Old 04-20-2015, 01:18 PM   #15
Tromatic
Every day I drive it...
The correct answer.
Old 04-20-2015, 01:22 PM   #16
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
You should redline it at least once each day, to verify that your limiter is working properly!
billwot is offline   Reply With Quote
The Following 2 Users Say Thank You to billwot For This Useful Post:
Caspeed (04-21-2015), zman (04-20-2015)
Old 04-20-2015, 02:02 PM   #17
ls1ac
ls1ac's Avatar
I thought the rev limiter was used as an audible shift indicator. It works for me. Just kidding, the red line is the safe limit, use it.
Old 04-20-2015, 02:19 PM   #18
Teseo
Drives: frs
We tuned the car to preserve the engine and increase longevity. Use the redline when you feel
its necessary for win. Good luck
The Following 2 Users Say Thank You to Teseo For This Useful Post:
ThierryIsAble (04-23-2015), trvth (08-06-2015)
Old 04-20-2015, 02:32 PM   #19
Surprised no one has mentioned this yet: Only after the engine has reached full operating temperature.
Not the water temp, the OIL. Give it a good 15-20 minutes before dropping the hammer.
The Following 6 Users Say Thank You to Ultramaroon For This Useful Post:
Andrew025 (04-20-2015), brandonblt2 (04-22-2015), Choco (04-20-2015), Clipdat (04-21-2015), Sarlacc (04-20-2015), Tcoat (04-20-2015)
Old 04-20-2015, 02:48 PM   #20
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Errday Everyday
The Following User Says Thank You to chaoskaze For This Useful Post:
strat61caster (04-20-2015)
Old 04-20-2015, 02:58 PM   #21
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by awhatzable View Post
How often can I reach red line ?
I think the red line counter is limited to 99. After that the computer will put the car into limp mode until you take it in for inspection and service. The inspection costs $400 at Subaru. I don't know what the Toyota dealers charge.
There's an easy way to check your RL counter to see how many you have left. There are three buttons on the dash for odometer and such. Put the car into accessory mode and punch the following sequence as fast as you can: top-middle-middle-top-bottom-top-middle-top-top-top, then pump the hand brake three times. The check engine light will begin flashing yellow, and the RL count will display on the dash in place of the odometer.
You have to get the timing just right to make it happen. It may take you several attempts.
The Following 4 Users Say Thank You to extrashaky For This Useful Post:
gramicci101 (04-20-2015), meWant (04-23-2015), Ultramaroon (04-21-2015), wbradley (04-21-2015)
Old 04-20-2015, 03:00 PM   #22
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I set my idle to be at redline
If anything comes up, I'll be able to say "The engine blew up at idle, I dont know what happened?!"
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
Thrustin (04-25-2015), Ultramaroon (04-20-2015)
Old 04-20-2015, 03:04 PM   #23
illicitstylz
Drives: 2014 FRS - Whiteout - 6spd MT
notsureifsrs
illicitstylz is offline   Reply With Quote
Old 04-20-2015, 03:49 PM   #24
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Monday to Friday.
Muaddib is offline   Reply With Quote
Old 04-20-2015, 04:06 PM   #25
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by illicitstylz View Post
notsureifsrs
Totessrs
Old 04-20-2015, 04:29 PM   #26
DarkSunrise
DarkSunrise's Avatar
I heard if you do it too much, it makes you go blind.
2022 BRZ Build
2013 FR-S Build
The Following 4 Users Say Thank You to DarkSunrise For This Useful Post:
brandonblt2 (04-22-2015), strat61caster (04-20-2015), Strife26 (04-22-2015), Ultramaroon (04-20-2015)
Old 04-20-2015, 04:31 PM   #27
thill
That explains my erratic driving....
The Following User Says Thank You to thill For This Useful Post:
DarkSunrise (04-20-2015)
Old 04-20-2015, 06:40 PM   #28
billwot
I'll quit when I need glasses!
The Following User Says Thank You to billwot For This Useful Post:
Possible to reach fumoto without lifting? 1Cor10:23 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-23-2014 05:36 PM
Tryong to reach Tony from FA20club infanterene Forced Induction 2 07-31-2013 09:16 PM
The seating position of BRZ is too low to reach at a drive-through-ATM yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 28 07-16-2012 03:18 PM
First to reach 1,000 miles? dietz Scion FR-S / Toyota 86 GT86 General Forum 22 05-31-2012 12:43 PM
