Old 11-09-2012, 07:43 PM   #15
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
So would the same go for the reverse? I have a set of sport edition rims for the winter. I was planning on using my stock lug nuts.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 11-10-2012, 01:29 AM   #16
NJA
Drives: Supercharged Saturn ION
this is good info...thanks guys
NJA is offline   Reply With Quote
Old 05-24-2013, 08:17 PM   #17
Perry
Drives: 86 Raven
Originally Posted by empower-auto View Post
and I now have nicer lug nuts. nice when I can pick em off the shelf at work haha
do you have pics?
Perry is offline   Reply With Quote
Old 05-24-2013, 08:44 PM   #18
empower-auto
Kouki-Monster
empower-auto's Avatar
Originally Posted by Perry View Post
do you have pics?
like selfies, bro?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 05-24-2013, 09:31 PM   #19
Sbeezy
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
no like pics of said lugs you took off the shelf at work
Sbeezy is offline   Reply With Quote
Old 05-24-2013, 11:38 PM   #20
wparsons
wparsons's Avatar
I'm running stock lugs on my RPF1's just fine, as long as the wheels you have for the winter are meant for conical seat lugs you're fine.
flickr
Gillams (02-25-2014)
Old 03-25-2015, 07:40 AM   #21
steveholt
Drives: 2015 BRZ Limited 6MT
are mcgard spline drive lug nuts ok with oem brz wheels?
steveholt is offline   Reply With Quote
Old 03-25-2015, 11:16 PM   #22
ka-t_240
^Should be fine, I run Muteki on stock wheels.
ka-t_240 is offline   Reply With Quote
Old 03-26-2015, 07:31 AM   #23
wparsons
wparsons's Avatar
As long as they're conical seat, yes. McGard might make different seat styles, not sure.
flickr
Old 03-26-2015, 06:33 PM   #24
steveholt
The mcgard website says:
"For use with wheels with lug nuts that utilize a 60 degree tapered cone seat at the bottom."
I imagine the oem wheels are 60 degree tapered cone seated?
Old 03-26-2015, 09:03 PM   #25
wparsons
wparsons's Avatar
Yep, you're good!
flickr
steveholt (03-26-2015)
Old 09-19-2018, 06:00 PM   #26
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Are you running open or closed end?
Thanks
scion fr-s is offline   Reply With Quote
Old 09-19-2018, 06:14 PM   #27
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Thanks
I ran Muteki open end (sr48) on stock wheels. Only downside to open is the debris/water that can get it. The sr48 stick out a fair bit but I bought them in prep for ARP studs
scion fr-s (09-20-2018)
Old 09-19-2018, 07:38 PM   #28
Beachin86
Beachin86's Avatar
Drives: FR-S 10 Series
It's probably worth noting the stock studs thread easily. I had two thread on me last time I rotated my tires. And yes, they were torqued down to factory spec 89 ft-lbs.
Just a heads-up if you're planning on swapping out all your lug nuts.
Beachin86 is offline   Reply With Quote
The Following User Says Thank You to Beachin86 For This Useful Post:
Stock Lug Nuts?? ESC POD Northwest 8 10-15-2012 12:43 AM
Factory wheels with aftermarket lug nuts. BigJyoungblood Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-21-2012 08:40 PM
Stock TPMS's with aftermarket valves/wheels? Phaedrus29 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2012 01:18 PM
Hub thread size and stock lug nuts onedollarodent Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-07-2012 08:40 PM
Aftermarket wheels on stock BRZ/86s yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 2 05-01-2012 02:52 AM
