#29 | ||
Drives: 93 MR2 Turbo; 2014 BRZ
Thanks. I didn't realize function7 had a set out yet. Theirs do look light and have some nice features to it! Any idea what weight it is? |
#30 | |
That Guy
Drives: 2013 asphalt FRS MT
Any chance you guys would be willing to look at the adjustable camber bushing? Whiteline had one a while ago but they discontinued it when they brought out their control arms. There are a few of us that like the factory arms as they'll break before needing to pull a frame back to shape. It might seem like competing markets but to me it really isn't. |
#31 | |
Because compromise ®
Drives: Red Herring
The idea of having an adjustable super rigid arm appeals for handling but the consequence of having a body bending off keeps me away.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Calum (02-18-2015) |
#32 | ||
| The Following User Says Thank You to eric6 For This Useful Post: | Captain Snooze (02-20-2015) |
#33 | |
Unless we are mistaken, different damper mounting points will only change allowable travel if the holes are vertically integrated (SPL's are horizontally). Horizontal adjustment will change the wheel motion ratio but we feel the stock location is adequate and are not sure why you would want to change this. We will continue to discuss though. ARB mounting points that are horizontally adjustable (like SPL's) can be used to change the stiffness of the rear ARB. However, adjustable endlinks may be necessary. Not sure. Another thing we will continue to discuss until production begins. You have PM. |
#34 | |
SPL's arms have adjustability both horizontally and vertically now. They revised them a few weeks ago, just FYI.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
#35 |
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
How about a camber adjusting LCA that doesn't put a bending load on a rod end shank? I know everybody does it and mostly gets away with it but it is still a fatigue crack waiting to happen.
#36 |
Drives: Strangely.
These aluminum arms are meant to be lighter than SPL's titanium? If so, props.
My FR-S has a build thread!
(It's mostly full of Nissans) |
#37 | |
To our knowledge, these are the lightest on the market. We don't know of another LCA that weighs less than three pounds, and these are quite a bit lighter. |
#38 | |
Drives: Strangely.
#39 |
Figured it about time to update the thread
. So we started development with a few overall goals and then capitalized on them with extensive FEA analysis. FEA (Finite Element Analysis) uses a numerical, computer based technique to solve complex scenarios. A variety of scenarios can be predicted, such as stress, heat transfer, vibration, fatique, and other physical effects. The power of FEA lies in the ability to solve problems that would be extremely difficult or impossible to solve by hand. Similar to CFD, FEA partitions the structure into a finite number of elements. These elements form standard shapes, such as triangles, quadrilaterals, hexagons, etc. The use of these standard shapes allows the development of a governing equations that can related stresses and displacement within the element. Please keep in mind that FEA is a tool, and in the wrong hands, it can be like shooting a target blindfolded. You need accurate inputs for an accurate output.![]() Close up of the mesh. We tested the component with three loads placed on the LCA simultaneously. 1.7G lateral acceleration, 3.5G bump acceleration, and 0.75G longitudinal acceleration. This is a heavy turn, while hitting a track curb, while accelerating. These loads are race car loads, think large slicks, quite a bit of aero work, and 350+ hp. We tested various other cases, but found this to be the most damaging to the model, so we designed around it. ![]() Stress in tension. When we say tension, we are speaking about the lateral acceleration. If we think briefly about how the lateral acceleration affects the inside or the outside wheel, you will understand where we get tension and compression from. The inside wheel’s LCA is seeing a tensile lateral acceleration, while the outside wheel’s LCA is seeing a compressive load. The tensile load is less than that of the compressive load due to weight transfer while going around a corner. ![]() Deformation in tension. ![]() Stress in compression. ![]() Deformation in compression. Please let us know if you have any questions. We will be testing these units off car soon, which should let us know how well our FEA analysis lines up with real world results. Then... onto some race cars .
| The Following 5 Users Say Thank You to eric6 For This Useful Post: | Black Tire (03-04-2015), blue cat (03-03-2015), Captain Snooze (03-14-2015), D_Thissen (03-03-2015), Takumi788 (03-04-2015) |
#40 |
Here are some non-professional photos taken by myself. These do not do them justice. I'm sure Jeremy will help us out there when he snags us a few.
![]() ![]() And a hint for what is to come .
#41 |
That Guy
That's strain gauge isn't it? But that part of the assembly will have threads all the way through it which will throw off your readings by a good margin. And, wouldn't you want another one perpendicular to that one to account for temperature variation?
#42 |
Alexandrino_Auto
Drives: series.Blue
So... When do I get my prototype for street testing? I'm the perfect candidate; I commute 128 miles per day.
The Shadetree Project: I turn wrenches
| Verus Engineering Rear Wing Development | VerusEric | Tracking / Autocross / HPDE / Drifting | 203 | 07-05-2021 10:15 AM |
| Verus' Shop BRZ - Development Thread | VerusEric | Member's Car Journals | 266 | 12-19-2019 05:12 PM |
| FT-86 SpeedFactory Diffuser by Verus - Complete Aero Solution | FT-86 SpeedFactory | Cosmetic Modification (Interior/Exterior/Lighting) | 574 | 09-15-2019 11:10 AM |
| FT-86 SpeedFactory Turbo Kit - Development and Testing | FT-86 SpeedFactory | Forced Induction | 271 | 09-20-2017 12:07 AM |
| Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering | VerusEric | Cosmetic Modification (Interior/Exterior/Lighting) | 25 | 09-22-2016 02:41 AM |
