Old 04-18-2015, 11:24 AM   #43
Chad_W
Drives: 2013 BRZ DGM
To simulate going from 4.10 to 4.56 with just wheels and tires, you'd have to do a 215/40r16. There is a good option from Yokohama in this size and you'd also benefit from reduced rotational mass and unsprung weight. Unfortunately that's not a lot of tire in terms of ride quality and rim protection.
You're also going to lower your vehicle about 1", definitely a factor if you have other suspension mods. Lastly I'm not sure how great that will look in terms of overall circumference in the wheel well.
If you could get a hold of wheels and tires that size that fit just to try, it would be a great way to preview the benefits of the gearing change.
Chad_W is offline   Reply With Quote
Old 04-18-2015, 11:25 AM   #44
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I am waiting to see how you enjoy it with the turbo. That is the ultimate goal for my car.
Old 04-18-2015, 08:55 PM   #45
mrk1
Drives: Sterling BRZ Ltd
I know what exactly its going to do, the slight FD increase will give that sporty eagerness I miss in the car. The turbo will give the power! My new setup is a T25 GTX28 that should have no problem keeping up and flowing enough to match. Anyone who says turbos don't work with higher FD just didn't match up there setup.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
cdrazic93 (04-18-2015), DustinS (04-19-2015)
Old 11-08-2015, 11:32 AM   #46
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
Originally Posted by Lunatic View Post
I have the automatic and went with 4.88s. Best mod I have done to the car.
1 second off my 0 to 60 time
1.5 seconds off my 30 mph to 70 mph time.
How you measured 0-60 time? Cornometer? Obdii? Speedometer?
can you tell me the 0-60 times before and after swap?
Toyota86.ir is offline   Reply With Quote
Old 11-08-2015, 08:00 PM   #47
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
With a Gtech SS meter
http://www.gtechpro.com/ss_fanatic.html
8 and 7 seconds.
Lunatic is offline   Reply With Quote
The Following 2 Users Say Thank You to Lunatic For This Useful Post:
new2subaru (12-28-2015), Toyota86.ir (11-08-2015)
Old 11-08-2015, 11:17 PM   #48
Toyota86.ir
8 and 7 seconds.
Huge difference , 12.5% better time is awesome.
My record in sea level is around 6.6 (AT , stage 2 mike tune E85) With12.5% off i should record 5.86 seconds. Should be nice
My car swapped to 4.88 but i do not passed the break-in time.
Old 11-14-2015, 05:21 PM   #49
azynneo
Originally Posted by mrk1 View Post
I got the gears from MFactory, $750.
Install kit with solid pinion spacer from Weir Performance $380.
I did the labor myself so that saves me money there as its not a quick job, setting up the backlash, pinion height and preload. There are a bunch of shims you need to set the back lash, this is really what makes this not a drive way install. I bought one of every size, not cheap. There are only 2 of these shims in the diff when its done but I had to try a few to get the back lash just right. If you have a shop do the gear set up they would have to have these shims.
Did you need to buy the install kit? Or could you have used your old stuff aside from the carrier bearer shims?
azynneo is offline   Reply With Quote
Old 11-14-2015, 05:27 PM   #50
mrk1
You absolutely need new parts, new shims, new bearings, new pinion spacer be it solid or crush. You can technically reuse some bearings but it's not a good idea for the amount of work here.
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
jcw99 (03-10-2016)
Old 11-14-2015, 06:09 PM   #51
azynneo
welp, there goes 359$ extra bucks rip
Old 12-24-2015, 03:15 PM   #52
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I wonder if there is a method to figuring out how a 19% reduction fd ends up giving a 12.5% gain in acceleration. I wonder what a 5.29(29% reduction) would knock off.
SUB-FT86 is offline   Reply With Quote
Old 12-25-2015, 02:51 PM   #53
Toyota86.ir
Imagine AT 4.88 start from zero and in 55km/h the AT 4.88 shift to gear 2 .
AT 4.1 will be slower till 55km/h but from 55km/h to 65km/h the AT 4.1 is in gear 1 and AT 4.88 is in gear 2 and the torque of AT 4.1 is higher in 55-65km/h range.
This happen in all shifting range and overally FD 4.88 will not make it faster than 5% in 0-176km/h.
Going to higher FD will not help you.
Old 12-25-2015, 07:43 PM   #54
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Look up mechanical advantage. The 4.88 FD has a greater mechanical advantage in every gear than the 4.10 FD. This basically means the engine has more leverage to turn the tire, in every gear. measure the difference in FD with what you want, but the only measurement of any importance is measured by a stopwatch. A FD won't give you any more or less horsepower, but it will change the mechanical advantage the engine has in relation to the wheel/tire. This advantage can be measured with a stopwatch. It can also be measured by an accelerometer/smartphone app. You will definitely feel it.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 12-25-2015, 10:16 PM   #55
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by stevesnj View Post
Much more reliable and less expensive than any FI. Very simple and will work great with taller wheels and tires. Milage could suffer. Depends on the tire height and how you are on the skinny pedal.
you wouldn't happen to know anyone in NJ or PA that is reputable enough to do a quality final drive upgrade would you?
Old 12-26-2015, 11:11 AM   #56
bfrank1972
Drives: 2013 FR-S Argento
Yup, in gear acceleration will be harder, but shorter. As soon as the lower geared car shifts it loses it's advantage over the longer geared car (assuming both are in the upper power band). There's another thread on here somewhere where I discuss it in a bit more detail, and posted a spreadsheet that shows everything in basic mathematics. No doubt a lower FD makes the car FEEL more fun to drive though
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 12:49 PM
Final Drive Discussion JimmyMac Engine, Exhaust, Transmission 118 08-07-2017 10:18 PM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 03:11 PM
Where to buy LSD & Final Drive/Gear? GT86_PRAGUE Transmission and Driveline 0 01-09-2015 08:09 AM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 02:51 PM
