Old 07-07-2012, 06:57 PM   #1
onedollarodent
Drives: None
Hub thread size and stock lug nuts
Hi all just a quick and easy one. What are the stock 86 lug nuts thread sizes and are the stock lug nuts the 60 degree type?
Just trying to get a set of enkeis ready before my 86 comes in a few weeks. Looking at a set of Legurra nuts (I think that's the brand).
onedollarodent is offline   Reply With Quote
Old 07-07-2012, 08:05 PM   #2
schtebie
Drives: CBS BRZ Limited
I believe the lug threads should be M12x1.25.
Factory lugs are usually a ball seat, not a cone seat (60-degree seat as you called it). You will have to buy new lugs for your vehicle if you don't have them already.
schtebie is offline   Reply With Quote
Old 07-07-2012, 08:22 PM   #3
xwd
Subarus (and the FR-S) use a cone (acorn, 60-degree taper, whatever you want to call it) stock so the stock lugnuts should work with most aftermarket wheels. And aftermarket lug nuts will work with the stock wheels.
The Following 2 Users Say Thank You to xwd For This Useful Post:
Fly Guy (07-08-2012), schtebie (07-07-2012)
Old 07-07-2012, 08:24 PM   #4
schtebie
Originally Posted by dwx View Post
Subarus (and the FR-S) use a cone, acorn, 60-degree taper, whatever you want to call it stock.
I had no idea. I learn something new every day!
Old 07-07-2012, 08:40 PM   #5
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
The hub bore on the wheel is also 56.1 mm as well.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Torque spec for lug nuts wrxneffect Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 09-06-2016 08:39 PM
Need Lug Nuts? Wheels? Hit us up! -FullyBolted.com Josh@FullyBolted.com Wheels and Tires 1 06-25-2012 02:04 PM
Calling all wheel nuts. Staticfrost AUSTRALIA 90 06-13-2012 09:33 AM
Thread size and pitch on gearshift knob. SilentMike Engine, Exhaust, Transmission 8 02-02-2012 02:20 PM
Stock Wheel Size Confirmed..? CoryUyede Scion FR-S / Toyota 86 GT86 General Forum 4 12-22-2011 12:26 AM
