Old 04-14-2015, 12:46 PM   #1
93frs
Drives: Raven frs
need a clutch assembly
Hey guys im gunna need a clutch assembly, where can i get one for good price (dealer is telling me $ 3,000+
93frs is offline   Reply With Quote
Old 04-14-2015, 01:03 PM   #2
fika84
fika84's Avatar
not the dealer.... There is a used one in the for sale section. Or just get an aftermarket stage 1 clutch (I'd go with Clutchmasters).
fika84 is offline   Reply With Quote
Old 04-14-2015, 01:26 PM   #3
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
stock clutch is from Exedy Stage 1 - if memory serves me correct
Old 04-14-2015, 01:48 PM   #4
gramicci101
Off Topic
OEM clutch is Exedy, but not stage 1. Stage 1 is a still an organic clutch, but it's a step up from OEM. Compared to the Stage 2 clutch, which has a three puck cerametallic disc.
OEM clutch ($222): http://www.ft86speedfactory.com/exed...h-kit-988.html
Stg 1 clutch ($395): http://www.ft86speedfactory.com/exed...h-kit-790.html
Stg 2 clutch ($550): http://www.ft86speedfactory.com/exed...utch-1995.html
I found the OEM flywheel on SubaruOnlineParts.com for $210.
link
The Following 3 Users Say Thank You to gramicci101 For This Useful Post:
Bonburner (04-15-2015), SkAsphalt (04-14-2015), Tcoat (04-14-2015)
Old 04-14-2015, 03:20 PM   #5
93frs
Drives: Raven frs
What would you guys recomend stage 1 or just oem
Old 04-14-2015, 03:22 PM   #6
What kind of driving do you do?
Old 04-14-2015, 03:25 PM   #7
93frs
Drives: Raven frs
Daily driver but i do drive a bit hard put i plan on taking it easier on the car after replacing it
Old 04-14-2015, 03:26 PM   #8
strat61caster
strat61caster's Avatar
The only way I could see a $3k quote is if by 'clutch assembly' they mean more than just the friction plate, pressure plate, and throwout bearing as that job is at most $1,500 (and could be as low as <$500 for a specialty shop).
What is the problem that needs fixing? You could go do the clutch job but with zero success if you're trying to fix say a noise in the pedal/hydraulics that could be fixed with a squirt of lube.
ineedyourdiddly
Old 04-14-2015, 03:26 PM   #9
gramicci101
Off Topic
Also, what kind of power mods do you have?
Old 04-14-2015, 03:28 PM   #10
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
How many miles on your car before needing the new clutch?
Braces is offline   Reply With Quote
Old 04-14-2015, 03:30 PM   #11
93frs
Drives: Raven frs
The problem i was having was hard to put the car into gear, i had to jam it into gear actualy, and at low rpm taking off car was kinda shaky, also i noticed my clutch pedal was not coming up like normal
Old 04-14-2015, 03:31 PM   #12
93frs
Drives: Raven frs
Im at 29k
Old 04-14-2015, 03:45 PM   #13
93frs
Drives: Raven frs
And itts bone stock
Old 04-14-2015, 03:55 PM   #14
Please don't freak out!
How much experience with MT?
A novice can ruin a clutch in a heartbeat without even knowing it.
Stock Clutch Assembly + flywheel - used 800 miles - $180 pickup - $200 shipped KSpider Transmission and Driveline 2 08-19-2015 01:21 AM
Replace entire OEM clutch assembly, or disc? radroach Engine, Exhaust, Transmission 8 08-07-2014 11:00 PM
Dealer installed new clutch assembly -- is there a break-in period? Meanderchap Engine, Exhaust, Transmission 22 04-03-2014 08:41 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
