Old 04-21-2015, 06:21 AM   #43
DohcTor
Drives: Low and fast
Every single day. You aren't living life if you don't string out this weak little motor.
DohcTor is offline   Reply With Quote
Old 04-21-2015, 09:12 AM   #44
Synack
Boosted
Synack's Avatar
Drives: Sideways
If that were true no car would survive more than a few track days where you spend nearly 20 minutes straight above 5k rpm and you're >7k rpm around 10 instances per lap (at my local) or ~100 times in that 20 minute session.
And it's typical to do that 5x in a track day... I've been above 7k rpm >500x in a single day. My car is at 37k miles with the only issue being a coil pack that needed replacing.
If this engine can't handle that long term expect this car to get dropped by thousands of people.
You basically just proved my point though, I was being conservative with the 50 number because I didn't want to seem like the d!ck that says "REDLINE IT 200 TIMES A DAY IN TRAFFIC BRO"
It should be able to handle it minus a couple of things like the coilpack and the DI issues. But anytime you consistently beat on a high compression motor, don't expect it to last forever.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 04-21-2015, 09:40 AM   #45
I can go you one better. I have "driven" a Subaru boxer engine (admittedly not this one) at 85 to 90% of RPM for as much as 3 hours at a time with no issues
Subaru engines are commonly used with reduction gear in experimental aircraft. In that scenario, they typically have a TBO (time between overhaul) of around 2,000 hours which is a lot of flying all at close to max RPM. Many last longer than that, but like any engine some won't.
strat61caster (04-21-2015)
Old 04-21-2015, 09:43 AM   #46
Timmy_Jones
Spun
Drives: 23' Supra
Timmy_Jones is offline   Reply With Quote
The Following 2 Users Say Thank You to Timmy_Jones For This Useful Post:
brandonblt2 (04-22-2015), Tcoat (04-21-2015)
Old 04-21-2015, 02:47 PM   #47
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Time will tell if this car has what it takes.
I'd rather find out today than putt around in fear.
Edit: My main point was that it's foolish to put a guideline of "number of redlines per day" there are too many factors to consider. I'd take a used car that was redlined 200x per day with proper maintenance over one that the owner cheaped out on maintenance and never passed 2,000 rpm any day of the week.
As dadhawk posted above, load and time spent at high load high rpm is a much better estimation on engine wear.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
Dadhawk (04-21-2015), Tcoat (04-21-2015), Ultramaroon (04-21-2015)
Old 04-21-2015, 02:57 PM   #48
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
That's basically how I think about it.
Why not drive the piss out of it while it's under warranty? I'd rather have something go wrong or any potential issues start to pop up now than years later.
The Following 4 Users Say Thank You to Andrew025 For This Useful Post:
strat61caster (04-21-2015), Strife26 (04-21-2015), Tcoat (04-21-2015), Ultramaroon (04-21-2015)
Old 04-21-2015, 04:34 PM   #49
torqdork
torqdork's Avatar
Drives: RV-7
Originally Posted by awhatzable View Post
So it safe to red line from 1st,2nd,3rd or 4th gear once everyday ?
Now that the science is settled in favor of "yes", please post dashcam footage of your daily 4th gear redline excursions around Sydney.
torqdork is offline   Reply With Quote
The Following User Says Thank You to torqdork For This Useful Post:
Old 04-21-2015, 04:37 PM   #50
Synack
Boosted
Synack's Avatar
Drives: Sideways
4th isn't a good gear for me. Been known to shred to pieces with boost. Already been through one.
Old 04-21-2015, 04:38 PM   #51
strat61caster
Oooh, 108 mph shenanigans.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
torqdork (04-21-2015), Ultramaroon (04-21-2015)
Old 04-21-2015, 05:11 PM   #52
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
I shift around Max non red rpms all day every day...about to hit 15k miles and no issues that I know of...hope it didn't go boom lol
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 04-21-2015, 10:23 PM   #53
shellslinger
Drives: Whiteout FRS
There's a 4th gear in this car!?
shellslinger is offline   Reply With Quote
The Following User Says Thank You to shellslinger For This Useful Post:
Old 04-21-2015, 11:25 PM   #54
Strife26
Strife26's Avatar
The car has 4th, 5th AND, 6th, but the race car only has 1st, 2nd, and 3rd!
Old 04-21-2015, 11:43 PM   #55
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Maybe once in every 5 times I drive it. I usually drive quite sedately in the city. Rarely go over 4k rpm.
I don't drive mine as much as I'd like though. She's a 2012 and still under 10,000 miles lol.
Wise is offline   Reply With Quote
Old 04-21-2015, 11:51 PM   #56
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I think our 3rd is good for 80 mph? Lol
The Following User Says Thank You to chaoskaze For This Useful Post:
Possible to reach fumoto without lifting? 1Cor10:23 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-23-2014 04:36 PM
Tryong to reach Tony from FA20club infanterene Forced Induction 2 07-31-2013 08:16 PM
The seating position of BRZ is too low to reach at a drive-through-ATM yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 28 07-16-2012 02:18 PM
First to reach 1,000 miles? dietz Scion FR-S / Toyota 86 GT86 General Forum 22 05-31-2012 11:43 AM
