Old 03-17-2015, 07:13 PM   #15
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
Curious. I might get one. This is because I do my own oil changes too. It'll be easier....
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 03-17-2015, 07:32 PM   #16
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
Originally Posted by Cjymiller View Post
How is the clearance with that 1/2 inch nipple?
hardly sticks out just like gramicci, you'd have to drive over something that would scrape the entire underside to hit it. as it stands the resonator on my front pipe hangs much lower and i barely hit it.
i'm on RCE yellows so just under an inch drop.
best thing you can get to make oil changes as easy as they can get.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 03-17-2015, 07:36 PM   #17
swarb
I might get one because it will make the oil changes I do myself easier. Curious.
Old 03-23-2015, 04:36 PM   #18
Ridgerunr
Drives: 2015 Series Blue
I remember reading on the forester forum (traded one for brz) that subaru did not recommend this. Something about the flow being to slow and not being able to remove sludge or wherever from the engine... Who knows... I have been changing my own oil for 40+ years! drain plugs work for me.
Ridgerunr is offline   Reply With Quote
Old 03-23-2015, 04:42 PM   #19
jvincent
jvincent's Avatar
Originally Posted by kingnba6 View Post
anybody use these valves in areas where it snows and roads are covered with salt?
Yep. Changed my oil a couple of weeks ago, no issues.
Old 03-23-2015, 04:47 PM   #20
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
That's a load of crap, unless you just simply don't change oil at regular intervals.
2016 Camaro SS is offline   Reply With Quote
Old 03-23-2015, 05:10 PM   #21
Koa
Greddy magnetic drain plug > this
lazy asses!
The Following User Says Thank You to Koa For This Useful Post:
NyC Zn6 (04-16-2015)
Old 03-23-2015, 10:50 PM   #22
2016 Camaro SS
Drives: Fast
lazy asses!
Hey, at least my hands don't get dirty. I LIKE TO BE CLEAN.
Not to mention it takes additional time to drain since the hole is a lot smaller. I just go inside and watch TV and come back in a few hours.
The Following User Says Thank You to 2016 Camaro SS For This Useful Post:
Koa (03-24-2015)
Old 03-23-2015, 11:43 PM   #23
Imrac
Drives: 13 SWP BRZ Prem
I have one with the short nipple, s version I believe.
I just jack the car up, take my 3 gallon used oil container, slip a 6 inch hose on the drain valve and dump directly into the container. Come out 30 minutes and refill.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 03-24-2015, 10:43 AM   #24
Koa
ok im just salty, fumotos are awesome & I wish I had one
Old 03-24-2015, 11:20 AM   #25
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
You guys with the valve is it possible to change the oil without jacking up the car? Like how hard is it to turn the valve, I'm pretty thin and can reach the oil pan without lifting my car. I'm considering this if I can knock out one more step in changing my oil.
brandonblt2 is offline   Reply With Quote
Old 03-24-2015, 11:22 AM   #26
gramicci101
Off Topic
Actually turning the valve is easy. Fitting a drain pan and my arm under the car is less easy.
Old 03-24-2015, 12:19 PM   #27
brandonblt2
Ok cool and yea the reason I can fit is cause I have really long lanky arms
Old 03-24-2015, 12:46 PM   #28
2016 Camaro SS
Drives: Fast
Until you lower your car.... Valve is super easy to twist. I have the one with the nipple for the clear hose attachment which makes it so easy to drain.
GROUP BUY: Fumoto Drain Valve Simon99 Mechanical Maintenance and Tools 8 03-28-2014 07:27 PM
Fumoto valve in the winter? Muskokan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 02-25-2014 01:06 PM
Fumoto valve for transmission? SurfAndSand Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 09-16-2013 12:01 AM
Question about Fumoto valve Bleevin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 04-18-2013 10:27 AM
FS: Fumoto quick valve Laika Engine, Exhaust, Bolt-Ons 1 01-08-2013 02:51 PM
