Old 04-01-2015, 11:44 PM   #267
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by Turdinator View Post
This is the first I have heard of the cylinders receiving different amounts of fuel. I know the ignition timing is different between the cylinders. Are the cylinder fuel trims defined in romraider?
Thank you for asking this as I was unaware as well. Could someone point us in a direction of the map that shows different fuel trims per cylinder? Or a thread discussing this? I was unaware oems were doing this.
VerusEric is offline
The Following User Says Thank You to VerusEric For This Useful Post:
Turdinator (04-01-2015)
Old 04-02-2015, 01:48 AM   #268
OkieSnuffBox
Drives: '23 BRZ Limited
Theoretically they do, but it's small enough that OEMs still use one O2 sensor per bank to figure things out.
Only big $$$$$$ race teams are monitoring each individual cylinder.
OkieSnuffBox is offline
Old 04-02-2015, 09:21 AM   #269
Tim Radley
Drives: None
I'm not aware of any threads talking about it but most oem ecu's on a performance car i've ever measured in this way runs different cylinder maps or at least offset tables for each cylinder for both ignition and fuel. This is why aftermarket ecu's with a single table for fuel and also for ignition often run pretty badly at idle and transient compared to oem.
I'm running a Motec ecu on my GT86 with 4 lambda's (one per header) and its very clear just how bad the intake and exhaust paths are and the amount of difference required. Its not a constant offset either, amounts cross over. If you measure each intake runner and exhaust runner length they all have a different total overall tuned length so it's not surprising at all.
When will pricing and completion date be confirmed on this?
Tim Radley is offline
The Following User Says Thank You to Tim Radley For This Useful Post:
Turdinator (04-05-2015)
Old 04-02-2015, 10:11 AM   #270
Kodename47
Kodename47's Avatar
Drives: UK GT86
AFAIK the stock setup only varies the ignition timing per cylinder, and even that is just cylinders A + B that are equally retarded IIRC (might be C and D). ECUtek has per cylinder fueling trims in the RaceROM upgrade but they are all the same, leading me to believe that this is how it is stock.
Is there any way you can publish the data on the cylinders and what you found?
OT but Tim are you in the UK? I guess if you're running a Motec then you've a little more than a standard car.
.: Stealth 86 :.
Kodename 47 DJ:
Kodename47 is offline
Old 04-02-2015, 10:39 AM   #271
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
I just saw this thread... subb'd!
I volunteer as tribute!
^GT5 Replay Photo Mode^
SirBrass is offline
Old 04-02-2015, 11:10 AM   #272
Tim Radley
Drives: None
Yes i am in the UK. I wouldn't want to publish my map data as it takes a lot of time and money to work these things out. I've got £1600 (2400usd) in lambda alone and it how i earn my living. What i will say is the trim tables need to be more than a single value for each cylinder.
Car is not standard no. It has an NA build now and i'm about to do a turbo build. Dead keen to find a proper intake manifold though as I want to run loads of boost and stumbled across this thread. Some awesome products appearing now for this car at last
Old 04-02-2015, 12:03 PM   #273
Kodename47
Kodename47's Avatar
Drives: UK GT86
I was more interested in what you had found on the stock setup, rather than how you improved on it
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-02-2015, 12:30 PM   #274
Tim Radley
Drives: None
Didn't do anything with the stock setup unfortunately. Took the car to the racetrack straight from the showroom to see what it was like then brought it back and put a Motec on it.
Old 04-02-2015, 02:29 PM   #275
flippy
flippy's Avatar
Drives: 2013 Firestorm Scion FRS
@Dimman, we definitely sucked the air through, no blowing.
I told myself I wasn't going to post anymore of the intake manifold until it was finished but I can't help myself. This is sexy...
It's so beautiful
Originally Posted by bdanisi View Post
Can we close this thread it wasn't intended to become vaginal pun fodder
flippy is offline
Old 04-02-2015, 03:22 PM   #276
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
All this talk about sucking and blowing, with all these sexy pictures makes me wonder why this hasn't been labeled NSFW.
DustinS is offline
The Following 3 Users Say Thank You to DustinS For This Useful Post:
Captain Snooze (04-02-2015), OkieSnuffBox (04-02-2015), wparsons (04-05-2015)
Old 04-02-2015, 07:30 PM   #277
Calum
That Guy
Drives: 2013 asphalt FRS MT
Can you share any more of what was done to the car and what the end result was power wise? Or was it just a motec and your own special sauce to get more out of the stock hardware?
I was aware of the unequal length of the exhaust manifold, where do the variances in the tuned length of the intake runners come from?
Calum is offline
The Following User Says Thank You to Calum For This Useful Post:
Blu-by-U (04-02-2015)
Old 04-03-2015, 02:38 AM   #278
Tim Radley
Drives: None
If you measure the intake manifold runners there is over an inch difference in length between shortest and longest. Cylinder 4 is a straight run I one plane but the others are all on a dog leg with cylinder 1 being the worst and longest
The Following 3 Users Say Thank You to Tim Radley For This Useful Post:
Blu-by-U (04-03-2015), Calum (04-03-2015), Dimman (04-03-2015)
Old 04-03-2015, 09:16 AM   #279
ISDriven
ISDriven's Avatar
Drives: chill
I'll take mine with a "blued" finish please!
ISDriven is offline
Old 04-04-2015, 02:54 PM   #280
VerusEric
VerusEric's Avatar
We had our suspicions that the OEM intake manifold doesn't distribute air evenly to each cylinder. Believing that the OEM ECU does not correct for this (which still seems like a viable assumption), we plan to pick up some power by balancing the cylinder distribution some while improving the overall efficiency through reduced flow losses. That was the goal at least.
I have no doubt that you can pick up significant power by optimizing cylinders. There is a great video on youtube detailing how NASCAR does this and they pick up multiple percentages of power. I just didn't think OEMs were to that point yet.
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 236 06-20-2019 01:42 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold viking Engine, Exhaust, Transmission 6 09-23-2014 11:08 PM
Oil on/around Intake Manifold Wepeel Issues | Warranty | Recalls / TSB 2 05-12-2014 11:40 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
