Old 04-05-2015, 07:37 PM   #1
thegoofyweirdo
thegoofyweirdo's Avatar
Temperature inside car
Hey guys,
Came to this forum to find info about my car BEFORE i bought it and love that i picked up a BRZ! So thanks for all the guidance and NON hostile environment.
Question: I live in Phoenix, Arizona and it's not yet summer, but already i'm noticing the car inside gets REALLY hot REALLY fast. Has anyone else felt the same thing? I have complete tint on the car, ceramic 80% on the front windshield along with 20%/35% IR film everywhere else. Could be that it's a tiny car with 2 BIG windows?
Thanks guys.
2013 Subaru BRZ Limited - Lightning Red
- Suntec Film 6 mil, OEM FRS Mud Flaps, Diode Dynamics Fogs, Yellow Lamin-x, noise maker delete, LED Footwell lighting w/dome light, LED bulbs EVERYWHERE lol
thegoofyweirdo is offline   Reply With Quote
Old 04-05-2015, 07:43 PM   #2
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
It's a small interior as well, so it heats up quickly. Black dashboard and seats don't do it any favors. Sunshades help a lot though, so get one that's fitted for the front windshield and it'll help lower temperatures a lot.
Lelantas is offline   Reply With Quote
The Following User Says Thank You to Lelantas For This Useful Post:
SirBrass (04-06-2015)
Old 04-05-2015, 07:44 PM   #3
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
If you mean while driving Probably need to turn recirculation on if you haven't. Some heat still comes from the vents and you'll really notice in the summer.
00NissanNinja is offline   Reply With Quote
The Following User Says Thank You to 00NissanNinja For This Useful Post:
nivek111070 (04-06-2015)
Old 04-05-2015, 07:44 PM   #4
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
I think because your scalp is very close to the ceiling
Speed2th is offline   Reply With Quote
Old 04-05-2015, 07:51 PM   #5
ryoma
ryoma's Avatar
I use a covercraft sun shade and it works wonders.
The Following User Says Thank You to ryoma For This Useful Post:
Wolfdogelite (04-08-2015)
Old 04-05-2015, 07:53 PM   #6
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
Yep, that's the one I use too. I believe they also make the Subaru OEM sunshade; only difference is the OEM one comes with a bag and has the Subaru logo on it.
Old 04-05-2015, 09:06 PM   #7
thegoofyweirdo
awesome, thanks guys. Ya it's when i come back to the car after it sitting for a few hours. I drive around to clients for a living so it's "in and out" of the car a lot. You think any sound deadening/insulation, especially on the roof, would help?
Old 04-05-2015, 09:08 PM   #8
WHTEBRZ
Drives: BRZ Limited
Louvers keep the car noticeably cooler
WHTEBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to WHTEBRZ For This Useful Post:
chaoskaze (04-06-2015), Dadhawk (04-06-2015)
Old 04-05-2015, 09:20 PM   #9
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
This is one of the reasons to use the auto climate control.
Chad86 is offline   Reply With Quote
Old 04-05-2015, 10:33 PM   #10
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Sunshade across windshield helps A TON when parked. Keep a window cracked open if safe area. Buy a quality sunshade, not a cheap see through one.
The back window allows the sun to bake in too - if its really bad and tint isn't helping, try louvers.
ashtray is offline   Reply With Quote
Old 04-05-2015, 10:42 PM   #11
Poodles
Drives: 2015 Series.Blue
I try to park facing the sun and use my OEM sunshade. Helps a ton.
Old 04-06-2015, 02:11 AM   #12
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
If you are talking about heat coming from the vents when the fan, heater, and A/C is off, that's because the last setting before you turned it off was set to a high temperature.
Turn it back on, lower the temp to MIN, wait several seconds, then turn the system off.
carma143 is offline   Reply With Quote
Old 04-06-2015, 09:34 AM   #13
nivek111070
Drives: 2014 GB Scoobie BRZ
i get tons of engine heat in mine if the a/c isn't on recirc. air or not
nivek111070 is offline   Reply With Quote
Old 04-06-2015, 09:44 AM   #14
Not surprised since we are talking about plenty of glass + black interior. Sure fire formula for a hot car.
As others have said, when parked about the only solution is a windshield screen, tint and if you can afford them, louvers. The back glass is as big an area as the front so its a huge contributor.
You can also get the window edge thingies (don't know what they are called) that let you leave the windows cracked but prevent easy entry by weather or persons to the car.
What temperature do you put A/C on? FRiSson New England 23 06-13-2016 08:55 AM
The need for an oil cooler when going FI (Temperature Data Inside) spdbydesign Forced Induction 145 11-05-2015 12:02 PM
E85 and oil temperature jvincent Engine, Exhaust, Transmission 11 11-12-2014 08:53 PM
Color Temperature FRSure Cosmetic Modification (Interior/Exterior/Lighting) 14 01-03-2014 11:19 PM
Temperature not reading below 0 BrewCity-FR-S Scion FR-S / Toyota 86 GT86 General Forum 6 01-22-2013 10:05 AM
