Old 05-18-2012, 04:47 PM   #15
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
I would be careful about running H3's in there. Using PSX24W's in place of H3's is fine because they use considerably less wattage, but using H3's in housings designed for PSX24W's can cause melting issues with both the housings and the wiring. The circuits are designed for 24W bulbs, not 55W bulbs.
Just saying, nobody will have tried it yet, don't want to see a ton of melted lights around .
EDIT: I do realize this is mostly about HID's, which are often 35W, but I believe my post is still relevant.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following User Says Thank You to Jeff Lange For This Useful Post:
86_ZN6 (05-18-2012)
Old 05-22-2012, 08:29 PM   #16
dnjshin0bi
dnjshin0bi's Avatar
Drives: 86 GTS (PW) Manual
Originally Posted by frs_gt86 View Post
Fog Lamps: PSX24W also known as the old H3
is this for the 86/fr-s ?
I know that in the BRZ manual it shows PSX24W but in the toyota 86 manual it doesn't seem to specify what the front foggies bulbs are...
dnjshin0bi is offline   Reply With Quote
Old 05-22-2012, 09:20 PM   #17
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
FR-S
86_ZN6 is offline   Reply With Quote
The Following User Says Thank You to 86_ZN6 For This Useful Post:
dnjshin0bi (05-22-2012)
Old 05-22-2012, 09:33 PM   #18
dnjshin0bi
dnjshin0bi's Avatar
FR-S
confirmed 100%?
cheers
Old 05-22-2012, 09:34 PM   #19
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
confirmed 100%?
cheers
yes!
dnjshin0bi (05-23-2012)
Old 05-23-2012, 12:21 AM   #20
Lighting Red
Habitual Line Crosser.
Lighting Red's Avatar
Drives: ^ Two of my favorite things.
Jeff
And appreciated. The point is to learn and make smart modifications.
But, but, but... It's only 200 hp?!
Lighting Red is offline   Reply With Quote
Old 05-23-2012, 12:32 AM   #21
Lighting Red
Originally Posted by jjdrivesajazz View Post
here's a picture of a subaru wrx i've done in the past
HID 6000k headlights and HID 3000k fog lights
That's what I am talking about! Do you recall the ballast size for that project? Also, have you found glare/dazzle issues with those HID fog lights? What about power draw???
Thanks in advance!
Old 05-23-2012, 02:27 AM   #22
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Thanks in advance!
he has yet to test these light on a FR-S
im bringing my car to him for complete testing of his lighting products
Old 05-23-2012, 08:58 AM   #23
Lighting Red
The inquiry was specific to the WRX, and HID lights in for light housings in general. Still, if you are taking your car in I will be very interested in how your set-up works out. Thanks!
Old 05-24-2012, 12:33 PM   #24
jjdrivesajazz
Drives:
Thanks in advance!
I used the slim digital ballasts for the fog lights, the WRX had a lot of space in the bumper and I actually re-used one of the mounting holes for the light housing, along with the supplied 3M double sided tape, it was very secure
With any housing intended for halogen bulbs WITHOUT a factory projector, you will experience some glare simply because that's the way the housing is, but with the FR-S and BRZ headlights, they have a factory projector that helps with a majority of the road glare.
These are all 35w kits, when compared to the factory bulbs which are 55w/65w usually, these are brighter with half the power.
edit: Here's a picture of the ballast mounted, very secure, doesn't move or bounce around at all
jjdrivesajazz is offline   Reply With Quote
Old 05-24-2012, 12:48 PM   #25
Carson Toyota
Carson Toyota's Avatar
Drives: Scion/Toyota
Originally Posted by robotvoice View Post
You never want to use HID bulbs in your fog light housings. Ever. It's too much light being scattered directly in front of your car and this makes it harder to see down the road in bad weather. This is why there are no cars that come from the factory with HID fog lights, it just doesn't work.
Very true, even Lexus cars in japan have had specific well designed HID fogs just to avoid this problem. But as you can imagine factory HID fogs are crazy expensive
Lexus IS factory LED fogs .. almost $1200.00 +
Factory IS350 HID kit .... $2200.00 !
Carson Toyota is offline   Reply With Quote
Old 05-24-2012, 01:41 PM   #26
bneale
bneale's Avatar
Drives: Scion FR-S
I was wondering, do you guys even know what the yellow lights/lenses mean? It does actually have a racing background.
In case you didn't know, yellow lights or lenses usually donates a car of a lower glass. Think GT2 and GT3 for example. Ferrari will run 458's in both classes but the GT3 cars will have yellow headlights to show the difference.
I always wonder if people know what this means. Especially when I see them on honda civics and such.
bneale
bneale is offline   Reply With Quote
Old 05-24-2012, 06:11 PM   #27
jjdrivesajazz
Drives:
bneale
I'm sure most people don't refer to yellow lights to racing history but a lot of people simply like the look of white light for the headlights and yellow for the fog lights, like the GS400's, IS300's, and other vehicles that have them stock from the factory
There's a reason behind everything, there's no real reason why people do anything to their cars other than the fact that it's their personal style and they like it, so if they want purple fog lights, let them understand that it doesn't produce much usable light but if they like it, then go ahead, if they wanted 20" wheels on their car, let them know they're gonna look like a clown car and get horrible gas mileage, but if they ultimately want to do it, no one is going to stop them, there's no written rule book on how to modify a car unless you're trying to build after a model vehicle
Old 05-24-2012, 11:48 PM   #28
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
:happy0180:
First thing i will do is to change the headlights then worry about the fogs~~~ still waiting for my fr-s to come sighhhh
Minovsky is offline   Reply With Quote
Rear Fog Light Thread robotvoice Cosmetic Modification (Interior/Exterior/Lighting) 38 03-11-2023 01:32 PM
6000k Halogen bulbs? CyberFormula Cosmetic Modification (Interior/Exterior/Lighting) 8 04-22-2012 03:41 AM
Rear lights difference… gtaqv Scion FR-S / Toyota 86 GT86 General Forum 15 01-26-2012 11:59 AM
why do we assume no hid lights? subaruslow Scion FR-S / Toyota 86 GT86 General Forum 6 12-01-2011 02:39 AM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
