Old 04-08-2015, 07:57 PM   #15
Mr_YUzU_FRS
Drives: 2015 Scion FRS RS 1.0
Not worried about the mpg because e85 is a lot cheaper than 91 so it somewhat evens out. I'm more worried about any side effects to the motor.
Mr_YUzU_FRS is offline   Reply With Quote
Old 04-08-2015, 10:20 PM   #16
Tromatic
Again, the answer to that is "none so far", and there is only one way to find out what the long-term results will be.
Old 04-09-2015, 01:07 AM   #17
Mr_YUzU_FRS
Cool. Guess im going e85 with the new uel. Will be posting update soon.
Old 09-19-2015, 05:47 PM   #18
asnatlas
Drives: 2013 - BRZ - SWP
Updates ?
asnatlas is offline   Reply With Quote
Old 09-19-2015, 10:03 PM   #19
Chad11491
Drives: 85.5 Porsche 944, '15 mustang GT PP
Originally Posted by asnatlas View Post
Updates ?
Not that I'm the OP, but I have JDL UEL, and OFT E85 and it rips. Very noticeable power difference. Mileage sucks, but it's about a buck cheaper than 93 so it evens out. I'm going with a Motoeast flex fuel kit and ecutek though. Nothing wrong with OFT, just want flex fuel so I'm not locked in to a specific fuel grade.
Chad11491 is offline   Reply With Quote
Old 09-19-2015, 10:20 PM   #20
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I've been running the same setup for a few months. What kind of mileage are you getting on E85? I've been averaging about 19 MPG. Been having some cold start issues when the temp drops into the 50's. I think I'll be switching back to 93 when AutoX season is over.
smg1138 is offline   Reply With Quote
Old 09-20-2015, 07:02 AM   #21
Chad11491
I'm getting about 19 when I'm all city, and about 26 on the highway. Before I was about 24/31.
Old 09-20-2015, 07:56 AM   #22
humdizzle
Drives: 2018 GT3 / 2015 M3
I've done a bit of reading on this as my GTR runs on e85. In short.. as long as you drive it regularly and run a tank of 91/93 thru it every couple months you will be fine.
2018 GT3 6MT
2021 M2 Comp DCT
Past: 458 Italia, R35 GTR, E36/E46/F80 M3, 335i, Scion FRS
humdizzle is offline   Reply With Quote
Old 09-21-2015, 02:26 PM   #23
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
What if I've been running e85 for 90% of the time. As soon as I hit 1k miles I swapped to e85. Now I'm at 13,6xx. So basically my car has only seen 1k miles of 93. I have no issues but should I switch back to 93 to be on the safe side?
Old 09-21-2015, 07:23 PM   #24
humdizzle
yeah i would. The real key is driving it regularly though. When you let it sit for weeks the e85 draws moisture out of the air, and it condenses as water at the bottom of the tank.
how are you driving it year round in nyc? you don't have any cold start issues in the dead of winter?
The Following User Says Thank You to humdizzle For This Useful Post:
NyC Zn6 (09-21-2015)
Old 09-21-2015, 07:34 PM   #25
NyC Zn6
NyC Zn6's Avatar
I don't drive my 86 for the winter it gets garaged Nov to march. Yea I get the cold start issue in fall when temp gets low.
Old 09-21-2015, 07:58 PM   #26
kch
Senior Misanthrope
kch's Avatar
Yeaaaahhhhh, it's probably not a great idea to let E85 sit for 5 months.
The Following 3 Users Say Thank You to kch For This Useful Post:
humdizzle (09-21-2015), NyC Zn6 (09-22-2015), RustySocket (09-21-2015)
Old 09-21-2015, 11:08 PM   #27
Ashikabi
Ashikabi's Avatar
No problems with e85 BUT out of the 6 months ice been using it, I have yet to get 85% ethanol.best I've had is 80% so I would not run a tune for 85% without flex fuel. If it's for 70% should be fine to my knowledge
Old 09-22-2015, 09:36 AM   #28
NyC Zn6
NyC Zn6's Avatar
Before it gets stored I run down the tank as low as I can go. I start the car 3 to 5 times a week and I let it run for 10 min or so. I fill up a 2 gallon canister with e85 for March when it returns to the road.
DRL problems kk808hi Cosmetic Modification (Interior/Exterior/Lighting) 2 09-27-2014 12:33 AM
ACT 6 Pug Problems, anyone have it like me? kombatlion Engine, Exhaust, Transmission 12 08-06-2014 11:30 AM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
A few problems...but how bad are they? deedz Issues | Warranty | Recalls / TSB 20 07-21-2013 02:27 AM
Gas Problems Kelbyat07 Issues | Warranty | Recalls / TSB 3 04-20-2013 09:21 PM
