Old 04-06-2015, 06:58 PM   #1
dar3d3vil
dar3d3vil's Avatar
Drives: 2015 BRZ Limited
OFT reflash post intake install?
I'd flashed my car with the stage 1 93 flash when I had the stock air intake. I've now switched over to a Grimmspeed intake, but still using stock header, exhaust etc. Do I need to reflash the stage one again, or would I be ok keeping the same flash on as I had prior to installing the CAI?
2015 DGM BRZ/Gruppe-S UEL/Gruppe-S Overpipe/Invidia N1 Catback/AEM Strut/TEIN Street Basis/Cusco AOS
dar3d3vil is offline   Reply With Quote
Old 04-06-2015, 07:07 PM   #2
JB86'd
JB86'd's Avatar
Drives: JAWS
You don't need to reflash, it will adapt. BUT there is a Grimmspeed intake OFT tune that you'd be much better off flashing, maybe email the Openflash guys if nobody here chimes in.
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
dar3d3vil (04-06-2015)
Old 04-06-2015, 07:38 PM   #3
dar3d3vil
dar3d3vil's Avatar
Thanks, I did a couple of searches now that I knew of the existence of a tune for the Grimmspeed intakes. I found the thread and seemingly found the files needed. I'm going to take a look through RomRaider, but I'm a bit green on that so I might not risk it.
If there is anyone who sees this thread that has the 93oct stage 1 Grimmspeed flash for a 2015 (i know, bloody specific right?) and they would be willing to share then that would be greatly appreciated. I've also emailed the OFT guys directly to see if they have it to hand.
Thanks again for the info though, I wouldn't have thought that they'd have had a specific flash for that intake.
Old 04-06-2015, 08:36 PM   #4
jflogerzi
jflogerzi's Avatar
Mainly you need to re-scale your maf for the new intake. There are guides on the forums to do this.
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 04-06-2015, 08:39 PM   #5
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
You would want to a Stage 1 map specifically intended for the Grimmspeed intake. We have such maps free and available upon request for all OFT users. Just email me your OFT serial number and your Calibration ID and I can send it to you.
Cheers
shiv
Shiv@Openflash is offline   Reply With Quote
The Following 5 Users Say Thank You to Shiv@Openflash For This Useful Post:
Akya2120 (08-04-2016), dar3d3vil (04-06-2015), JDsThatGuy (04-06-2015), Koa (04-07-2015), zc06_kisstherain (04-06-2015)
Old 04-06-2015, 08:48 PM   #6
dar3d3vil
dar3d3vil's Avatar
I found a couple, specifically one by KOA. I haven't played with RomRaider before so I'm a little dubious of playing with things like that until I get a bit more experience. I know KOA also uploaded a 91oct flash for the Grimmspeed in a different thread.
Cheers
shiv
Shiv, thank you I'll get the serial and CalID as soon as possible and email them to you.
Old 04-06-2015, 09:31 PM   #7
dar3d3vil
dar3d3vil's Avatar
Just sent a PM Shiv, if thats not the correct info just let me know.
Old 04-06-2015, 09:33 PM   #8
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Cheers
shiv
what a great service!
one of reason that i went with OFT not other platform.
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Shiv@Openflash (04-06-2015)
Old 04-06-2015, 09:37 PM   #9
Shiv@Openflash
Drives: 2013 FRS
No PMs please. Just email me the info at shiv@openflashperformance.com
Old 04-06-2015, 09:40 PM   #10
dar3d3vil
dar3d3vil's Avatar
Sent via email, apologies, I didn't have your email at the time. Should have realized it would basically be like your username.
Old 04-06-2015, 11:06 PM   #11
Shiv@Openflash
Drives: 2013 FRS
No prob. I just emailed you the maps you requested
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Old 04-06-2015, 11:15 PM   #12
Krazy
Krazy's Avatar
Drives: FR-s
Hey shiv, do you guys have any other specific tunes? Like drop in air filter, exhaust Etc?
Krazy is offline   Reply With Quote
Old 04-06-2015, 11:26 PM   #13
jaf89f
jaf89f's Avatar
Drives: Raven MT
@Shiv@Openflash Is there a 93 oct. grimmspeed intake tune as well, or just 91? If not would I just need to change the MAF scaling in the standard stage 1 93 tune, or are there additional tables I would need to modify? Thanks in advance!
OpenFlash Tablet Tune v2.06 E85 Stage 1 - Grimmspeed Intake, Strut Tower Brace & Master Cylinder Brace - MTEC Clutch & Shifter Springs - TRD Quickshifter - cQuartz Finest Paint Protection Coating - and more to come...
jaf89f is offline   Reply With Quote
Old 04-06-2015, 11:43 PM   #14
dar3d3vil
dar3d3vil's Avatar
Amazing, thank you. I wasn't expecting anything until tomorrow at the earliest. I'll do the flash first thing in the morning. Again, many, many thanks.
The Following User Says Thank You to dar3d3vil For This Useful Post:
Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install The Sentinel Engine, Exhaust, Transmission 92 03-09-2015 05:20 PM
Reflash after adding intake tube w/ OFT tune? ghost86 Software Tuning 2 03-27-2014 10:13 AM
Modified Magzine story: AEM intake and ECUTek reflash by OnPoint Dyno l8apexr CANADA 3 07-23-2013 10:55 AM
Tips and Tricks: Disconnecting the Battery Necessary Post Intake Install? ScionFR-S Engine, Exhaust, Transmission 8 12-17-2012 05:39 AM
ECU reset post aFe Takeda CAI install APS86 Engine, Exhaust, Transmission 4 12-16-2012 10:49 PM
