#85 | |
Frosty Carrot
Drives: The Atomic Carrot
![]() It builds pressure then pushes the parts up in one-shot. High force (40 - 200G) and short duration (5 - 20 ms). For milder shock testing where you're not going to have fixture or parts resonance... you can use a shaker table (this one is using a slip table). ![]() Doing a control arm would be complicated. You'd need to fix both 2 of 3 pivot points and apply the shock load on the third (just like with the Instron testing above). It's probably cheaper to just throw it on a race car and beat on it.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
| The Following User Says Thank You to Shankenstein For This Useful Post: | CSG Mike (03-30-2015) |
#86 |
Junior
Drives: a car
Wouldn't be cheaper if you crashed because of the product...lol
#87 |
Frosty Carrot
For Mike's situation, you may have luck finding a giant pendulum (like the charpy or izod) impact tester.
![]() Many universities and labs will have these, and it's an easy way to wang on stuff in a controlled manner.
#88 | |
Drives: Subaru BRZ
The structural designer in me loves the truss look of your design. makes me feel better compared to the other ones.
2014 WRB BRZ
#89 | |
That's exactly what I had in mind. |
#90 | |
Drives: 2014 FR-S 6MT Whiteout
[ame="https://www.youtube.com/watch?v=x_a-XjdGV_s"]MIL-STD-901D shock test, 20 feet - YouTube[/ame]
#91 | |
Kuruma Otaku
Aluminum, especially the aerospace grades, can outperform titanium in certain aplications. Between 6061 and 7075... 2024?
Because titanium. |
#92 | |
Drives: BRZ, STI, GT350R, Supra, 987.2
I'm away on business for my day job. I will write up our findings when I return home on Saturday. |
| The Following User Says Thank You to VerusEric For This Useful Post: | Dimman (04-02-2015) |
#93 |
Alright so after Sunday's test, we found out that the adjuster fails prematurely when cyclically loaded. We believe we actually instigated the failure slightly by heating up the unit by loading it at 10 Hz (friction/movement builds heat). Regardless, we don't believe it would have reached our goal of 50,000 cycles. It did last fairly long though and in most cases, the unit wouldn't have failed in our opinion. It would have still lasted multiple seasons but not long enough for us to take it to production.
We have already machined up replacement adjusters and ordered high strength alloy rod ends. This will add about 0.2 lbs per LCA, however, we have effectively increased the strength of these two pieces by 75%. Realistically, we don't need to re-test, but we want to. On top of that, we are going to test the OEM unit and see how it fairs in the same tests we are testing our LCA in. The person who is testing said he can probably get it on the bench next weekend. Thanks for your patience, Eric |
| The Following 7 Users Say Thank You to VerusEric For This Useful Post: | 2much (04-04-2015), Black Tire (04-05-2015), civicdrivr (04-08-2015), D_Thissen (04-04-2015), Jonsey (04-04-2015), MINOCIN (04-06-2015), Shankenstein (04-04-2015) |
#94 | |
That Guy
Drives: 2013 asphalt FRS MT
#95 | |
Frosty Carrot
Even when threads are "helped" with a glass bead blast, hardening, or heat treatment... there's always stress concentration due to shape. Many times, you've got residual stresses too. Fatigue testing will find the weak point and initiate a crack. At this point, the crack is its own stress concentration. The material's toughness dictates how much concentration... and it's just a matter of cycles before the part is #rekt. Thanks for posting the news publicly. There is no failure in R&D... we follow the cycle: test --> anomaly --> problem definition --> root cause --> corrective action --> re-test It's only a failure once you've put it in the field, and it seems like you guys are going the extra mile to ensure customer satisfaction.
| The Following 3 Users Say Thank You to Shankenstein For This Useful Post: |
#96 |
Because compromise ®
Drives: Red Herring
Fixed.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Calum (04-05-2015) |
#97 |
Frosty Carrot
Fixed:Fixed: ... you guys are going the extra 1.073 kilometers to ensure customer satisfaction.
![]() (50,000 of 75,000 shocks)
#98 | |
I should also point out we are testing this at around 4 degrees of negative camber. This is to stress it in the absolute worst case we can. Since we need to prove that it broke.
| The Following 4 Users Say Thank You to VerusEric For This Useful Post: |
| Verus Engineering Rear Wing Development | VerusEric | Tracking / Autocross / HPDE / Drifting | 203 | 07-05-2021 09:15 AM |
| Verus' Shop BRZ - Development Thread | VerusEric | Member's Car Journals | 266 | 12-19-2019 04:12 PM |
| FT-86 SpeedFactory Diffuser by Verus - Complete Aero Solution | FT-86 SpeedFactory | Cosmetic Modification (Interior/Exterior/Lighting) | 574 | 09-15-2019 10:10 AM |
| FT-86 SpeedFactory Turbo Kit - Development and Testing | FT-86 SpeedFactory | Forced Induction | 271 | 09-19-2017 11:07 PM |
| Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering | VerusEric | Cosmetic Modification (Interior/Exterior/Lighting) | 25 | 09-22-2016 01:41 AM |
