Old 04-06-2015, 02:20 PM   #43
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
My Thoughts:
He burnt out the clutch by holding it while trying to burnout like that Corvette, just held it in (maybe he's new to manual?) riding it, smacked/kicked clutch trying to shift instead of holding it in only during shift periods. This hurts the pressure plate.
My first clutch I burnt in 15min. It was kind of old, but still. I just rode it.
Old 04-06-2015, 02:40 PM   #44
Valentino
Drives: GT86 2014
What I meant about any thoughts, suggestion, or opinions is about the oil on the back of the crankshaft plat sensor.
I past the point of trying to figure what happened, and now I'm trying to fix the problem.
But thank you for your inputs. Taking it to the dealer is not an option.
Valentino is offline   Reply With Quote
The Following User Says Thank You to Valentino For This Useful Post:
nivek111070 (04-06-2015)
Old 04-06-2015, 04:11 PM   #45
fika84
fika84's Avatar
Originally Posted by Valentino View Post
After removing the crankshaft timing plate as you can see found some oil.
It doesn't seem it's an engine or transmission oil. The color of the oil is light red and smells like an automatic transmission oil. The stock transmission oil color was gold.
Is this normal? Any suggestions?
I would think that it would just be dirty engine oil from all the crap it was subjected to, meaning bad seal on the engine block. . Did it look like any oil was coming out of the transmission? It would be pretty hard/impossible without total submersion for any other sort of oil to get into the bell housing from the street... Does the crankshaft have damage on it as well?
fika84 is offline   Reply With Quote
Old 04-06-2015, 04:40 PM   #46
Valentino
Drives: GT86 2014
Doesn't seem that any oil came out of the transmission.
Don't think the metal ring is damaged, because the engine starts normally (no miss fire, or hesitation)
Old 04-06-2015, 05:21 PM   #47
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Looks like when your friend smoked your clutch all the heat smoked the rear main seal. You might was well replace it while you do everything else. Hopefully the heat didn't do any damage to the crankshaft. You need a new flywheel, too. I'm not sure if all the heat checking will come out with a resurface. That's some serious abuse.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 04-06-2015, 05:36 PM   #48
Valentino
Drives: GT86 2014
Yes. i think i have to replace the rear main seal since I'm already there. I took a quick look at the repair manual, and it looks like an easy job.
I already have a new clutch kit next to me waiting be installed .(I put everything on hold till i solve this oil leak.)
Old 04-06-2015, 06:06 PM   #49
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I'm willing to bet that your oil leak is because your engine's rear main seal is borked. It'll probably need replaced. I don't know what all that entails, but it definitely won't be fun or cheap.
Bobblehead is offline   Reply With Quote
Old 04-06-2015, 11:03 PM   #50
Turdinator
Señor Member
Turdinator's Avatar
A little off topic but why not?
1974 TA22 Celica
2013 86 GT
Old 04-07-2015, 03:55 AM   #51
Valentino
Drives: GT86 2014
First. I like and i enjoy working on cars,bikes, and boats. (I like fixing things my self).
Second, the dealer wont instal any after market parts, and if they did the job it wont be under warranty.
Turdinator (04-07-2015)
Old 04-07-2015, 04:36 AM   #52
Just lube leaking out of the pilot bearing. Replace it with your clutch. Leave the rear main seal alone. Not a hint of leakage from it. If there was you would have a greasy soggy mess all in your bell housing. All you have is dust.
Valentino (04-07-2015)
Old 04-07-2015, 05:44 AM   #53
steve99
Drives: FT86
Its it just me or do those cracks in casting look suspect ?
Old 04-07-2015, 06:09 AM   #54
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yes, unless he recently replaced the engine oil, that oil behind the seal looks rather clean. I would've thought that if it was leaking engine oil it would be a lot messier....
Fizz is offline   Reply With Quote
Old 04-07-2015, 08:49 AM   #55
fika84
fika84's Avatar
You could be right, but wouldn't you want to replace the main seal while you can easily access it (easy replacement)? I would lose my mind if I wasn't 100% sure after I put everything back together.
Old 04-07-2015, 08:51 AM   #56
fika84
fika84's Avatar
Looks like any normal casting to me, would help if it was cleaner
weird noise from my clutch stevemp5 Issues | Warranty | Recalls / TSB 3 08-12-2014 04:58 PM
weird noise from clutch pedal area... mongiamc10 Issues | Warranty | Recalls / TSB 5 08-08-2014 06:04 PM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
