Old 04-25-2015, 10:17 PM   #225
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by akahenry View Post
Are you currently running the Stage 2 UEL Map?
On a side note, I can't believe this hasn't been asked yet but how the hell do I disable the "P050B" CEL that I keep getting every morning? I clear it with the OFT every day and am getting pretty sick of clearing it day after day. Any tips?
Currently running the OFT300 Map - I've got a Vortech.
The P050B option may not be in your XML definition file by default and you'll need to get the right definition set up before it shows up as an option.
Old 04-26-2015, 06:33 PM   #226
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I didn't have to do anything special to disable the P050B CEL code. It was already in my OTS tune definition. I am currently running a heavily modded UEL tune, but since the tune doesn't make changes for just one bank of the engine it's all right. It has more power in the UEL tune then the EL tune, so I use the UEL tune.
KoolBRZ is offline   Reply With Quote
Old 04-26-2015, 07:22 PM   #227
troek
troek's Avatar
Drives: 2012 Toyota 86
Your running an EL with OFT UEL tune? How are you determining the UEL tune makes more power?
troek is offline   Reply With Quote
Old 04-26-2015, 08:04 PM   #228
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Unless he's done something different to it, it doesn't according to the dynos he's done.
Check the threads he started and you'll see the thread.
Old 04-30-2015, 10:03 AM   #229
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
Did this yesterday. What a huge difference. Now i can install a catback and not be worried about the neighbors.
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 04-30-2015, 02:16 PM   #230
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
Oh god, dont get him started
Digitalanalog is offline   Reply With Quote
The Following User Says Thank You to Digitalanalog For This Useful Post:
Wayno (05-11-2015)
Old 04-30-2015, 09:28 PM   #231
akahenry
akahenry's Avatar
Drives: '18 STi
Man I'm confused. I have no idea how to add the remaining sections of: "MAF Correction After Start (Neutral)" and "MAF Correciton After Start (In Gear)" into my "definition"/ rom. People are saying to edit a definition... how do I go about doing this? When I try to copy and past the following into my "definition," nothing happens.
Code:
<table name="MAF Correction After Start (Neutral)" storageaddress="11C868">
		  <table type="X Axis" storageaddress="11C81C" />
		  <table type="Y Axis" storageaddress="11C848" />
		</table>
		<table name="MAF Correction After Start (In Gear)" storageaddress="11C964">
			<table type="X Axis" storageaddress="11C918" />
			<table type="Y Axis" storageaddress="11C944" />
		</table>
and
Code:
<table type="3D" name="MAF Correction After Start (In Gear)" category="Mass Airflow / Engine Load" storagetype="uint16" endian="big" sizex="11" sizey="8" userlevel="4">
      <scaling units="g/s" expression="x*0.004577637" to_byte="x/0.004577637" format="0.0" fineincrement="0.1" coarseincrement="1" />
      <table type="X Axis" name="Coolant Temperature" storagetype="float" >
        <scaling units="DegreesF" expression="(x*1.8)+32" to_byte="(x-32)/1.8" format="0.0" fineincrement="1" coarseincrement="10" />
        </table>
      <table type="Y Axis" name="Idle Mode" storagetype="float" >
        <scaling units="Mode Counter" expression="x" to_byte="x" format="0" fineincrement="1" coarseincrement="5" />
      </table>
    </table>
    <table type="3D" name="MAF Correction After Start (Neutral)" category="Mass Airflow / Engine Load" storagetype="uint16" endian="big" sizex="11" sizey="8" userlevel="4">
        </table>
      </table>
    </table>
In other words, I'm a noob and don't know how to edit the my rom. Can anyone make a step by step guide?
I'm using the "OFT_ZA1JB10C" rom, more specifically the Stage 2 UEL bin.
akahenry is offline   Reply With Quote
Old 04-30-2015, 09:51 PM   #232
Andrew025
Andrew025's Avatar
Code:
</table>
</table>
and
Code:
        </table>
      </table>
    </table>
        </table>
      </table>
    </table>
What are you using to edit the definition?
If you're not already using it, download notepad++ and open the definition with that.
Old 04-30-2015, 09:59 PM   #233
steve99
Drives: FT86
Code:
        </table>
        </table>
and
Code:
        </table>
      </table>
    </table>
        </table>
      </table>
    </table>
Romriader does the rom editing.
you need to edit the definition file romraider uses to index into the rom.
However you may be lucky. If your original ROM was B01C and your using OFT V2.06x tunes then I believe the ROM is based on B01C.
So in your case you should be able to grab the Github version of the B01C definition and use it to edit your ROM. You wont be able to access LC/FFS parameters with that definition but the MAF tables will be in their.
Just make sure you check some tables in rom to make sure the definition matches. See the ROM Raider Tips link below.
Remember your going into dangerous territory here so check your work and rom and defs match else its bricked ecu for you.
Old 05-01-2015, 12:22 AM   #234
akahenry
akahenry's Avatar
Drives: '18 STi
Thanks. The Notepad++ definitely allowed me to edit the definition. Luckily, I already have it on my computer.
As of right now, I've copy and pasted the first code-block (the first code that I quoted in my previous post) into my definition, but my question now is where should I copy and paste the second code-block(the longer block of code)?
Old 05-01-2015, 12:31 AM   #235
Andrew025
Andrew025's Avatar
Both blocks of code will go into the definition.
Old 05-01-2015, 12:46 AM   #236
akahenry
akahenry's Avatar
Drives: '18 STi
Yeah I know that but, my question is where should I paste the blocks of codes? From my intuition on programming, I know that if I were to copy and paste the block of codes into a random place, the program as a whole wouldn't function as intended.
Well anyways, I got it to work. I see the MAF Correction After Start (In Gear) and (Neutral). What I did was copy and paste both code blocks and placed them where, acj47, placed his/her's.
I copy and pasted the first block of code
after
Code:
  <table type="Y Axis" storageaddress="104E98" />
         </table>
and I copy and pasted the second block of code and pasted it before:
Code:
 <table type="3D" name="Engine Load Compensation A (MP) "...
I'll go ahead and save this, and flash it onto my car. I'll report back whether my ecu is "bricked" or not.
Old 05-01-2015, 02:23 AM   #237
Kodename47
Kodename47's Avatar
Drives: UK GT86
Think of it as the top half of the definition are the addresses, the bottom half is the table info. The addresses don't need to be in order, you can just add new ones at the top. However the table info will sort the categories automatically by the 1at instance and within each category it will sort by the order in the list.
.: Stealth 86 :.
Kodename 47 DJ:
akahenry (05-01-2015)
Old 05-01-2015, 05:34 AM   #238
troek
troek's Avatar
after
Code:
         </table>
Code:
sorry i got to your message late. glad to see you got a handle on things.
The Following User Says Thank You to troek For This Useful Post:
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 02:14 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 06:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 01:35 PM
