Old 04-02-2015, 01:48 AM   #267
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by NotEric6 View Post
Thank you for asking this as I was unaware as well. Could someone point us in a direction of the map that shows different fuel trims per cylinder? Or a thread discussing this? I was unaware oems were doing this.
Theoretically they do, but it's small enough that OEMs still use one O2 sensor per bank to figure things out.
Only big $$$$$$ race teams are monitoring each individual cylinder.
OkieSnuffBox is offline
Old 04-02-2015, 10:11 AM   #268
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Tim Radley View Post
I'm not aware of any threads talking about it but most oem ecu's on a performance car i've ever measured in this way runs different cylinder maps or at least offset tables for each cylinder for both ignition and fuel. This is why aftermarket ecu's with a single table for fuel and also for ignition often run pretty badly at idle and transient compared to oem.
I'm running a Motec ecu on my GT86 with 4 lambda's (one per header) and its very clear just how bad the intake and exhaust paths are and the amount of difference required. Its not a constant offset either, amounts cross over. If you measure each intake runner and exhaust runner length they all have a different total overall tuned length so it's not surprising at all.
When will pricing and completion date be confirmed on this?
AFAIK the stock setup only varies the ignition timing per cylinder, and even that is just cylinders A + B that are equally retarded IIRC (might be C and D). ECUtek has per cylinder fueling trims in the RaceROM upgrade but they are all the same, leading me to believe that this is how it is stock.
Is there any way you can publish the data on the cylinders and what you found?
OT but Tim are you in the UK? I guess if you're running a Motec then you've a little more than a standard car.
.: Stealth 86 :.
Kodename 47 DJ:
Kodename47 is offline
Old 04-02-2015, 10:39 AM   #269
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
I just saw this thread... subb'd!
I volunteer as tribute!
^GT5 Replay Photo Mode^
SirBrass is offline
Old 04-02-2015, 12:03 PM   #270
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes i am in the UK. I wouldn't want to publish my map data as it takes a lot of time and money to work these things out.
I was more interested in what you had found on the stock setup, rather than how you improved on it
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-02-2015, 02:29 PM   #271
flippy
flippy's Avatar
Drives: 2013 Firestorm Scion FRS
@Dimman, we definitely sucked the air through, no blowing.
I told myself I wasn't going to post anymore of the intake manifold until it was finished but I can't help myself. This is sexy...
It's so beautiful
Originally Posted by bdanisi View Post
Can we close this thread it wasn't intended to become vaginal pun fodder
flippy is offline
Old 04-02-2015, 03:22 PM   #272
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
All this talk about sucking and blowing, with all these sexy pictures makes me wonder why this hasn't been labeled NSFW.
DustinS is offline
Old 04-02-2015, 07:30 PM   #273
Calum
That Guy
Drives: 2013 asphalt FRS MT
Yes i am in the UK. I wouldn't want to publish my map data as it takes a lot of time and money to work these things out. I've got £1600 (2400usd) in lambda alone and it how i earn my living. What i will say is the trim tables need to be more than a single value for each cylinder.
Car is not standard no. It has an NA build now and i'm about to do a turbo build. Dead keen to find a proper intake manifold though as I want to run loads of boost and stumbled across this thread. Some awesome products appearing now for this car at last
Can you share any more of what was done to the car and what the end result was power wise? Or was it just a motec and your own special sauce to get more out of the stock hardware?
I was aware of the unequal length of the exhaust manifold, where do the variances in the tuned length of the intake runners come from?
Calum is offline
Old 04-03-2015, 09:16 AM   #274
ISDriven
ISDriven's Avatar
Drives: chill
I'll take mine with a "blued" finish please!
ISDriven is offline
Old 04-04-2015, 02:54 PM   #275
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
If you measure the intake manifold runners there is over an inch difference in length between shortest and longest. Cylinder 4 is a straight run I one plane but the others are all on a dog leg with cylinder 1 being the worst and longest
We had our suspicions that the OEM intake manifold doesn't distribute air evenly to each cylinder. Believing that the OEM ECU does not correct for this (which still seems like a viable assumption), we plan to pick up some power by balancing the cylinder distribution some while improving the overall efficiency through reduced flow losses. That was the goal at least.
I have no doubt that you can pick up significant power by optimizing cylinders. There is a great video on youtube detailing how NASCAR does this and they pick up multiple percentages of power. I just didn't think OEMs were to that point yet.
VerusEric is offline
Old 04-04-2015, 03:16 PM   #276
himbo
Drives: Lightening Red BRZ Ltd.
Has this info changed the development or schedule of this manifold?
himbo is offline
Old 04-04-2015, 03:20 PM   #277
VerusEric
VerusEric's Avatar
No, nothing has changed.
Old 04-04-2015, 09:13 PM   #278
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
So long, I've been looking too hard, I've been waiting too long
Sometimes I don't know what I will find, I only know it's a matter of, time
When you need an intake, when you need an intake
It feels so right, so much power, I need to know if you need it too
Maybe I'm wrong, won't you tell me if I'm accelerating too strong
This wallet of mine has been hurt before, this time I want to be sure
I've been waiting for a manifold like you to come into my life
I've been waiting for a intake like you, your engine will survive
I've been waiting for a new intake to make me feel alive
Yeah, waiting for a manifold like you to come into my life
You're so good, when we make power it's understood
It's more than a tune or KoolBRZ can say
Only Velox could make it this way
When you love your car, yeah, really love love your car
I know it's right, from the moment I floor it deep in the night
There's nowhere on earth that I'd rather be than thrashing you mercilessly
With apologies to Foreigner
[ame="https://www.youtube.com/watch?v=GOf915su9q8"]foreigner waiting for a girl like you - YouTube[/ame]
Captain Snooze is offline
Old 04-05-2015, 12:35 PM   #279
Calum
That Guy
@DeliciousTuning @moto-mike @EcuTek
Anybody know if these cylinder offset correction factors are adjustable with ECUTEK?
Calum is offline
Old 04-05-2015, 01:28 PM   #280
Kodename47
Kodename47's Avatar
Drives: UK GT86
What offset do you mean? I know that fuel and timing trims are available. They just aren't available to end users (at the moment).
.: Stealth 86 :.
Kodename 47 DJ:
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 236 06-20-2019 01:42 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold viking Engine, Exhaust, Transmission 6 09-23-2014 11:08 PM
Oil on/around Intake Manifold Wepeel Issues | Warranty | Recalls / TSB 2 05-12-2014 11:40 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
