Old 07-30-2014, 10:41 AM   #1
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
ACT 6 Pug Problems, anyone have it like me?
I bought this clutch and used it for 4 months I dont circuit racing mostly street and drag and not more than 2 times since the clutch maybe 24 pases on 1/4 mile.
kombatlion is offline   Reply With Quote
Old 07-30-2014, 10:43 AM   #2
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
Bend forks!
Old 07-30-2014, 10:59 AM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Bent forks can indicate that the pressure plate was being overextended.
Old 07-30-2014, 09:29 PM   #4
arghx7
Drives: car
You do know that puck clutches are not built to last right?
arghx7 is offline   Reply With Quote
Old 07-31-2014, 02:33 AM   #5
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
6 pugs that's a lot of wrinkle faces!
The Following 2 Users Say Thank You to OICU812 For This Useful Post:
Hyper4mance2k (07-31-2014), STV3 (08-06-2014)
Old 07-31-2014, 03:50 AM   #6
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
It's 6 PUCKS by the way
Mad1723 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mad1723 For This Useful Post:
Hyper4mance2k (07-31-2014), Jason@DSG (08-04-2014)
Old 08-06-2014, 10:16 AM   #7
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
So how do I fix that bro?
Old 08-06-2014, 10:17 AM   #8
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
How do I fix that bro, my car still grinding 4th gear above 5000 revs when engaging????
I just install same but new clutch kit.
Old 08-06-2014, 10:54 AM   #9
Sportsguy83
Drives: Limited BRZ
To not overextend the clutch need to adjust clutch grab point so its low, you do that adjusting the pedal and/or adding a clutch pedal stopper.
Grinding a gear with brand new clutch, seems synchros have gone bad.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
kombatlion (08-06-2014)
Old 08-06-2014, 11:07 AM   #10
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
So the pedal lower to the firewall?
Yes I believe that the synchros are bad to bro...
Old 08-06-2014, 11:09 AM   #11
Sportsguy83
Drives: Limited BRZ
Yes, pedal lower, so that the clutch grab point is close to the bottom of the clutch travel, and that way you only extend the clutch forks the necessary amount and not more.
Old 08-06-2014, 11:13 AM   #12
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
You are the man, like a mountain of 86 knowledge, gracias!
The Following User Says Thank You to kombatlion For This Useful Post:
Sportsguy83 (08-06-2014)
Old 08-06-2014, 11:30 AM   #13
Luis_GT
If you can't find the DIY
http://www.ft86club.com/forums/showthread.php?t=8040
BRZ/FRS problems... jdmgevo Issues | Warranty | Recalls / TSB 19 08-07-2014 10:54 AM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
Gas Problems Kelbyat07 Issues | Warranty | Recalls / TSB 3 04-20-2013 09:21 PM
No CEL problems here BRZranger Issues | Warranty | Recalls / TSB 41 12-08-2012 01:36 PM
Do you think this car is going to have some problems? Huss Scion FR-S / Toyota 86 GT86 General Forum 45 03-21-2012 01:48 PM
