Old 04-14-2015, 05:00 PM   #15
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by 93frs View Post
The problem i was having was hard to put the car into gear, i had to jam it into gear actualy, and at low rpm taking off car was kinda shaky, also i noticed my clutch pedal was not coming up like normal
Yeah a 'clutch job' is unlikely to fix this problem unless the pressure plate has collapsed and there is nothing left of the friction disc. I would be attacking the pedal assembly and clutch hydraulics which can certainly add up to $3k if you do the brute force fix of 'replace everything' which is the dealerships favored most profitable approach.
Why is the dealership not covering this under warranty? This does not sound like user error unless you have FUBAR the disc and it's disintegrated. It honestly sounds like a hydraulics problem.
ineedyourdiddly
Tcoat (04-14-2015)
Old 04-14-2015, 05:08 PM   #16
fika84
fika84's Avatar
^^ I second the fact that this is absolutely hydraulic related.
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
SkAsphalt (04-14-2015)
Old 04-14-2015, 05:09 PM   #17
93frs
Drives: Raven frs
This is my first mt car, well the car is at the dealer i only spoke wit the tech on the phone, im gunna get more info and let you guys know what they say after work,
93frs is offline   Reply With Quote
Old 04-14-2015, 05:10 PM   #18
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Your release bearing probably stuck
Old 04-14-2015, 05:11 PM   #19
strat61caster
Push for a warranty repair, make them prove that it was user error.
Everybody, this is why you ask questions when diagnosing problems.
ineedyourdiddly
Old 04-14-2015, 05:12 PM   #20
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Is this also your first car? Based on spelling and grammar errors I am pegging you as either young or English is not your first language.
Old 04-14-2015, 05:25 PM   #21
93frs
Drives: Raven frs
Firsr out the dealer car yes
and im at work tryna keep up with the machines and also replying to you guys
Old 04-14-2015, 07:44 PM   #22
ZX88
ZX88's Avatar
Drives: 22 BRZ
this sounds like an issue i had the assembly that guides the shift rod ( what ever its called came loose and i couldnt get it int gears) once tighten it worked like a charm. The dealer didnt even charge me for the fix (still under warrenty) as for the pedal i would make sure your fluid levels are good and bleed the master.
if there is play in your shifter when in gear its definitly that selection rod assembly.
ZX88 is offline   Reply With Quote
Stock Clutch Assembly + flywheel - used 800 miles - $180 pickup - $200 shipped KSpider Transmission and Driveline 2 08-19-2015 02:21 AM
Replace entire OEM clutch assembly, or disc? radroach Engine, Exhaust, Transmission 8 08-08-2014 12:00 AM
Dealer installed new clutch assembly -- is there a break-in period? Meanderchap Engine, Exhaust, Transmission 22 04-03-2014 09:41 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
