Old 02-24-2015, 01:15 PM   #393
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Originally Posted by Freedom View Post
Would anyone know what would happen or what the effect would be, if the rear mount assembly bracket (Item 2) was not installed or used and the OEM piece left installed?
Attachment 103268
The rest of the kit installed as per instructions.
Probably this:
Originally Posted by Koa View Post
TRD Quickshifter and Perrin bushing issue resolved! My first post about this issue will be updated.
Swapping out the perrin for the kit mount and bushing eliminated the shifter linkage/driveline collision. Shifting is crisp, smooth, and QUICK. 5th and 6th feel stock throw surprisingly, but 1st through 4th... goooood lord what a difference. Even helped out with 2nd being a bitch when cold. Clocked 50 miles on the shifter post install where I tried hard braking in every gear- acceleration, slamming the bugger in there etc; care was still used to hopefully not break anything
Here's some pics taken with a potato that probably won't convey the point..
TRD Quickshifter and Perrin installed, to confirm I'm not pulling your leg
Ultra-detailed high fidelity breakdown of the issue area
You can barely make out the place where the linkage rod and knuckle of the driveline were rubbing. In person you can most definitely make out the place where they rubbed- bare steel on the rod and little knick of paint off the tip curls of each knuckle
Fully recommend this piece. Confirms what most others who installed it correctly (everyone but myself and @stockysnail apparently haha) have to say about it. Very smooth, OEM feel. Short shifts, smooth and buttery gates.. more force needed, but not excessive.
Will update after a couple thousand miles seat time with it
JDKane527 is offline   Reply With Quote
The Following 2 Users Say Thank You to JDKane527 For This Useful Post:
JohnJuan (02-24-2015), Koa (02-24-2015)
Old 02-25-2015, 01:42 AM   #394
Freedom
Freedom's Avatar
Drives: PEARL WHITE GT86 TRD
Originally Posted by JDKane527 View Post
Probably this:
Hopefully not, I could not see much difference between the trd bracket and OEM. Taking the car in tomorrow to have it changed anyway.
Thanks
Freedom is offline   Reply With Quote
Old 02-25-2015, 06:49 PM   #395
JDKane527
JDKane527's Avatar
I used to have the Perrin rear shifter bushing with the TRD short shifter and it didn't feel right. Changing the shifter bushing for the TRD bushing and bracket feels a lot better as it relocates the rear carrier mounting point.
Old 02-26-2015, 05:13 AM   #396
Freedom
Freedom's Avatar
I had the bracket (Item 2) installed today. There is very little difference between the TRD bracket and OEM bracket. The TRD bracket assembly seems to hold the shift tower assembly slightly higher.
I didn't notice any change in the length of the gear throws after installing the part.
Regards
Old 03-08-2015, 07:43 PM   #397
Dboe
Drives: 2013 Red FRS
Just installed this. Got it for 156+tax. Not best deal probably.
Install took me about 3-4 hours. I did it all by putting my car on 2x4s and using jacks. Would be much easier with proper lift.
I also really recommend having an assortment of ratchet extensions, i had to improvise a bit and it was difficult.
My was really happy with the test drive. Throws are definitely shorter and they seem to pop into gear much more firmly.
Dboe is offline   Reply With Quote
Old 03-09-2015, 02:30 AM   #398
Freedom
Freedom's Avatar
I had a gear lever rattle, after installing this the rattle is gone ! I think the bolt provides a more secure connection to the gear lever.
Old 03-23-2015, 10:45 PM   #399
2much
I wanna go fast
Drives: 2013 FR-S 6MT
Just had this installed on Friday. I am not sure how I feel about it yet.
The throws are pretty dang short indeed, nice job of engineering. I can't help but feel like the msrp could be a little lower as they achieved their goal with the use about about $5 of parts. but I digress...
Also the feel is very tight and notchy now. It will loosen up slowly over time, im sure, but at its current state, I'm not sure if I can actually shift a gear quicker because there is a little more resistance to motion now.
2much is offline   Reply With Quote
Old 03-24-2015, 10:06 PM   #400
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
I think mine either went away after about a month, or I got used to it. I still shift with only my fingertips, and I've had it for about 10k miles now.
JohnJuan is offline   Reply With Quote
Old 04-27-2015, 01:43 AM   #401
Jake_86
Jake_86's Avatar
Did your notchy shifting go away yet? I might try putting on some MTEC springs and hope it's smoother. Or Motul oil seems to be another option
Gold Accented GT86 Build Thread
Live Fast, Die Young.
Jake_86 is offline   Reply With Quote
Old 04-27-2015, 02:12 AM   #402
kanundrum
Drives: 2013 Whiteout FR-S
Anyone here track their car pretty hard core with results? Mine has started to become rubbish so may need to figure out what is going on soon.
The Following User Says Thank You to kanundrum For This Useful Post:
chaoskaze (04-27-2015)
Old 04-27-2015, 12:25 PM   #403
Cop
Cop's Avatar
Drives: 2013 FRS
I'm about to go to the track this weekend but recently I've been getting a TON of slack in the shifter. I've re-tightened the bolt probably 4-5 times now, using bolt paste every time. Very concerning at the moment, not sure if you're having the same problem.
Cop is offline   Reply With Quote
Old 04-27-2015, 06:49 PM   #404
2much
I wanna go fast
It does seem to have loosened up a bit, I'm still counting on it getting looser though. Still not sure if I am actually faster at shifting with this kit.
Old 04-27-2015, 07:12 PM   #405
Jake_86
Jake_86's Avatar
im about to put on MTEC springs and see if it helps.
also picked up Supertek solid trans mount support and Torque solutions trans bushing to just kick it up a notch.
but really id try the springs but ill probably post again review after i installl
Old 04-27-2015, 07:30 PM   #406
2much
I wanna go fast
please do. Id love to hear how they work with the trd qs
TRD Quickshifter lovebeingbleu98 Brakes, Suspension, Chassis 3 02-13-2014 01:14 AM
Amazing Wax geb2391 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-12-2013 05:42 PM
The most amazing thing I've done with my BRZ so far azngolfur BRZ Photos, Videos, Wallpapers, Gallery Forum 8 01-09-2013 09:23 PM
Concept-Three-LED's DRL's are AMAZING! soros151 Cosmetic Modification (Interior/Exterior/Lighting) 4 11-09-2012 02:42 AM
