Old 03-30-2015, 04:50 AM   #15
mig86
Drives: MY15 86 GTS
Originally Posted by jonboy99 View Post
How do you mean not set up to do it? You don't need to lift the motor, it's just a case of wriggling / rotating the OP to the right angle then it just slips out easily. Might be different if you are right hand drive though IIRC.
My RHD just needed the engine jacked off the mounts a little. After removing the heat shields it came out easily. Much easier than sorting that damn stud!
mig86 is offline   Reply With Quote
Old 03-30-2015, 05:22 AM   #16
Teclis
Marine Electrician
Teclis's Avatar
Drives: Toyota TRD86, 2014
Same thing happened to me when I changed my FP, I used titanium drill, to drill out the stud/bolt (pin bolt), it was hard as hell to get out, but doable.. then just replace it with a new bolt and nut
Teclis is offline   Reply With Quote
Old 03-30-2015, 09:24 AM   #17
EvoPrecision8
Drives: 2015 BRZ Sport Tech
It was my understanding that the engine had to be lifted slightly. If that's not the case I will probably just try to slip the OP out and get that stud drilled out. Thanks.
EvoPrecision8 is offline   Reply With Quote
Old 03-30-2015, 09:56 AM   #18
cnk
Drives: '13 DGM BRZ Limited
Remove the heat shielding first and it will slide out the back. Just takes some manipulation of the OP as you slide it out, but it's definitely doable.
Old 03-30-2015, 12:13 PM   #19
jonboy99
jonboy99's Avatar
Drives: Black Panda BRZ
Yep, doesn't need any force. It seems impossible at first but twist it just right and it just slides out. I didn't remove the shielding until after I'd removed it.
*edit* actually maybe I did remove the shielding first, was a while ago now.
jonboy99 is offline   Reply With Quote
Old 03-30-2015, 01:10 PM   #20
OmarYasin
OmarYasin's Avatar
Oem op will not slide out. U must take the nut from the passanger side motor mount and lift the motor about 2 in for clearance.
OmarYasin is offline   Reply With Quote
Old 03-30-2015, 01:17 PM   #21
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Not true. I was able to get my OEM overpipe off and on twice w/o doing anything to the motor mounts. Might help to remove the heat shield first.
Originally Posted by humfrz
I'm old and lazy
Old 03-30-2015, 01:21 PM   #22
OmarYasin
OmarYasin's Avatar
I couldn't take heatshields off because the little bolts were corroded, thus motor was lifted to pull the op off
Old 03-30-2015, 01:27 PM   #23
Clipdat
Proud of BOXER
Clipdat's Avatar
Oh yeah, I could see that, those bolts are not very high quality.
I'm old and lazy
Old 03-30-2015, 02:11 PM   #24
OmarYasin
OmarYasin's Avatar
Btw i ended up with two oem op lol. I bought the invidia op to go with the invidia catless fp and catback and i got a hold of a oem header for free so now i have two oem op one with a broken stud in it the other with the studs still in contact
Old 03-30-2015, 02:12 PM   #25
OmarYasin
OmarYasin's Avatar
Trust me i tried to take the op off for about 20min till i said screw it and jacked the motor up.
Old 03-30-2015, 11:24 PM   #26
EvoPrecision8
Thanks for all the help guys! In the end my local shop ended up giving me a fantastic deal on a Tomei overpipe they had in stock. I'll probably still replace the stud on the stock one once it's off the car. That way I can always throw it back on if I sell the car or need major warranty work.
Old 03-30-2015, 11:44 PM   #27
EvoPrecision8
The stupidest part about the whole thing was the way it happened. The nut broke free without too much trouble, then it seized with only a couple of threads left on. The car is nearly brand new (1200 km) as well, so I wasn't expecting the heat or weathering to have seized things up too badly yet.
Old 03-31-2015, 12:30 AM   #28
mig86
Drives: MY15 86 GTS
Exact same here..... very frustrating.
Need Advice: Broken strut mount stud... cobrabyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 12-22-2014 04:37 PM
DIY Video - Perrin Exhaust Tip Install! (and how I dealt with broken OEM tip bolts) CruiseControl DIY (Do-It-Yourself) Guides 3 06-25-2014 09:05 PM
Broken stud on stock header BAMF86 Engine, Exhaust, Transmission 1 06-06-2014 04:27 PM
Broken Stut mount Stud. Anyone Did This Before? Figo Issues | Warranty | Recalls / TSB 3 07-19-2013 10:29 AM
Exhaust Tips & Broken Bolt eriktherod Cosmetic Modification (Interior/Exterior/Lighting) 0 08-07-2012 12:48 AM
