go_a_way1
Old 02-16-2015, 12:10 PM   #15
Calum
That Guy
Drives: 2013 asphalt FRS MT
Eric, I'm glad to see you still producing for the twins. I hadn't seen much from you recently which had me worried the boards negativity had gotten to you.
I'll admit though that I didn't expect to see you in such a saturated market. I'm curious to see what you come up with and how it's going to be different from the masses.
And in keeping with the negativity from before, I think you missed a zero. I can hit tolerances of less than 5 thou with a file and a well mounted vice.
Calum is offline
The Following 2 Users Say Thank You to Calum For This Useful Post:
Dimman (04-02-2015), GT86_PRAGUE (09-28-2015)
Old 02-16-2015, 01:21 PM   #16
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Perhaps too hasty of a question but....any idea on an estimate price? More than the SPC lca but less than the SPL lca.....maaaaybe?
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline
Old 02-16-2015, 02:28 PM   #17
Koa
bro they said earlier that it was too early to tell.. but pricing will be competitive
Koa is offline
The Following User Says Thank You to Koa For This Useful Post:
JohnJuan (02-17-2015)
Old 02-16-2015, 04:03 PM   #18
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Why not go the SPL route and do the multiple mounting points for the shock and sway bar? Maybe something different than any current ones out there don't have? I know that sounds stupid, but you're limited.
There's already so many LCA's out there. In fact i contacted one suspension builder i know who is making parts for our twins and he flat out said there's no point in making a LCA because the market for it is already so competitive.
dem00n is offline
Old 02-16-2015, 05:00 PM   #19
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
What isn't saturated with these cars anymore? FT86-Speedfactory asked us to come up with something, and we came up with these. The major difference is the weight. We are well under 3lbs per side fully loaded.
Definitely more then SPC, unsure about SPL. These aren't going to be the cheapest, I just said competitive. Their has been a significant amount of work that went into these, as well as using a superior alloy of aluminum then anything else out.
I'm a little curious as to why that adjustment is necessary?
See above as to why we came out with something.
eric6 is offline
The Following 2 Users Say Thank You to eric6 For This Useful Post:
Lonewolf (02-16-2015), themajesticone (02-16-2015)
Old 02-16-2015, 05:35 PM   #20
dem00n
dem00n's Avatar
Drives: Scion FRS
Different shock mounting point for more travel and the other mounting point for adjustable stiffness.
It seems that the people using the SPL LCA's compete in a lot of motorsports so that extra fine tuning means a lot to them.
dem00n is offline
Old 02-16-2015, 05:53 PM   #21
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
sweet! Love seeing new options + development of it
can't wait for price
continuecrushing is offline
Old 02-16-2015, 05:58 PM   #22
s2d4
s2d4's Avatar
Guess self leveling sensor allowance would be a good differentiation.
s2d4 is offline
Old 02-16-2015, 06:51 PM   #23
Calum
That Guy
Good to hear!
Calum is offline
Old 02-16-2015, 08:14 PM   #24
themajesticone
Drives: '13 UM86
Hey I waited a day!
Old 02-17-2015, 12:23 AM   #25
eric6
eric6's Avatar
Thanks!
We will look into it. We don't have that in the states, making it difficult to see what is needed.
Good to hear!
. We like this car and community quite a bit. Their is always negative people. Especially when you're new and don't do everything by the book.
eric6 is offline
The Following User Says Thank You to eric6 For This Useful Post:
Calum (02-17-2015)
Old 02-17-2015, 01:52 AM   #26
Turdinator
Señor Member
Turdinator's Avatar
@eric6 any thoughts on doing a light weight upper control arm? From the reports I have seen they are rather heavy.
1974 TA22 Celica
2013 86 GT
Turdinator is offline
Old 02-17-2015, 04:27 AM   #27
Calum
That Guy
CNC ported heads with a naturally aspirated goal.
A means if adjusting camber via an offset bolt/bushing on the rear LCA.
And adjustable stock size or only slightly larger sway bar set.
That's all I can think of.
Calum is offline
The Following User Says Thank You to Calum For This Useful Post:
dem00n (02-17-2015)
Old 02-17-2015, 02:44 PM   #28
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Arms look great! I have function7's on my car now and curious to see if these end up lighter.
JDLAutoDesign is offline
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 10:15 AM
Verus' Shop BRZ - Development Thread VerusEric Member's Car Journals 266 12-19-2019 05:12 PM
FT-86 SpeedFactory Diffuser by Verus - Complete Aero Solution FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 574 09-15-2019 11:10 AM
FT-86 SpeedFactory Turbo Kit - Development and Testing FT-86 SpeedFactory Forced Induction 271 09-20-2017 12:07 AM
Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 25 09-22-2016 02:41 AM
