go_a_way1
Old 04-01-2015, 11:40 PM   #1919
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Originally Posted by 0351USMC View Post
Ended up getting an ACT clutch with lightweight flywheel and lightweight pulley set. Header and overpipe can wait until after I do coilovers.
Don't forget that you'll have to update your tune once you put the exhaust mods on, so plan your mods carefully so you don't have to keep getting retuned and wasting money.
ApolloSki is offline   Reply With Quote
The Following User Says Thank You to ApolloSki For This Useful Post:
0351USMC (04-02-2015)
Old 04-02-2015, 12:01 AM   #1920
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
You don't want to see the list of things I have for you to do if throttle response is your goal....
I kinda do wanna see this list.
0351USMC is offline   Reply With Quote
Old 04-02-2015, 12:05 AM   #1921
0351USMC
0351USMC's Avatar
Retune with moto east is only $80 for "making minor changes such as intake/exhaust that does not change MAF size, injectors, displacement, or compression/cams"
Old 04-02-2015, 12:12 AM   #1922
CSG David
CSG David's Avatar
That is a fairly interesting statement.
The Following User Says Thank You to CSG David For This Useful Post:
Old 04-02-2015, 12:48 AM   #1923
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
So the total for this kit should be around 5.5 including the actual JRSC kit, optional oil cooler which I will get, dual catch cans, boost gauge, AFR gauge, and tune..
904FRSlow is offline   Reply With Quote
Old 04-02-2015, 12:51 AM   #1924
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
You don't need a boost gauge at all, and you don't really need a Afr gauge either.
ScionOfHorus is offline   Reply With Quote
Old 04-02-2015, 01:15 AM   #1925
904FRSlow
904FRSlow's Avatar
Mm true I could use an OBDII reader. Well I guess I'll be ordering the catch cans soon and then just save for everything else
Old 04-02-2015, 01:29 AM   #1926
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Isn't that bad and could cause a blown engine, a light weight clutch and a light weight fly wheel? I read it somewhere I'm just at work and too lazy to find it right now but correct me if I'm wrong, because I also would like to save you in the case that I am correct.
Alltezza is offline   Reply With Quote
The Following User Says Thank You to Alltezza For This Useful Post:
Old 04-02-2015, 01:34 AM   #1927
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
People say do one or the other but don't do both. The crank pulley mass shifts vibration resonances out of the normal engine operating range. You'll probably find threads and articles stating it doesn't as well and lightened crank pulley won't harm the engine.
You're better off doing lightened flywheel and lightened driveshaft as it'll reduce more rotational mass than the pulleys.
JDKane527 is offline   Reply With Quote
The Following User Says Thank You to JDKane527 For This Useful Post:
Old 04-02-2015, 02:02 AM   #1928
CSG Mike
CSG Mike's Avatar
I need to make a clarification here. The Jackson Rackng factory tune is locked, and Moto-East does NOT have access to the tune. They are not making minor changes to a tune they do not have access to, nor own the rights to.
Old 04-02-2015, 02:02 AM   #1929
CSG Mike
CSG Mike's Avatar
Can you forward me that quote please?
Old 04-02-2015, 02:13 AM   #1930
ScionOfHorus
I'm guessing here, but ballpark sounds like $4000 kit, $700 oil cooler, $400 dual catch can set up, leaving $400 for a tune... Doesn't seem enough, unless he finds a used kit. Minimum for a tune should be $620. (~$20 cable rental, $300 license, $300 SC tune)
So I've got roughly $5720 if he passes on the gauges. Which I think he should.
Old 04-02-2015, 02:19 AM   #1931
0351USMC
0351USMC's Avatar
http://www.ft86speedfactory.com/act-...ight-1433.html
Only the flywheel is lightweight. Thanks for the concern though.
Pulled direct from Moto-East
Bought the moto-east flex fuel kit and accompanying tune. Not going to be running the CARB tune.
The Following User Says Thank You to 0351USMC For This Useful Post:
Alltezza (04-02-2015)
Old 04-02-2015, 03:02 AM   #1932
Alltezza
Alltezza's Avatar
Wait so you can have a light flywheel and light pulley? I don't know for sure I may have said it wrong as well, just trying to look out for a fellow 86 owner
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
