Drives: 2015 BRZ Limited
WTB: intake to PCV elbow
Long story short, I had a Supertek drop in kit but upgraded to a Grimmspeed intake. However my father in law, in an attempt to clean up the garage, threw away the stock intake pipe. I need the PCV elbow from that intake pipe to bridge between the Grimmspeed hump hose connector and the stock PCV pipe. If anyone has this piece and is willing to sell then please let me know how much you want for it, as it seems that Subaru don't sell that one part on it's own, only as part of the intake pipe.
Fingers crossed and thanks
2015 DGM BRZ/Gruppe-S UEL/Gruppe-S Overpipe/Invidia N1 Catback/AEM Strut/TEIN Street Basis/Cusco AOS Last edited by dar3d3vil; 04-06-2015 at 08:08 PM. |
#2 |
NVM. I found at alternative at a local hardware store that seems to work just as well.
2015 DGM BRZ/Gruppe-S UEL/Gruppe-S Overpipe/Invidia N1 Catback/AEM Strut/TEIN Street Basis/Cusco AOS |
#3 |
Drives: 2013 Ultramarine Scion FRS MT
#4 |
I found some nylon 1/2 inch to 1/2 inch PEX pipe hot water elbows at Lowes, its the same diameter as the stock one as I took the extra pipe piece from the Grimmspeed install with me to test. With the spring clamps it locks in nice and tight. They're rated for household hot water lines, so I figured that they'd be good enough for the PCV line as it only really handles the emissions. They also make a copper one, but I figured that I'd try the nylon option first, especially as it only cost $1.99 for 2 pieces. The Grimmspeed intake calls for you to attach the stock PCV elbow to a hump pipe, they provide a second spring clamp to go with it. This little piece did the same job as the PCV elbow without needing to buy the whole intake pipe again from Subaru (which retails for around $65).
| ECM Pin Connector | simpleisbest | Software Tuning | 19 | 01-18-2015 02:13 AM |
| What's this connector ? | mashal | Electronics | Audio | NAV | Infotainment | 5 | 12-10-2013 01:13 AM |
| Third connector on headlights? | FastLap | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 05-15-2013 01:36 AM |
| Help, what connector is this? | Hayashi | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 02-26-2013 01:39 AM |
| VSS Connector | AlexTheGreek | Engine, Exhaust, Transmission | 15 | 02-02-2013 12:12 PM |
