5 of parts. but I digress... Also the feel is very tight and notchy now. It will loosen up slowly over time, im sure, but at its current state, I'm not sure if I can actually shift a gear quicker because there is a little more resistance to motion now. |
#400 | |
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
#401 | |
#402 |
Drives: 2013 Whiteout FR-S
Anyone here track their car pretty hard core with results? Mine has started to become rubbish so may need to figure out what is going on soon.
| The Following User Says Thank You to kanundrum For This Useful Post: | chaoskaze (04-27-2015) |
#403 |
Drives: 2013 FRS
I'm about to go to the track this weekend but recently I've been getting a TON of slack in the shifter. I've re-tightened the bolt probably 4-5 times now, using bolt paste every time. Very concerning at the moment, not sure if you're having the same problem.
#404 |
I wanna go fast
It does seem to have loosened up a bit, I'm still counting on it getting looser though. Still not sure if I am actually faster at shifting with this kit.
#405 | |
im about to put on MTEC springs and see if it helps. also picked up Supertek solid trans mount support and Torque solutions trans bushing to just kick it up a notch. but really id try the springs but ill probably post again review after i installl
#406 |
I wanna go fast
please do. Id love to hear how they work with the trd qs
| TRD Quickshifter | lovebeingbleu98 | Brakes, Suspension, Chassis | 3 | 02-13-2014 01:14 AM |
| Amazing Wax | geb2391 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 04-12-2013 05:42 PM |
| The most amazing thing I've done with my BRZ so far | azngolfur | BRZ Photos, Videos, Wallpapers, Gallery Forum | 8 | 01-09-2013 09:23 PM |
| Concept-Three-LED's DRL's are AMAZING! | soros151 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-09-2012 02:42 AM |
