Old 05-18-2012, 10:01 PM   #43
Palmy
Palmy's Avatar
Drives: '12 86 GTS (AUDM)
[ame="http://www.youtube.com/watch?v=gCi2yo4UqPI"]Mighty Car Mods - Cold Air Intakes Mythbusted (Turbo) - YouTube[/ame]
Palmy is offline   Reply With Quote
The Following User Says Thank You to Palmy For This Useful Post:
ESBjiujitsu (05-18-2012)
Old 05-18-2012, 11:01 PM   #44
FoolCyclist
Drives: SWP BRZ Limited, MT
Originally Posted by StuttterButtter View Post
Factory Box with K&N filter inside done!
Well for me at least
K & N filters with oil can cause damage. AEM is making the same thing without the need for the lubricating oil.
FoolCyclist is offline   Reply With Quote
The Following User Says Thank You to FoolCyclist For This Useful Post:
StarsGarrador (05-27-2012)
Old 05-19-2012, 01:42 AM   #45
PERRIN_Jeff
PERRIN_Jeff's Avatar
Drives: Matte Black STI
Its for sure NOT ram air. The scoop is behind the bumper in an area that gets fresh air. During some pretty hard runs yesterday, I found the whole box was cool to the touch. Which I wasn't excpecting since part of the box gets hot air from the radiator blown on it.
I thought the filter was pretty small at first, then i compared it to an STI filter. Surprising actually.
To be fair to them, the K&N oil is light and CAN mess up MAF sensors. This problem is very rare and mainly issues after a customer cleans one and puts too much oil on it. Our filters are foam and use a much stickier oil. I can't even remember the last time a customer complained about oil on their MAF.
No filter is perfect for every customer, or every situation. But foam is pretty close.
PERRIN_Jeff is offline   Reply With Quote
The Following 3 Users Say Thank You to PERRIN_Jeff For This Useful Post:
86'd (05-19-2012), ESBjiujitsu (05-19-2012), Fly Guy (05-19-2012)
Old 05-19-2012, 02:40 AM   #46
86design
Attack By Demons
86design's Avatar
Drives: 2022 BRZ (pre ordered)
I didn't know that ARC was still around...is this intake for sale yet??
#attackbydemons #imcomingbackbish
86design is offline   Reply With Quote
Old 05-19-2012, 03:21 PM   #47
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
any videos of the sound???
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 05-19-2012, 03:36 PM   #48
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I plan to do a resonator and noise generator delete/plug and filter change...should improve/increase the sound and somewhat the throttle response. Plus it declutters the engine bay a little and removes a little weight up front... not much but hey it's a few lbs that doesn't truely need to be there IMO. Done it with my other vehicles and have liked the results (though MAP sensored honda's...)
Vracer111 is offline   Reply With Quote
Old 05-19-2012, 04:35 PM   #49
eight_six
Drives: None
I'd like to do a full resonator, noise tube etc delete too. Smoother pipe replacing the accordion piping. And not sure what it looks like under the bumper, but if there's a more direct path to fresh air that would be cool too
eight_six is offline   Reply With Quote
Old 05-19-2012, 05:49 PM   #50
StuttterButtter
Yes i have a stutter
StuttterButtter's Avatar
Drives: 94 Acura Integra
A friend has had 1 in his S2K for 4 years now and he loves it but you dont get the sound like you would with a "cold air intake" set up. S2k's seem to get the most power with the factory air box and from what iv heard the K&N filter seems to be the best. But this is what iv seen from S2000's
I think you'll see the same thing with the FR-S/BRZ
I have a feeling you will see the most power increase with a Factory box and a aftermarket filter K&N, TRD so on. But you'll loses that sound you would get with a cold air set up. But i have no facts to back this up.
Id rather get a few more HP the have the sound + exhaust is one of the first things on my list.
This is very true the TRD filters are a wet as well. When i was working for toyota and this problem occurred it was because people would just about soak the filter and that would throw a check E light. And if a filter is too wet you lose performance. Juts follow instructions and you wont have a problem.
StuttterButtter is offline   Reply With Quote
Old 05-19-2012, 06:19 PM   #51
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
I'd like to see a simpler, lighter box and tube to the throttle body. An also get rid of the sound tube. All that plastic and rubber has to weigh quite a bit.
Perhaps there can be a tube that goes straight down to the ground from the filter box? Though you'd have to cut, or create another underbody panel?
86'd is offline   Reply With Quote
Old 05-19-2012, 06:46 PM   #52
ESBjiujitsu
yeah a nice light aluminum or carbon box and streamline the flow slowly... of course that may not fit with a sc or turbo setup..... but maybe?
Old 05-19-2012, 07:10 PM   #53
Calum
That Guy
Drives: 2013 asphalt FRS MT
Wow, I'm amazed at how efficient that looks. On second thought, I don't think there's going to be much to gain there. I might remove the sound tube and resonator for room, but I bet that resonator is removing a lower pressure resonance to help smooth out the torque curve. (Please for the love of god don't read that as smooth out the torque DIP. I don't know what's causing that and I'm not trying to say this is helping it.)
Old 05-19-2012, 07:28 PM   #54
Calum
That Guy
Originally Posted by Draco-REX View Post
"Cold Air" has been a gimmick in the aftermarket for a VERY long time.
Agreed, but with a caveat. I've seen some cars that have HORRIBLE intake paths. Cleaning up the flow is the only real advantage of a 'cold air intake' and often times you can remove some bends or restrictions with out spending a ridiculous amount of money. If the intake system is good from the factory you wont gain a thing though.
My beater Neon took it's intake from inside the drivers side of the bumper cover. The air entered through an oval about 1.5 by 2 inches, turned 90 deg in a ~2.5 inch radius bend, went down about a foot for a resonator, turned 180 deg about ~4 inch radius bend, back up about 1.25 feet, 90 deg into filter box, through the filter box, into a bellows tube, and then into the intake at down angle of about 15 deg, to then have to turn ~105 deg to get into the intake runners... The resonator completely blocked off the bottom area of the bumper cover so there wasn't any flow coming in from there and there was a cover over the fog light opening. The only air entering was coming from air leaks in the wheel well and around the headlight which had a gasket.
I removed the resonator box leaving only the 90 bend going into the filter housing. I then remove the cover over the fog light whole to help move air into the area when the car is moving. The sound inside hasn't changed any that I've noticed, but it's got be getting more air.
Old 05-19-2012, 10:07 PM   #55
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Looks like it wouldn't be too hard to turn it into a ram air intake. Depending on how much room there is up front, you could hook up a bit of flexible hose to the end of the fresh air scoop and route to towards the front of the car. I don't know if there would be any benefit though. It certainly won't sound any faster like an aftermarket intake would.
industrial is offline   Reply With Quote
Old 05-19-2012, 11:54 PM   #56
PERRIN_Jeff
If tomorrow goes as planned, I will find out how efficient that intake is. I have about 4 main tests to perform to prove or disprove a Cold Air intake. Yes, one of those tests is seeing what happens with removing the sound generator and resonator. And no, my butt dyno isn't what I am using to prove this.
The Following 10 Users Say Thank You to PERRIN_Jeff For This Useful Post:
86'd (05-20-2012), Calum (05-20-2012), cmspooner (05-20-2012), Fly Guy (05-20-2012), industrial (05-20-2012), kmbkk (05-20-2012), LivingLegend (05-20-2012), Scooby South (05-20-2012), StarsGarrador (05-27-2012), Vracer111 (05-21-2012)
Short ram Intake/CAI ? QC-FRS Engine, Exhaust, Transmission 12 02-01-2014 08:02 PM
FRS AEM Cold Air Intake KenAEM Engine, Exhaust, Transmission 28 10-24-2012 12:48 PM
2013 Scion FRS AEM Cold Air Intake KenAEM Engine, Exhaust, Bolt-Ons 2 07-12-2012 07:30 PM
Does anyone have pictures of TRD intake Pekingduck Engine, Exhaust, Transmission 2 04-26-2012 10:37 PM
Brisbane meet up for a beer/cold beverage Nafe AUSTRALIA 10 03-09-2012 02:31 AM
