Old 03-11-2015, 01:03 PM   #15
Tmo
Drives: 2013 FRS
Originally Posted by gramicci101 View Post
A similar idea is already being produced. Look into a product called filtermag.
I'm always late to the party, could of been a millionaire
Tmo is offline   Reply With Quote
Old 03-12-2015, 01:32 PM   #16
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Anyone see if the filtermag actually keep stuff in the filter? I got one recently, and has been on for this oil change. I'll open up the filter and see if it actually holds stuff. I thought it would come with two sides to go around the whole filter, but it didnt.. so its a pretty expensive magnet. Hopefully it actually works! should be clear with my filter since one side has it and the other side doesnt. if it does, ill pick up another side
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 03-12-2015, 09:00 PM   #17
tracerit
Drives: '13 SSM BRZ Limited 6MT
Not sure if it works this way but I'm thinking it's only half sided so if one were to open up the filter they could compare each side. Intrigued by this fjltermag as well but Damn it's expensive.
tracerit is offline   Reply With Quote
Old 12-23-2015, 02:57 PM   #18
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
Anyone using the fumoto oil valve, did you use the gasket they supplied (nylon?) or did you use a metal subaru washer?
BDotG is offline   Reply With Quote
Old 12-23-2015, 03:05 PM   #19
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by Tmo View Post
This is a really old post, but I just now had an epiphany. I am more of a computer geek than a real gear head so please excuse my nerdyness. I personally wouldn't want to exchange function for the ease of changing my oil. I do however believe in finding a way
The idea I had was to insert a magnet around the drain plug. If you have an old hard drive laying around, this should work perfectly and would be about the same strength I would think. A hard drive has 2 magnets attached to a metal piece in the shape of about a half circle so you could surround the valve. I'd leave the metal on but you can take it off I suppose. Might make it harder to remove though. I'd throw a little grease on it to prevent corrosion too. The metal should get stuck to the bottom of the pan and should be removed when you drain the oil (provided you removed the magnets). I'm sure that there are other magnets that would serve the purpose, but this is the first thing that I thought of when looking for a roundish magnet to surround the valve. Any thoughts about this or do you see any problems with this setup??
Good idea. But it's possible that whenever it's drained, metal could accumulate in the valve and eventually clog. Maybe not at the first few oil changes, but eventually. Would be nice if the valve was designed to not clog and its plug were magnetic.
Old 12-23-2015, 03:54 PM   #20
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Nylon.
BDotG (12-23-2015)
Old 01-04-2016, 07:36 PM   #21
ze12o
Drives: BRZ 2015 DGM
Nylon. no problems so far 4xx miles
ze12o is offline   Reply With Quote
Installed Perrin shifter bushing & Fumoto oil drain valve zooki Engine, Exhaust, Transmission 23 03-31-2013 05:18 PM
Magnetic oil drain plug, effective? BRZPDX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 02-16-2013 11:59 PM
Greedy Magnetic Drain Plug USMC -FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 02-10-2013 06:04 PM
GReddy Magnetic Drain Plug BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 01-05-2013 10:19 PM
Greddy Neodymium Magnetic Drain Bolt Subaru FRZ Scion FR-S Toyota GT86 any reviews? FRS-HHH Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 12-22-2012 04:55 AM
