#15 | |
Radio wiring harness guru
Drives: 1996 SVX L AWD
See this page on my site: Subaru/Toyota 16-pin camera socket information The Beat-Sonic harness has both a 16-pin plug and socket. Their harness passes through most of the pins from the car's factory plug to the HU. Since your car didn't have a factory plug, the Beat-Sonic's socket remains unused. You can touch the #6 pin there. Looking forward to seeing "before" and "after" pictures of your HU's Diagnostic and Camera Setting screens. BTW, it turned out that the only parking guide lines you were seeing were from the Rydeen camera, not the HU, correct?
#16 |
Drives: 2013 Scion 10 series frs
Where do you run the reverse trigger wire?
Sent from my SAMSUNG-SM-N910A using Tapatalk |
#17 |
I figured it out. Also found a connector that wasn't plugged in. I've never had that kickpanel off so it must have been a weak push from the factory.
| Rydeen Duo on BRZ Limited | sure74 | Electronics | Audio | NAV | Infotainment | 343 | 01-22-2019 06:28 PM |
| rydeen mini backup cam | jknakes | Electronics | Audio | NAV | Infotainment | 21 | 05-08-2015 10:04 PM |
| How to wire up with Rydeen Duo | Hyperian | Electronics | Audio | NAV | Infotainment | 6 | 05-16-2014 03:20 PM |
| Pioneer HU and Rydeen Duo Camera | pauland | Electronics | Audio | NAV | Infotainment | 5 | 03-04-2014 05:20 PM |
| Rydeen Duo installed on a Preimum | sparks | Electronics | Audio | NAV | Infotainment | 9 | 10-16-2012 05:39 PM |
