#29 | |
Drives: Sterling BRZ Ltd
Install kit with solid pinion spacer from Weir Performance $380. I did the labor myself so that saves me money there as its not a quick job, setting up the backlash, pinion height and preload. There are a bunch of shims you need to set the back lash, this is really what makes this not a drive way install. I bought one of every size, not cheap. There are only 2 of these shims in the diff when its done but I had to try a few to get the back lash just right. If you have a shop do the gear set up they would have to have these shims.
| The Following 6 Users Say Thank You to mrk1 For This Useful Post: | Griever423 (11-08-2015), Hawk77FT (11-08-2015), jcw99 (03-10-2016), JoeC (04-17-2015), stevesnj (04-17-2015), Ultramaroon (04-17-2015) |
#30 |
Drives:
Where's the like button lol
#31 |
Drives: 2013 MT Asphalt FRS
#32 | |
Drives: '13 Raven FR-S, MT
![]() ++kudos for the mod! .ck |
#33 |
#34 |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Higher RPM at cruising speed and engine/exhaust noise, possibly lower MPG, and possible warranty issues.
| The Following 2 Users Say Thank You to Bobblehead For This Useful Post: | Mr.Impreza (12-26-2015), Ultramaroon (04-17-2015) |
#35 |
Drives:
Intrigued...how would this feel on a vortech superchargered model?
#36 | ||
Because compromise ®
Drives: Red Herring
2/ The difference in static diameter is approximately 2mm. I do not know what the difference is on rolling diameter but I am suggesting it is not the panacea that some people claim. Quote:
17" 45 profile vs 16" 50 profile: When speedometer reads 60mph (96.6km/h) actual speed will be 59.8mph (96.3km/h): 0.3% slower on the 16". Once again this is static diameter. Negligible difference in ratios. I am hypothesing that given the increase in sidewall height a 16" tyre has more angular momentum than a 17" tyre.
#37 |
Not that dramatic a change in RPM but there is enough to notice. Warranty should not be affected at all. Would like to know for sure though.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#38 |
Any Centrifugal SC car would love a higher final drive. More RPM more power with a centrifugal SC so a higher FD will keep you in those higher more powerful rpms
| The Following User Says Thank You to mrk1 For This Useful Post: | misooscar (04-18-2015) |
#39 |
Try a 225/45/16 tire with those calculations. Thats what im running.
#40 | |
Drives: Red Herring
That is not something I have considered given how few choices TireRack offers in that size. I do not doubt there are savings to be made with that size.
#41 | |
Drives: 2014 GT86
But how about other bits? Like to some preferable handling changes, daily driving comfort, tire cheapness (imho should matter a lot in this car, as going sideways eats through rubber quickly), wider choice for that size? In my eyes pros/cons of 16" outweigh those for 17", except maybe for BBK fitments bit. |
| The Following 2 Users Say Thank You to churchx For This Useful Post: | Captain Snooze (04-18-2015), xsnapshot (11-14-2015) |
#42 |
Drives: 2014 GT86
BTW, that speedometer reading .. does it matter much at all, if even on oem 17" rims & oem prius tyres (and at air pressure as per manual) i saw difference of almost 8-10% vs what i saw on gps? As in 65kmh on speedo, 59 @gps. Yes, with different final drive difference will grow, but if there wasn't any precision to begin with, and main thing - real drive-ability/performance will increase no matter what is displayed on speedometer. And vice versa, putting bigger diameter wheels on car to get speedometer report right numbers will decrease performance of it except maybe top speed, almost no one almost never needs.
P.S. Great pitty that those rally grade rims are mostly available as 14-15" (those that are 16" look somewhat interim between them and average rims, with much longer spokes/smaller center dish, +usually are for 4x100 nut pattern, except maybe this) almost never as 17" and even greater pitty - that they are THAT heavy. Design-looks wise i prefer them to most other designs (#1, #2, #3). They simply look much meaner then thin spoke "normal" lightweight rims. I know that weight is there for strengthening/rigidity at heavy abuse .. but if there were of such design && lightweight (i'm willing to sacrifice extra durability), i'd jump on purchase right away. Last edited by churchx; 04-18-2015 at 10:47 AM. |
| 4.8 final drive | drift86 | Engine, Exhaust, Transmission | 29 | 11-28-2022 12:49 PM |
| Final Drive Discussion | JimmyMac | Engine, Exhaust, Transmission | 118 | 08-07-2017 10:18 PM |
| Final Drive 4.67 | Bongertz | Engine, Exhaust, Transmission | 33 | 09-02-2015 03:11 PM |
| Where to buy LSD & Final Drive/Gear? | GT86_PRAGUE | Transmission and Driveline | 0 | 01-09-2015 08:09 AM |
| 3.3 Final drive? | Manji | Engine, Exhaust, Transmission | 18 | 01-01-2015 02:51 PM |
