Old 05-18-2012, 09:37 PM   #1
USB on the stock radio
Has anyone pulled their stock radio yet on the FR-S? I'm interested in seeing if there is a way to get a second USB connection on it. I want to throw my old iPod in the glove box and just leave it there (I only use it in the car) and don't like the cable running from the USB port to the little cubby hole.
ESBjiujitsu (05-22-2012), Fly Guy (05-22-2012)
Old 05-18-2012, 09:55 PM   #2
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Hard wire a hub behind the lower jack, cut it, wire in the hub, run one of the hubs ports to the factory original one, then the others to wherever you want them. Assuming the radio works with a hub, which it should to be USB compliant. Plug the hub in first to be sure
michaelahess is offline   Reply With Quote
The Following User Says Thank You to michaelahess For This Useful Post:
Old 05-18-2012, 10:07 PM   #3
Yea, that is what I was thinking as well, but thought maybe the radio had a USB on it. I'm guessing not though from looking at the lame diagram in the manual. I'll definitely try the hub first, as you suggest.
Old 05-18-2012, 10:34 PM   #4
michaelahess
The FCC pictures do show a usb port on the back, but I suspect that's what's going down to that jack, might be able to just plug a hub in there. However it looked really square, so it may only be a USB B port which probably wouldn't support host mode.
Dadhawk (05-19-2012)
Old 05-22-2012, 11:03 AM   #5
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Maybe a dumb question, but is the stock USB port 'right side up' or 'upside down'?
In other words, if I wanted to order a short cable with a right angle connector (like from here: http://www.angledcables.com/a-to-micro-b.html) to have the cable go toward the cubby, do I want a 'left angle' or a 'right angle' on the A plug end?
Thanks for any info!
jdrxb9 is offline   Reply With Quote
The Following User Says Thank You to jdrxb9 For This Useful Post:
Jayde (05-26-2012)
Old 05-22-2012, 11:49 AM   #6
On mine, it is "right side up". When you plug a cable into it, the USB logo goes up.
jdrxb9 (05-22-2012)
Old 05-22-2012, 01:05 PM   #7
Tried plugging an unpowered hub into the USB plug on the console, but the radio throws up a "USB Error" message. Back to the drawing board I guess. Now I have to decide if its worth pulling the radio to try it. Maybe this weekend.
Old 05-22-2012, 02:07 PM   #8
michaelahess
It may require a powered hub...I believe they all run at 5v so it may be possible to run it off the car power with a small inverter or rectifier...I'll look into this.
If you have a powered hub and an inverter laying around you could try.
Old 05-22-2012, 02:36 PM   #9
Yea, I thought about that too but didn't have a powered one handy. Will try that later.
Old 05-22-2012, 02:44 PM   #10
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
Just thought about this over a long driving session. IIRC in the manual it stated that the default HU can read the MP3 files from a USB Thumb drive. So if the OP's requirement is to have a device storing music files left in the car, would it make sense just to get a cheap Thumb USB drive and load it with all your music file and plug that in all the time. With that, no cable is needed. Furthermore, changing music files is a breeze with your PC to copy-paste files.
I remember in the early days the forum members had discussed about the requirement of the HU. Things that 2-din unit with USB/AUX inputs are definitely required. It seems that Toyota got this and provide a decent HU for this purpose. (Although the SD card slot idea was not accepted...)
I know this is the work-around but not solving the problem. Just fruit for thought.
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
The Following User Says Thank You to Want.FR-S For This Useful Post:
Grateful Dave (09-17-2012)
Old 05-22-2012, 03:07 PM   #11
Originally Posted by Want.FR-S View Post
...So if the OP's requirement is to have a device storing music files left in the car, would it make sense just to get a cheap Thumb USB drive and load it with all your music file and plug that in all the time. With that, no cable is needed. Furthermore, changing music files is a breeze with your PC to copy-paste files....
That is an option, and I have my "86" USB drive loaded with music. The HU does a really nice job of controlling an iPod though, so I don't really want to give that up since I have a spare iPod.
It would also be nice to have the front USB port available for phone charging, etc since I want to "permanently install" the iPod. If it was an easy fix, I thought I would mount it in the glove box, but if not, I'll just leave as is.
Old 05-22-2012, 04:23 PM   #12
HotLavaMann
First 86 member
Drives: FRS, Tacoma, Honda CB1100
So I tried the "86" thumb drive loaded with 320 kbps mp3 music. It works great though I could only get about 55 songs on there which is a bit limiting. OTOH there isn't a way to play a playlist, it's all just one long list of music. So if I had all my music on a big thumb drive, it would be painful to find anything.
And the 86 thumb drive looks really cool in there. I think I'll stick with that for now.
HotLavaMann is offline   Reply With Quote
Old 05-22-2012, 04:26 PM   #13
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
very interested in your findings i have an old ipod i could do the same thing with!
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 05-22-2012, 04:55 PM   #14
Nitro
Nitro's Avatar
Drives: 2013 Firestorm Scion FR-S
Does anybody know if the built in USB near the shifter connects to the stock radio via USB or a proprietary connector. I want to put an aftermarket unit in and it would be nice if I could use the built in USB
Nitro is offline   Reply With Quote
NAV Radio suggestions Dadhawk Electronics | Audio | NAV | Infotainment 20 07-31-2013 02:25 PM
Aha Radio in the Subaru BRZ Chronogps BRZ First-Gen (2012+) — General Topics 3 02-21-2012 05:52 PM
Aha Radio Streaming to BRZ borge12 BRZ First-Gen (2012+) — General Topics 25 01-18-2012 09:47 AM
does this car get a radio/CD player ? beirouty Electronics | Audio | NAV | Infotainment 12 12-03-2011 11:06 PM
No AC/Radio option? blur Scion FR-S / Toyota 86 GT86 General Forum 53 04-10-2010 06:54 AM
